tailgate insert letters removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by justcuz, Jul 28, 2021.
  1. Jul 28, 2021 at 9:50 AM
    justcuz
    justcuz [OP] 2.5 Gen Member
    My truck has the stainless ones on it now and I would like to remove them and put matte black
    tailgate insert letters on.
    what is the best way to remove the existing recessed letters?
  2. Jul 28, 2021 at 10:00 AM
    RobertD
    Robert
    DFW, Texas
    Heat and plastic tooling (goal is to loosen the bond without damaging the paint). You'll probably have to go back with some goo gone and remove any remaining residue and then clean the surface before applying the new inserts.
    justcuz[OP] likes this.
  3. Jul 28, 2021 at 10:06 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    biebs96 likes this.
  4. Jul 28, 2021 at 10:39 AM
    Rerun
    Rerun New Member
    Rick
    Tucson AZ
    2019 Crewmax Limited TRD 4x4 white
    I used a hair dryer and fishing line(50lb) and they came right off. Goo gone and alcohol on the residual.
    Gravy and Saltyhero13 like this.
  5. Jul 28, 2021 at 12:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This. Don’t pull up on the line if you use this method. Take care not to overheat the paint if you use the heat gun.
    It’s almost unnecessary to use the heat gun in most situations, though older applications or certain adhesives may require one. If you can get the Goo Gone worked in behind the badge/letters it can do the heavy lifting on its own using the line in a sawing motion. I used an eraser wheel to remove any excess glue. Make sure the surrounding area is clean before using the wheel. The wheel itself won’t damage healthy paint but a dirty panel will.
  6. Jul 29, 2021 at 8:15 PM
    Bentarm13
    Bentarm13 New Member
    Hair dryer at best, dental floss or fishing line. Don’t scissor down, try and use constant downward pressure, less chance of damaging paint. Go slow and make it work without much resistance. Goof off and alcohol (for truck and you!) after.
