radio head compatibility
Discussion in '1st Gen Tundras (2000-2006)' started by napa2u, Jul 28, 2021.
  1. Jul 28, 2021 at 5:07 PM
    napa2u
    napa2u [OP] New Member
    Barry
    napa, ca.
    2000 Toyota Tundra Limited
    anyone know if a 2006 radio head is interchangeable with my 2000 tundra?
    Barry
  2. Jul 28, 2021 at 5:53 PM
    I’d be surprised if it didn’t. The harness might not be identical, but you should be able to make it work if your using the amp within the head unit itself.
  3. Jul 28, 2021 at 6:09 PM
    napa2u
    Barry
    napa, ca.
    well Jack, thats my thought. Its not a good pic from the seller but ive asked for pics front and back. i put an aftermarket in but still have the original
  4. Jul 28, 2021 at 6:25 PM
    Hopefully someone with a wiring diagram of their 2006 head unit will chime in to confirm.
  5. Jul 28, 2021 at 7:02 PM
    We've had guys here even able to swap in 201x model head units into their 1st gen. @Darkness aren't you one?
    Toyota hasn't changed a ton on the main harnesses. Tacoma and Tundra even share some misc plastic parts inside and out.
    Jack McCarthy likes this.
  6. Jul 28, 2021 at 7:12 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not me, Alpine since 2009. @empty_lord has a pretty new radio from the 86.
    It should be interchangeable but you'll want to be sure it is the same arrangement. Some have an amp in the back of the cab, some have an amp behind the hvac controls. Some might not have an amp.
  7. Jul 28, 2021 at 7:15 PM
    Good points. And yep it's EL with, I think, a 2018 model radio in his, full bluetooth and all that.
    I wouldn't be worried about things swapping in from the same generation. You may need trim pieces to shim. Steering wheel controls won't work in a 2000-2001 (maybe 2003), but I'm almost certain the main harness is the same, but agree to check whether the source vehicle was a 4 speaker or 6+ speaker setup to know if it had an amp. May (?) be a factor.
    Darkness[QUOTED] likes this.
  8. Jul 28, 2021 at 7:29 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Unit will plug in and work. But you will need an 03-04 radio bezel. The 00-02 bezel only fits the narrower radios (true double din)
    Darkness and KNABORES like this.
  9. Jul 28, 2021 at 7:55 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I dunno about compatibility but "Pablo Honey" was a damned fine album.
    Darkness, jimf909 and shifty` like this.
  10. Jul 28, 2021 at 8:23 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    ^^^ There. If you didn't I was going to. Thom Yorke seems like a Gen 1 dude.
    Darkness likes this.
  11. Jul 28, 2021 at 8:31 PM
    Radiohead requires big fans for compatibility. Mine is only a small fan, so not really compatible.
  12. Jul 28, 2021 at 9:25 PM
    napa2u
    Barry
    napa, ca.
    Some really good info……..some haha’s……..all good. Thank you all for your quick and informative responses.
    Barry
