Knock/Tick
Discussion in '2.5 Gen Tundras (2014-2021)' started by stroakes, Jul 29, 2021.
  1. Jul 29, 2021 at 12:20 PM
    stroakes
    stroakes [OP] New Member
    At a cold start my tundra sounds fine. But after about 10 ten minutes of idling it starts making a knocking or a ticking on the drivers side. I can drive a couples miles down the road and it will disappear? The tundra is 2015 sr5 with only 54,000 miles. https://youtube.com/shorts/xscntqU32iY?feature=share
    RdKing likes this.
  2. Jul 29, 2021 at 12:47 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    How's the oil level? and are you still under warranty?
  3. Jul 29, 2021 at 12:57 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
  4. Jul 29, 2021 at 1:37 PM
    2mchfun
    Welcome from OKC! Oil viscosity??
  5. Jul 29, 2021 at 2:34 PM
    stroakes
    Oil level is good unfortunately it isn’t under warranty.
  6. Jul 29, 2021 at 2:37 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe try some 5w-30 in it. But I have heard of timing chain tensioner‘s and or valve spring failures. Let’s hope you just need some thicker oil
    2mchfun likes this.
  7. Jul 29, 2021 at 2:39 PM
    2mchfun
    Definitely not sounding good, what oil you been using? Sounds like some really poor lubrication.
  8. Jul 29, 2021 at 2:49 PM
    stroakes
    Mobil 1 0w-20.
  9. Jul 29, 2021 at 2:54 PM
    2mchfun
    I'd run a can of seafoam in it for thirty minutes and then drain it. Change filter, fill it up with quaker state SAE 30. See what happens. At this point you gotta do something soon.
    frichco228 and 15whtrd like this.
  10. Jul 29, 2021 at 2:58 PM
    2mchfun
    If seafoam cleaning up and thick oil does not quiet it down, I believe it is going to require removing the valve cover to get a look.
  11. Jul 29, 2021 at 3:00 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Likely the primary timing chain tensioner on the driver side
    2mchfun likes this.
  12. Jul 29, 2021 at 3:05 PM
    2mchfun
    Timing chain tensioner wasted at less than 60k? Why?? Oil change interval?
  13. Jul 29, 2021 at 3:18 PM
    ViktorG
    Viktor
    Calgary, Canada
    No, very common problem, faulty design
    2mchfun[QUOTED] likes this.
  14. Jul 29, 2021 at 3:47 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    What gas do you use?
  15. Jul 29, 2021 at 11:21 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Heaver oil. Run 5w30 in the winter and up to 15w40 in the summer. Its night and day with engine noise. 0w20 is simply to comply with CAFE standards our engines can handle up to 20w50 oil.
