Is a Limited fender the same as a Double Cab fender?
Discussion in '1st Gen Tundras (2000-2006)' started by toyota_fan, Jul 29, 2021.
  1. Jul 29, 2021 at 6:44 PM
    toyota_fan
    toyota_fan [OP] New Member
    Missoula, MT
    2006 Tundra SR5 Double Cab 4.7 Liter V8
    Are the Limited fenders' the same as the Double Cab fenders'?
    I have car-part.com set to search for parts for my 2006 Toyota Tundra SR5 Double Cab by VIN, and a fender is showing up from one salvage yard described as "4 DR,LIMITED,BLACK".
  2. Jul 29, 2021 at 6:46 PM
    18" TRD Off Road Wheels
    Limited has nothing to do with body shape. It's a trim like SR5 or SR.
  3. Jul 29, 2021 at 6:50 PM
    toyota_fan
    Missoula, MT
    @AzureNightmare So does that mean the fenders for the Limited are intechangable with the Double Cabs'?
    Sorry. I understand trim levels. Just wanting to make sure the limited trim level of Double Cab fender, will fit an SR5 Double cab.
    GODZILLA likes this.
  4. Jul 29, 2021 at 6:52 PM
    My point is that Limited has nothing to do with the fenders in anyway. The only way it would tell you is if a certain trim were exclusive to the cab type. It's akin to asking if an SR5 fender will fit a double cab. Well, was the SR5 a double cab or a single cab or an access cab. Trim doesn't affect it in anyway.
  5. Jul 29, 2021 at 6:52 PM
    See post #2 or #4
  6. Jul 29, 2021 at 6:55 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Double cab fenders are double cab fenders. As @AzureNightmare said, SR5 and Limited are trims. The main exterior difference between SR5 and Limited is the latter has color matched bumpers and mirrors.
    SR5 Double Cab:
    Limited Double Cab:
    Darkness, GODZILLA and toyota_fan[OP] like this.
  7. Jul 29, 2021 at 6:55 PM
    toyota_fan
    Missoula, MT
    @AzureNightmare Thank you. Please forgive my tiredness, and not wanting to pay for a part, just to find out it won't fit after driving to pick it up
    Darkness and GODZILLA like this.
  8. Jul 29, 2021 at 6:57 PM
    No apology needed. We all have our days.
    I'd contact whoever has that part and ask if it came of an access cab or a double cab.
  9. Jul 30, 2021 at 4:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As others mentioned, Limited is a trim. For a time I would get confused when figuring out parts for AC, DC, SR5....etc but became clearer when looking at what was offered in their brochures. While it can still be daunting when searching parts, with a veh VIN, it does become much clearer. If car-part.com does indeed show VIN, I would use that info at McGeorge Toyota for example to then check fender part numbers.
    this may or may not help explain....
    toyota_fan[OP], des2mtn and Darkness like this.
  10. Jul 30, 2021 at 4:59 AM
    Sir we don't have an "sr" trim here in first gen paradise. I need you to take your land yacht elsewhere.
  11. Jul 30, 2021 at 5:08 AM
    :rofl::rofl::rofl:
    Ok, boomer. :boink:
    I guess you guys had Tundra Grade or some such?
    Darkness and bmf4069[QUOTED] like this.
  12. Jul 30, 2021 at 5:10 AM
    Back in my day we called it base model. We didn't need to hide the fact it was base.
    Darkness and GODZILLA[QUOTED] like this.
  13. Jul 30, 2021 at 5:12 AM
    This is how I picture you saying "base" just FYI.
    Enjoy the earworm
  14. Jul 30, 2021 at 5:20 AM
    What's the point of a land yacht if you can't cruise it into paradise once in a while? o_O
    bmf4069[QUOTED] and Darkness like this.
  15. Jul 30, 2021 at 8:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh DAMN YOU!
    bmf4069 and GODZILLA[QUOTED] like this.
  16. Jul 30, 2021 at 10:06 AM
    I disagree. The limited-edition anniversary Fender strat is curvy while their double cab 2x12 twin reverb amp is somewhat boxy.
    Darkness likes this.
  17. Jul 30, 2021 at 10:58 AM
    But I am all about that bass:
    GODZILLA[QUOTED] and Darkness like this.
  18. Jul 30, 2021 at 12:51 PM
    If the fender you're buying is a limited and your truck is a base model, then the fender flare may be different. Some fender flares have mounting holes behind them, which your fender may not. So removing a non matching flare may not be a good option. Thus is true for the AC models, can anyone confirm for the DC?
  19. Jul 30, 2021 at 12:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I believe that only matters for access cab. Double cab I think are all the same.
  20. Jul 30, 2021 at 1:01 PM
  21. Jul 30, 2021 at 1:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Well I'll be damned. I've never seen a DC without the flares on. Thats part of why I don't like their style, I might have to change my mind about that.
