33 inch tires rubbing with a 3/2 lift and offset rims.
Discussion in 'Wheels & Tires' started by Matguy34, Jul 28, 2021.
  1. Jul 28, 2021 at 9:31 PM
    Matguy34
    Matguy34 [OP] New Member
    Just installed the ready lift 3/2 levelling kit and was a little disappointed that my tires rub. Truck looks great but still kinda choked. Any simple solutions besides cutting or getting smaller tires? Maybe my offset sticks out too far?
  2. Jul 28, 2021 at 9:34 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
  3. Jul 28, 2021 at 9:57 PM
    Matguy34
    Thanks. I’ll look into it. I’m loving the truck so far. I’ve had lots of comments on the 1794 leather. Nicest truck I’ve ever had and I’ve had lots.
    GIN•OKUMA likes this.
  4. Jul 28, 2021 at 10:08 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    1) where are you rubbing?
    2) Rub in reverse only or also in drive?
    3) what is the offset of your wheels?
    joseph_womack and GODZILLA like this.
  5. Jul 29, 2021 at 4:26 AM
    PAlittlematty
    PAlittlematty New Member
    Central PA
    2021 CrewMax TRD OR
    Hammer…
  6. Jul 29, 2021 at 4:45 AM
    18" TRD Off Road Wheels
    ^^^This.
    @Matguy34 We need more info to be able to assist effectively. Also, what size are your tires? I saw that they are 33", but are they 275/70R18, are they 33x12x20, etc.? Need the full tire size info to get an accurate idea of the rub issue.
    joseph_womack likes this.
  7. Jul 29, 2021 at 4:46 AM
    Loose
    Loose New Member
    2020 Platnium
    check with an alignment specialist first. They were telling me I needed a BMC and I adjusted the caster and that fixed the problem.
    joseph_womack and bflooks like this.
  8. Jul 29, 2021 at 4:54 AM
    33" tires (so long as they aren't super wide) should not need an alignment to fit. My guess is that the tires are either significantly wider than stock as well as taller, or that the lower offset of the aftermarket wheels are the source of the rub.
    For example, I'm have stock suspension with 275/70R18 (discount tire measures these as a little large at 33.43") tires on +25mm wheels and I have some minor rubbing. I had to remove the front air dam/splash guard under the bumper. After that I only have a little rub on the mud flaps if I reverse and turn more than about 75%. A little heat to mold the flaps, or trimming them and I'd be golden. My guess is that OP has a lower offset and it's causing additional rubbing, or that the air dam/splash guard under the bumper hasn't been removed.
  9. Jul 29, 2021 at 4:57 AM
    War Machine
    War Machine SSEM # 5 3MW
    What’s your offset? I had a 3/2 and 33” tires with no issues. I only had to do a BMC when I went to 35”. The wheels I have on that truck have a +1 offset.
  10. Jul 29, 2021 at 5:22 AM
    Loose
    Loose New Member
    2020 Platnium
    I have 295/60/20 (34x11.5) on a fuel wheel with +20 offset on a 3 inch pro-comp lift
    BlueSpartan1597 likes this.
  11. Jul 29, 2021 at 5:56 AM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    I have 305/55 on 20's with +20 offset on stock suspension. Minimal rubbing in reverse full lock
  12. Jul 29, 2021 at 6:15 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    as many others have asked; what is the offset on those wheels? i am guessing it is near zero.
    i fit 34" tires with minimal plastic trimming, but i also went with a wheel with +20 offset.
    here is what i did to eliminate any rubbing:
    Trimming front bumper liner and mudflaps | Toyota Tundra Forum (tundras.com)
  13. Jul 29, 2021 at 6:23 AM
    timsp8
    NY
    Need answers to the questions asked above. Stock tires are about 32”, so your 33” tires are only 1/2” taller on top and 1/2” on bottom. They should easily fit with no lift. Like others asked, what’s the offset and tire width?
    Wahayes likes this.
  14. Jul 29, 2021 at 6:35 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I went from stock to LT275/70r18 on stock suspension and no rubs anywhere. Added Bilstein 5100’s up front set to the lowest lift, just under an inch, got rubbing on stock skid plate. Installed the RCI skid, no more rubbing. So in addition to the suggestions above, I’d check the skid plate too.
  15. Jul 29, 2021 at 9:11 AM
    Matguy34
    Rubbing on the plastic insert inside the front bumper. -24 offset rims. 275/70/18. 33.2 inch tires. Very minimal rub but still annoying. I think it only rubs turning in reverse but I’ll have to test that later on today.
    GODZILLA likes this.
  16. Jul 29, 2021 at 9:14 AM
    Matguy34
  17. Jul 29, 2021 at 9:16 AM
    timsp8
    NY
    GODZILLA and Loose like this.
  18. Jul 29, 2021 at 9:26 AM
    Looking at the pics, the bumper shims will take care of it. Yes, you can install the shims by doing one side at a time and you do not have to remove the bumper.
  19. Jul 29, 2021 at 10:28 AM
    Matguy34
    Update. After another drive I’ve noticed it rubs slightly when turning but way worse in reverse
  20. Jul 29, 2021 at 1:06 PM
    BayRunner
    As others have said, the coach builder bumper shims will give you an additional 1/2” clearance.
  21. Jul 29, 2021 at 1:37 PM
    Solid info. As others said, that -24 offset is what's getting you. For that size tire your sweet spot would be a +20 to +30 offset. Trimming, bumpers shims, or wheels that don't poke as much are your options.
  22. Jul 31, 2021 at 6:35 PM
    Matguy34
    I just found out the tires are +0 offset. They barely rub but it’s embarrassing loud in reverse. Going to try the bumper ships this week
  23. Jul 31, 2021 at 6:46 PM
    Ry24000
    Ry24000 New Member
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Remove the bolts that hold the plastic liner on at the front bumper. Push the liner in and redrill some holes. Push the liner in and bolt it down. That's what I did and problem solved. For the rear you may need to remove the mud flaps.
    Gravy likes this.
