  1. Aug 1, 2021 at 11:22 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @jpink let me swap tires for 13WL test fitment as I still have 13WE front calipers.
    There's just a splash of red poking through on his powerstops which I think is pretty cool.
    A gnat's cock worth of clearance.
    @FirstGenVol drove my truck, and told me that he thinks my stiff brake pedal is from seized calipers. That made everything click into place in my nugget. That explains why it comes, and goes. It also explains why when a seized piston/caliper breaks free the front end of the truck nose dives hard core.
    I've just been putting a little extra foot into the pedal to make do...
    So, moving forward with continual progress... @jpink gave me a set of extra 13WL rotors from his refresh that weren't bad, and had been sitting in storage since October. Plenty of life left on them. Also gave me a set of recently changed pads, and anti-squeal shims he didn't need as a 2005 DC. I ordered a set of rebuild kits for my 13WE calipers, and a set of Powerstop 13WL calipers with a discount code for an absolute rock bottom price.
    The plan moving forward is as follows:
    1. Install new 13WL.
    2. Bleed.
    3. Rebuild my 13WE calipers.
    4. Box up my old calipers, and rotors. Label 13WE SMOL, and keep as a back up.
    oscardog86, bmf4069, NUDRAT and 6 others like this.
  2. Aug 1, 2021 at 12:13 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Yikes, don't get a rock in thar.
    Darkness and Tundra2 like this.
  3. Aug 1, 2021 at 12:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Didn't even consider that, but feck it.
  4. Aug 1, 2021 at 12:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Aug 1, 2021 at 12:47 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    PTR20-35110-BK (black) with the K02 All Terrain wouldn't look bad on there, but your current wheels are also nice.
  6. Aug 1, 2021 at 2:53 PM
    Finally got around to replacing the back door window latches on the Tundra. Whoever machined these really made a tight fit on the side that pivots the latch on the window side. Glad I had a ball-peen hammer and punch to do it otherwise I’d be cutting that hole just slightly bigger.
    Bmktw2, Klob, shifty` and 10 others like this.
  7. Aug 1, 2021 at 7:01 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Is it just me or does the one on the right seem wider?
    Tundra2[QUOTED] and NUDRAT like this.
  8. Aug 1, 2021 at 7:09 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I'd still like an 04 DC with a supercharger to trailer my AC to the trails someday. That way I don't have to fear having too good of a time and limping home 5 hours lol
    NUDRAT and Darkness like this.
  9. Aug 1, 2021 at 7:20 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    My sequoia has towed everything i can throw at it like a champ. And for a 2wd its a billygoat, climbed in and out of lots of river trails, and never wiggled or anything during the icepocalypse of feb.
  10. Aug 1, 2021 at 7:39 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    The extra traction to the rear tires from the weight of the cab probably helps a lot vs a 2wd pickup
  11. Aug 1, 2021 at 7:48 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont know if it came with lsd, but when the diff was replaced they put an lsd in it. Sometimes i hang it way out on rainy days.
    NUDRAT, bmf4069 and Thrussn like this.
  12. Aug 1, 2021 at 7:56 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I put my tundra in a ditch that way once but she crawled right out unscathed. Mine came with LSD.
    bmf4069 and Darkness like this.
  13. Aug 2, 2021 at 5:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  14. Aug 2, 2021 at 9:09 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    So an update on this...
    1. The idle has settled back to where it should be after a day or two:
    2. New bypass hoses and clamps from McGeorge solved the leak problem. (Note to self - whenever opening coolant hose/clamps that have been unmolested for ~ 17 years just assume they'll never go back together the same way and buy new to begin with).
    3. While I thought the P0420 code was related (because it never happened before, and only started literally the same day I did the other work), it turns out not to be the case!
    I did some googling around, and crawled under my truck and saw that the rear driver's side O2 sensor nuts had turned to dust. The sensor was opening up at the gasket. (I was planning to change all the O2 sensors, but not now!). Intermittent P0420 codes predict this very failure, especially on 1st Gen Tundras and Sequoias. Here's the quick fix:
    1. Remove the shield, sensor, gasket (or remnants thereof).
    2. Hit the studs with PB blaster, and chase them clean with an M8 x 1.25 die
    3. Get a new gasket at Autozone, NAPA, wherever (The right thing to do is get a new Denso, but that's a project for another day)
    4. Go to Ace Hardware (or wherever) and get M8 x 1.25 stainless steel nuts and washers (get extra, you can sacrifice a nut if you don't have a die).
    5. Put it all back together, using anti-seize so I can get it back apart again when the new sensors arrive.
  15. Aug 2, 2021 at 9:31 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Missionary, they're doing it wrong.
    bmf4069, jpink, TRDGen and 6 others like this.
  16. Aug 2, 2021 at 9:32 AM
    They are, but maybe there's one more person under the truck not pictured. Eww.
    bmf4069, Tundra2 and Darkness like this.
  17. Aug 2, 2021 at 9:33 AM
    Lil Steve
    Gilbert, AZ
  18. Aug 2, 2021 at 9:33 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Fun fact. Those calipers are almost identical to 2nd gen Tacoma and 3rd gen Tacoma calipers. The only difference is the line location. So if the wheel clears a 3rd gen, it’ll clear yours
  19. Aug 2, 2021 at 10:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Good deal! Thanks for the extra confirmation. I'll stick this info in my note pad thread. Any reason to go up to 17" rims then?
  20. Aug 2, 2021 at 10:17 AM
    Better tire selection
    Tundra2[QUOTED] likes this.
  21. Aug 2, 2021 at 10:54 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Prepping for 14wa calipers?
  22. Aug 2, 2021 at 11:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    13WL
  23. Aug 2, 2021 at 11:04 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    ... I meant as a reason to go 17's :burnrubber:
    TRDGen, Darkness and Tundra2[QUOTED] like this.
  24. Aug 2, 2021 at 11:07 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I think at 17 you’re legally required to call em rims, and 18 or bigger you have to pronounce it rimz.
    NUDRAT, TRDGen, Darkness and 2 others like this.
  25. Aug 2, 2021 at 11:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naw, just more clearance is all I was considering. Now, if my booster went out, and price of a direct replacement was roughly the same cost as the T100 booster that @Thrussn used on his....
    Darkness likes this.
  26. Aug 2, 2021 at 11:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  27. Aug 2, 2021 at 11:15 AM
    Do all the OEM calipers have rebuild kits? I never bothered to check.
  28. Aug 2, 2021 at 11:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I ordered a set of seal kits from rockauto. Not sure if it's everything I need, but I'm gonna attempt to rebuild my 13WEs, and keep as back ups. If I can't rebuild them, I'll send them to roack auto for a core charge :rofl:
    If I did end up sending them back, that means I've only spent $100~ish on the 13WL power stop calipers, and two seal kits thanks to discount code that was single use unfortunately...
  29. Aug 2, 2021 at 11:21 AM
    daveeasa
    Anyone have a part number handy for 1st gen water pump? I'll commence searching.
    Perhaps this guy?
    16100-09201
  30. Aug 2, 2021 at 11:25 AM
    Not to downplay the humor, but that's technically a 'box', not a 'donk' or 'bubble'. Any truly cultured person knows the difference. :rofl:
