2016 Tundra Crew TRD
Discussion in 'Wheels & Tires' started by ohiocamper131, Jul 26, 2021.
  1. Jul 26, 2021 at 8:29 AM
    ohiocamper131
    ohiocamper131 [OP] New Member
    2016 Tundra TRD Crewmax
    Current tires Michelin LTX A/T2 P275/65R18 114T
    Currently pull travel trailer 4,000lbs - looking to upgrade trailer to 5,500-6,000lbs
    Need to replace current tires, what's recommended for daily drive and towing 4-5 times a year. I have read the sidewall rating needs to improve from current factory tires
    * I like the "look" of current tires
    TIA!
  2. Jul 26, 2021 at 10:16 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    I tow 8,000# Arctic Fox that has 1k tounge weight with same tire in 20" and have been all over country, works great and no problem. I can't remember tire capacity but stamped on side wall along with max PSI.
    ohiocamper131[OP] likes this.
  3. Jul 26, 2021 at 5:45 PM
    TundraRich
    TundraRich New Member
    Rich
    2018 Tundra Limited 4x4 Crewmax TRD off road package
    None
    Hey Kfrog,
    What’s the length of your Trailier …. I’m looking at a flagstaff 30 footer 6800 lbs dry 8k full capacity. Any tips or tricks would be much appreciated, first time hauler
    Thanks
    Tundra Rich
  4. Jul 27, 2021 at 3:04 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Stock size tires in standard load handle the loads the Tundra can tow and haul just fine. I would recommend you look at michelin defender, vs the At2 it is a better tire than their AT. They are great riding, good in snow and can even handle some mild off road use.
    If you want to move to E load tires, 275/75-18 size will fit a stock truck no issues and there are a ton of AT or regular all season tires available in that size.
