TRD sway bar?
Discussion in '2.5 Gen Tundras (2014-2021)' started by CH1NO, Apr 2, 2020.
  1. Aug 1, 2021 at 9:39 AM
    #121
    Elduder
    Elduder New Member
    People over think this, I think :monocle:
    I ran the RSB on my Pro. Basically if you own a Tundra and have ever taken a turn going >20mph it will make a difference. It will make a useful difference when towing. It wont make your truck a sports car, but it will make it feel more sporty. It will stiffen the rear suspension feel a bit over potholes and any bump that affects one side of the truck.
    If you can spare a couple hundred its worth it.
  2. Aug 1, 2021 at 9:57 AM
    #122
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Just put them on the truck, front and rear, feels great when turning , and does help towing, specially on heavy loads.
    nobodyintexas likes this.
  3. Aug 1, 2021 at 10:10 AM
    #123
    Elduder
    Elduder New Member
  4. Aug 1, 2021 at 10:13 AM
    #124
    Elduder
    Elduder New Member
    Toyota was back ordered on these. I tried my local dealer and at first they stated it was indefinite back order but you could still order. Now Toyota just put a stop sell on it because people are buying them up and I guess theyre way backed up at their part factories due to covid.
  5. Aug 1, 2021 at 10:44 AM
    #125
    French Avocado
    Utah / Wyo
    Just installed - big difference in cornering and staying grounded.
  6. Aug 1, 2021 at 3:57 PM
    #126
    pursuit2550
    pursuit2550 New Member
    I installed mines on Friday before leaving on a long trip. It makes a big difference on the turns. It does stiffen up the rear end on a straight line drive. And it wasn’t on back order through my dealer. I ha e to re-torque everything tomorrow because I only had a cheap ass torque wrench and saw the u-bolts bending. But from other pics the u-bolts do bend. Either way it was worth it.
    French Avocado likes this.
  7. Aug 1, 2021 at 4:16 PM
    #127
    Downytide
    GTA
    Some tundra accessories parts will be discontinued soon, I think sway bars are one of them, the oem pop lock as well.
  8. Aug 1, 2021 at 4:22 PM
    #128
    pursuit2550
    Wonder why. Any info on this. Either way I got mines already.
  9. Aug 1, 2021 at 4:31 PM
    #129
    Elduder
    Elduder New Member
    Where did you hear/read this?
    It would seem a little odd for Toyota as they still offer TRD parts for vehicles that are older than our Tundras. Hell, you can still buy the TRD brake kits for the 2000 era Celicas, or sway bars the Scion cars.
    Oey12 and French Avocado like this.
  10. Aug 1, 2021 at 4:41 PM
    #130
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I just installed mine yesterday. Used a CDI split beam torque wrench and my u-bolts bent on the top. I think they're supposed to.
  11. Aug 1, 2021 at 7:13 PM
    #131
    Downytide
    GTA
    The sways are considered accessories, and accessories production usually stops around same time as vehicle production stops, which will be in next 45 days.
    So whatever stock left is pretty much it.
    For 2000s era celica trd parts, those are nos parts, those brake kits were made by stoptech, same reason why it's almost impossible to find the replacement rotors for the trd 400mm BBK.
  12. Aug 1, 2021 at 7:17 PM
    #132
    I like the color match on the hardware.....powdercoat or paint?
  13. Aug 1, 2021 at 7:42 PM
    #133
    Elduder
    Elduder New Member
    The Tundra isnt stopping production though. We know its under going a generation change but it would be the same situation the Tacoma has gone through. Yet you can still buy the 2nd gen TRD parts, intake, short shifter, exhaust. Same applies to the FJ cruiser, which is out of production.
    As I had previously mentioned TRD still produces the sway bar for the Scion models, while this is a shared platform with the Corolla its again a previous generation, just as the current iteration of the Tundra will be this fall.
    https://parts.toyota.com/p/Scion_2005_TC/TRD-Sway-Bar/69528915/PTR112105110.html
    I havent any issue with being wrong, I surely hope I am not though, simply because the rear sway bar for the Tundra is easily one of their most selling Tundra accessories. There are shortages from the factories right now, which at least as I had been told by Toyota resulted in the stop sale. I have a hard time seeing them stop production on the rear sway bar, while the front is still listed in production.
    It might be a gray area, but there are federal laws prohibiting a manufacturer from ceasing production of a stock part for a vehicle within a 10 year period of its production. I suppose it could be argued that since the sport models come stock with RSBs, that I would hope to assume they would at least remain in production until 2028.
    Cpl_Punishment likes this.
  14. Aug 1, 2021 at 7:52 PM
    #134
    Downytide
    GTA
    This gen is, xk50 is stopping at end of September, or around there, scion trd parts are nos , they are not in production.
    And you are right on service parts, so they will most likely make it only available if you had equipped it from factory, but the production for these are stopping soon, same as pop lock kit, doesn't mean will run out, but don't expect it to be widely available as they are now.
    Elduder likes this.
  15. Aug 1, 2021 at 7:55 PM
    #135
    Elduder
    Elduder New Member
    Bummer
    Interesting to learn the bit about Scion parts. Glad I ordered my bar today in that case.
  16. Aug 1, 2021 at 8:01 PM
    #136
    Downytide
    GTA
    They over estimate the Scion parts demand by a large margin lol.
    I recall they said they estimate 40% of scion tc will leave the lot with some sort of trd parts, which raise some eyebrows at dealer convention, oh well.
  17. Aug 1, 2021 at 8:38 PM
    #137
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The torque numbers are all over this site but the rear sway bar is one of the best mods you can do.
    If you really off road, then you already know that you should not have sway bars.
    If on the fence, do it.
  18. Aug 1, 2021 at 9:34 PM
    #138
    French Avocado
    Utah / Wyo
    Powder coated at same time as coils - minimum at powder coater so added in the hardware to be done. It does change the wrench sizes however due to the powder coat added width to the bolts and nuts.
    Tundra234[QUOTED] likes this.
  19. Aug 25, 2021 at 5:52 AM
    #139
    Shaken_1
    Shaken_1 New Member
    2015 TRD 4x4 OffRoad CrewMax
    I added the front to my trd then went continued the red look after20210622_223702.jpg
    French Avocado and Bammer like this.
