Door check problems
Discussion in '1st Gen Tundras (2000-2006)' started by slowdisco, Sep 27, 2018.
  1. Sep 27, 2018 at 7:49 AM
    slowdisco
    slowdisco [OP] New Member
    2000 Toyota Tundra TRD White
    I have a 2000 tundra and the driver side door check will not hold it open anymore. So the door will shut if i am on a slight incline. I have looked for the part and it seems that they don't make an aftermarket only a $80 oem. Anyone else have this issue and solution. Thanks
  2. Oct 27, 2018 at 10:35 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I feel your pain. I tried and was able to find a used one at a junkyard but it wasn't that good. Finally got fed up with my rear doors not staying half or all the way open and bought two new OEM ones for $80/piece. Sucks but I'm much happier putting my kids in the back now.
  3. Oct 28, 2018 at 10:40 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Been tinkering on the 02’ today and read this which prompted me to look at my ‘door check’. They were not fully engaging like when new. I took my 10mm socket and tighten up the 2 screws on the hinge side of door above and below the ‘check’. They were slightly loose at all 4 doors. Tightened them a 1/4 turn and the doors (all 4) have better tension now! Not like new, but close enough.
    Also, as a heads up, you can tighten that one 10mm on the handle side door jambs to correct a rattling window (when opened).
    Tundra family, Sunnier and 15whtrd like this.
  4. Jul 30, 2020 at 9:21 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Bringing this one up from the dead.
    Has anyone found a better solution? I went up camping this weekend and it was pretty annoying having both doors trying to close on me when I am in the cab. They are so bad that it doesn't even take them being on an incline and they want to shut on their own.
  5. Jul 30, 2020 at 10:15 AM
    bmf4069 Captain wtf
    I think it's OEM only. Someone took one apart to see if it was serviceable, but it wasn't. PHM is more versed on that than me though.
  6. Jul 30, 2020 at 10:25 AM
    SouthPaw
    2000 Limited 4x4 AC
    That's what I was afraid of.... There is a local toyota salvage yard that I might be able to pick through.
  7. Jul 30, 2020 at 11:20 AM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Yep, me too.
    Getting the groceries out of the back seat is a challenge when the door closes faster than you can get in.
    Seems like the back doors are worse then the fronts for some reason.
    04DCTundraMan likes this.
  8. Jul 30, 2020 at 11:36 AM
    SouthPaw
    2000 Limited 4x4 AC
    I guess I haven't paid that close of attention to the rear doors but the front ones close so fast now, don't know if I can get the rears open in time :annoyed:
    Sunnier likes this.
  9. Jul 30, 2020 at 1:21 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    haha! i feel your pain. My rear left door only takes nothing for it to close. my daughter gets so annoyed cuz it closes on her. Cleaning my truck out is always so annoying with that too. Im at the point of buying a new one.
    theblurry1 likes this.
  10. Jul 30, 2020 at 2:14 PM
    Fred
    Hand Protectors
    @theblurry1 replaced his with new ones and sent me his old ones to experiment with. I took them apart per a youtuber guy instructional, but these Toy ones are not as serviceable as the youtubes. I’m not one the give up so I tried a few angles, but then decided it is not worth the effort to half ass them. Figured I’ll buy new ones (MAYBE) down the road some day. They are like $83 each! Wwoooooweeee!!!
    The door panel needs removal, as well, so these will probably never get replaced because I am done with that pulling those off ever again unless absolutely necessary.
  11. Jul 30, 2020 at 6:04 PM
    SouthPaw
    2000 Limited 4x4 AC
    Kind of where I'm at, $83 a whack?! Ouch.
  12. Jul 31, 2020 at 7:20 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Also, don't go through the trouble of replacing these door checks with more used ones. I thought I was saving all this money on my driver's rear but it's only marginally better. Wish I had gone new!
  13. Jul 31, 2020 at 9:11 AM
    SouthPaw
    2000 Limited 4x4 AC
    Well the good news is the rear ones seem to be just fine (at least for my standards) bad news is, they are still $80 each lol.
  14. Jul 31, 2020 at 3:09 PM
    Fred
    Hand Protectors
    Yeah. My rear checks still work (he said). $80 dollas. Woooweeee!
    Fugetaboutit!
  15. Aug 2, 2021 at 6:39 AM
    Bearbrew
    Bearbrew New Member
    Ben
    2000 Tundra 4X4
    Recently purchased the door check repair kit, https://www.ebay.com/itm/293549708759. The kit came from Russia and took about three weeks to arrive. I will be installing the kit with in the next few days. scrolling down on the Ebay page will show the instructions for repairing the door checks. One kit will repair all 4 doors.
    Got the door checks installed today. A fairly simple job. I used the included shims when reassembling and now the doors are really tight to open or close. Most likely the door checks will loosen up a little over time. If they don't I will still be quite happy with the checks. No more of having the door closing on me while trying to get something out of the truck.
    e3phung, bmf4069, SouthPaw and 2 others like this.
  16. Aug 2, 2021 at 6:42 AM
    Love to see if these work out well for you. Need to repair mine.
  17. Aug 2, 2021 at 10:23 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    the first gen tundras FB page there was a guy who said 06 Camry door checks were 17 doll hairs a piece and worked like a charm for him, I'll be ordering a set now and updating with results.
    Weagle, Sampson, bmf4069 and 3 others like this.
  18. Aug 2, 2021 at 11:15 AM
    05tundra916
    05tundra916 New Member
    2005 Toyota Tundra Double Cab
    Curious to know if this works for you.
  19. Aug 2, 2021 at 1:14 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Subscribed.
    Would love to hear how it works out!
    05tundra916 likes this.
  20. Aug 2, 2021 at 8:21 PM
    SouthPaw
    2000 Limited 4x4 AC
    I just ordered a set as well. A guy on the FGT FB group used the same set and said they work well. I have been meaning to replace mine and if these work, I’ll be happy as hell for $28.
  21. Aug 2, 2021 at 8:36 PM
    I replaced the rear door checks in my double cab because I was worried about the kids getting in. Replaced with OEM checks, maybe a years worth of use and they are already garbage; I just anticipate the kankle crunch now
    tacoguybill likes this.
  22. Aug 3, 2021 at 3:25 PM
    SouthPaw
    2000 Limited 4x4 AC
    I redact that post.
    I ended up ordering a set of these. They were only $12/ea and if they work, I will be happy. If they don't, I will return them.
    https://www.amazon.com/gp/product/B07S8NGXMS?ie=UTF8
  23. Aug 3, 2021 at 3:28 PM
  24. Aug 3, 2021 at 3:29 PM
    SouthPaw
    2000 Limited 4x4 AC
    They are for a camry lol. I snapped some pics of mine and did some comparing. They look identical so fingers crossed they work. I don't mind being the beta tester. Mine are so bad now, they close by themselves... on level ground lol.
  25. Aug 3, 2021 at 3:32 PM
    Same here with OE rear checks…….. 1 years old
  26. Aug 4, 2021 at 4:02 AM
    tacoguybill
    Saaaan Diaaago
    received mine from ole Jeff B yesterday, but was also trying to figure out why the trusty (until now) lawn mower is quitting out on me, I'll try to install them this afternoon if the boss doesn't give me the stink eye for keeping a half mowed lawn :rofl:
    SouthPaw and 05tundra916 like this.
  27. Aug 4, 2021 at 7:00 AM
    SouthPaw
    2000 Limited 4x4 AC
    The OE ones only lasted a year?!
  28. Aug 4, 2021 at 7:03 AM
    Yep. Super disappointed. But if the carolla ones work for cheaper for only a year, still a win haha
    I went back and looked at my install post, September of 2019
  29. Aug 4, 2021 at 7:04 AM
    SouthPaw
    2000 Limited 4x4 AC
    They come in today and I should be able to put them on this weekend. I will keep everyone posted.
  30. Aug 4, 2021 at 7:20 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Please do. I put them on my wish list hoping that they work well for you. :fingerscrossed:
    SouthPaw[QUOTED] likes this.
