Skullclowns Stormtrooper CrewMax
Discussion in '2.5 Gen Builds (2014-2021)' started by skullclown, Sep 29, 2020.
  1. Jul 18, 2021 at 1:16 PM
    skullclown
    skullclown [OP] New Member
    Steven
    North Carolina
    2015 White Tundra CrewMax Limited
    FOX 3" DCS, JBA UCAs, RRW RR6-H w/ Cooper STT Pro 315/70r17, C4 Front Overland Bumper, Thule Bedrack, Ultraflex Tonneau
    Installed Thule Aero bars on roof, waiting on Yakima LockNLoad platform to arrive.
    MikeyRedFL and danno266 like this.
  2. Jul 20, 2021 at 4:34 PM
    skullclown
    Steven
    North Carolina
    Mounted Baja Designs XL Sports (with amber rock guards) using SDHQ hood brackets.
    Ordered Switch Pro kit and Powertrays Universal mount along with blue sea systems block and bus bar to wire up soon.
  3. Jul 25, 2021 at 3:26 PM
    skullclown
    Steven
    North Carolina
    SDHQ Aluminum Battery Terminal Blocks installed, next up Switch Pros.
  4. Jul 28, 2021 at 1:02 PM
    skullclown
    Steven
    North Carolina
    Switch-Pro installed, opted to mount it on a piece of trim near steering wheel instead of the typical behind shifter.
    First accessory wired up are the Baja Designs XL Sport's attached to back of the hood with SDHQ brackets.
  5. Jul 29, 2021 at 11:15 AM
    skullclown
    Steven
    North Carolina
    Installed Yakima LockNLoad roof platform.
  6. Jul 31, 2021 at 12:23 PM
    skullclown
    Steven
    North Carolina
    JPB_VT and Black@Blue19 like this.
  7. Aug 4, 2021 at 7:25 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    ‘21 Nightshade Wind Chill Pearl
    Fox 2.5 Fox DSC front & rear Camburg UCAs Alcan leaf springs Kenwood 1037S HU OEM Audio Plus
    How do you like the Kenwood? I've got a new '21 Tundra coming and and think I'd like to swap that unit in.
  8. Aug 4, 2021 at 7:31 AM
    skullclown
    Steven
    North Carolina
    So far I'm loving the Kenwood, I did a lot of research and for the features I wanted (Wireless Carplay, large screen) it had great remarks including the screen being more responsive than other brands. The load up is a little on the slow side but not terrible, as far as settings go its very robust I had the local car audio shop tweak the settings for me to achieve some great results with the upgraded speakers I installed as well.
  9. Aug 4, 2021 at 9:16 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    Right on. Did you install yourself or the audio shop? I'm trying to figure out the correct install kit, maestro, etc. Not sure what I need entirely. Still researching.
  10. Aug 4, 2021 at 9:17 AM
    skullclown
    Steven
    North Carolina
    Did the install myself, Crutchfield will tell you everything you need and they ship quick if the items are in stock.
  11. Aug 4, 2021 at 9:20 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    Perfect, thanks again. Out of stock at Crutchfield's but in at Best Buy. I'll order all the accessories from Crutchfield.
  12. Aug 4, 2021 at 9:21 AM
    skullclown
    Steven
    North Carolina
    Yea I got the accessories from Crutchfield but the headunit from ABT since they had it in stock as well.
  13. Aug 4, 2021 at 9:57 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    The install kit on Crutchfield says it does not support bluetooth, satellite radio or nav. Do you think that's listed because they are provided directly the head unit?
    You have those functions?
    Sorry...for some reason I can't paste the link.
  14. Aug 4, 2021 at 10:40 AM
    skullclown
    Steven
    North Carolina
    As far as nav goes I just use the Carplay feature with my iphone (similar for android) to which provides navigation on the headunit as well, but the headunit comes with a GPS antenna which is said to be better than stock so I installed that and ran it to the middle speaker area of the dash (since I removed the middle speaker as well).
    Bluetooth you will have to run and install the included microphone, the stock bluetooth won't work with the new headunit.
    I don't bother with satellite radio but the Headunit does have Sirius built in so I think that works.
  15. Aug 4, 2021 at 10:59 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  16. Aug 4, 2021 at 11:09 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    Thanks again for all the info! My orders are in....and i'll have everything before my truck rolls in.
    I'm going to have some similar items to yours on my new ride as well: Stormtrooper, Fox 2.5 DSC coil-overs up front and 2.5 DSC in the rear. Debating a leaf spring replacement and researching that now. Will run my current Method Mesh 18" with 285/65R18 Wild Peaks for now. I'll move into 295/70R18 Wild Peaks next spring.
    I'll be adding a RTT next spring as well. Just had a kiddo this past December and will finally hit the trails again.
    It'll be a busy and fun fall working on the build!
    Cheers!
    skullclown[OP] likes this.
  17. Aug 4, 2021 at 11:11 AM
    skullclown
    Steven
    North Carolina
    No problem, you'll have a nice rig on your hands!
    I haven't had the desire to do any leaf spring replacements yet, maybe someday.
  18. Aug 5, 2021 at 12:01 AM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I’m having trouble tracking down your grill. Do you have a link? Beautiful truck…thanks for the inspiration!
  19. Aug 5, 2021 at 5:18 AM
    skullclown
    Steven
    North Carolina
    So my grille came off an XSP edition tundra, I was told that’s an east coast dealer special.
  20. Aug 5, 2021 at 9:29 AM
    #50
    swallace
    Steven
    Tri-Cities, WA
    Hmmm, I will have to do some digging. I can’t find it anywhere. Thank you.
  21. Aug 11, 2021 at 2:18 PM
    #51
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    I’m having the same issue, really need that grill and cannot find it. If anyone does plz forward a link. I’ve found other versions shown online but not nearly as cool as this one, and none ever for sale. Must have to buy used from an owner wanting to swap for a different grill.
  22. Aug 11, 2021 at 2:24 PM
    #52
    skullclown
    Steven
    North Carolina
    Yea this grille wasn't something you could buy/order, came on trucks and I got lucky to find someone who wanted the TRD Pro grille instead so they just resold it ($100 too!) ;)
  23. Aug 11, 2021 at 2:33 PM
    #53
    adamreinhardt
    Seattle
    Damn. Well I’m on the hunt regardless. I’ll find it if it kills me! The fam swears they don’t like either Pro grill, and I have a black platinum. As I remove anything not black, that grill sticks out. I’ve thought of plastidip but not sure I’ve seen one I’m actually impressed with, looks cheap. Hoping someone proves me wrong cuz that’s an easy job
  24. Aug 11, 2021 at 3:31 PM
    #54
    swallace
    Steven
    Tri-Cities, WA
    I talked to Sparks parts. They said it is not available to purchase. :(
  25. Aug 11, 2021 at 6:43 PM
    #55
    skullclown
    Steven
    North Carolina
    You'd be surprised how well plastidip holds up, I did my rear bumper and its taken over 2yrs to start showing signs of wear, but I have ordered a C4 rear to replace that so I wont' bother replastidipping ;)
  26. Aug 15, 2021 at 4:09 PM
    #56
    skullclown
    Steven
    North Carolina
    Got the new (to me, from @CorsoTundra) C4 overlanding bumper (with lightbar cutout) mounted up with an S8 Amber driving/combo lightbar and rigid 6" drive lights
    300BLK and Punisher29073 like this.
  27. Aug 17, 2021 at 8:32 AM
    #57
    skullclown
    Steven
    North Carolina
    Installed black chrome exhaust tip
  28. Aug 17, 2021 at 5:55 PM
    #58
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Nice build! I'm in Huntersville, maybe I'll bump into you sometime around town.
  29. Aug 17, 2021 at 6:09 PM
    #59
    skullclown
    Steven
    North Carolina
    You'll know when you see my truck, its hard to miss ;)
  30. Aug 17, 2021 at 6:21 PM
    #60
    Charvonia Design
    Keith
    Huntersville, NC
    I'm in a blue Lexus ISF or a white FJ60 these days.
