Tundra TRD Skid Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tyrw1963$, Jul 29, 2021.
  1. Jul 29, 2021 at 6:51 PM
    Tyrw1963$
    Tyrw1963$ [OP] New Member
    Robert
    Tundra
    Sway bars,skid plate, wheels and tires,graphics
    Confirmed application/fit for 2014 Tundra Double Cab. The only reason the skid plate is not listed for earlier gen 3 Tundras is item was introduced to the market later. Everything lined up perfectly with no modifications. Also, I have shackles and d rings using my factory bolts which incidentally are long enough to secure them. First, secure the skid plate (tighten down). Then, install the d rings. Expect to apply a little muscle. I installed mine on the ground with no jack or ramps. So, GO FOR IT! No regrets here.
  2. Jul 30, 2021 at 5:13 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    As an FYI, make sure you put some rubber gasket material between the plate and where it touches the frame. Otherwise, it will make noise. Honestly, its a shitty design…I have one and have had to fight with this issue as have others…there is a thread on here that spells all this out.
  3. Jul 30, 2021 at 6:33 AM
    Master Chief 20
    Master Chief 20 New Member
    Eddie
    21 Tundra Limited TRD
    I just added a few washers to each bolt. Problem solved!
  4. Jul 31, 2021 at 11:32 AM
    Welcome from NY.
