Question about the aluminum engine oil filter cap
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Jul 28, 2021.
  1. Jul 28, 2021 at 9:08 PM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    So our Tundras come with a plastic oil filter housing cap. Toyota uses an aluminum version of this same cap on other vehicles as I understand it, and the part is identical to our plastic cap except for the material and the length of the filter mounting tube.
    My question is, do we know why Toyota uses the aluminum cap on some things but uses a plastic one on the Tundras?
  2. Jul 28, 2021 at 9:18 PM
    odymar
    odymar New Member
    Marcus
    21 SW CM SR5 4WD
    I don’t know why the metal one is used in some applications, but I always thought the idea behind the plastic housing was to create a weak point. Ideally, if you were to strip or cross thread, the plastic housing would be the damaged piece and easily replaced. If both sides of the coupling are the same material or strength, you could potentially damage the portion the housing screws in to.
    My Jeep uses a plastic filter housing and that was the reasoning I found for that application.
    coldcanuk likes this.
  3. Jul 28, 2021 at 9:24 PM
    PA452
    The first vehicle I ever saw that used an element instead of a canister filter was a 2004 Saturn. Now that you mention it, that thing used a plastic cap on an aluminum housing too; accessible from the top though and the cap went on top. Still strikes me as a silly reason to use plastic, but I guess that's possible. Something like that should be pretty hard to strip or cross-thread unless you're really being careless.
    And honestly I feel like the plastic cap on that Saturn was made of better plastic than the one on the Tundra sadly.
  4. Jul 28, 2021 at 9:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Dunno. I had 150k trouble free miles on my ‘08 with the plastic cap, then switched to the aluminum one and had another 150k trouble free miles with it.
    I’m not in a hurry to swap out the plastic one on my ‘21, but might do it if I run out of other mods to do. :notsure:
    WILLINH and Ely010606 like this.
  5. Jul 28, 2021 at 10:01 PM
    PA452
    I had a plastic cap fracture on my '18. It was my fault. I was using a torque wrench I wasn't used to, never felt the click and went way too far. Then backed it off when I realized it, torqued it again. Looked fine. Started the engine and heard oil gushing everywhere. Had to race to a Toyota dealer about an hour away to get a new one. Thankfully I was able to get there within about 15 minutes of their closing time.
    As a result of that experience, I bought the aluminum cap and will change it on the first oil change on my '21.
    Ely010606 likes this.
  6. Jul 28, 2021 at 11:03 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I decided to change it also. I already purchased it and the Valvomax quick twist valve. I have a couple more freebies and after that I will be doing all my oil changes.
  7. Jul 29, 2021 at 9:06 AM
    2mchfun
    They use plastic because when buying tens of thousands the cost savings is quite significant.
    15whtrd and AZBoatHauler like this.
  8. Jul 29, 2021 at 9:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    "A plastic filter cap is used for weight reduction." LOL
    15whtrd likes this.
  9. Jul 29, 2021 at 11:05 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    What document is this from? Can I get access to it?
  10. Jul 29, 2021 at 11:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not sure if it's from a service manual or not. I found it on the Internet some years ago.
  11. Jul 29, 2021 at 12:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes, it's an excerpt from the Factory Service Manual.
    Wynnded[QUOTED] likes this.
  12. Jul 29, 2021 at 12:10 PM
    AZBoatHauler
    So.Arizona
    Having held both, I can tell you there isn’t more than a couple ounces difference. You’d save more weight by going pee before getting in.
    TTund16, Bakershack, 2mchfun and 3 others like this.
  13. Jul 29, 2021 at 4:20 PM
    PA452
    Wow...
  14. Jul 29, 2021 at 5:27 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    They should make the front skid plate out of plastic! That would save some weight!
