Does anyone's do this on startup?
Discussion in '2.5 Gen Tundras (2014-2021)' started by crewmaxlmt, Jul 26, 2021.
  1. Jul 26, 2021 at 11:32 AM
    crewmaxlmt
    crewmaxlmt [OP] How dare you!
    scott
    2020 Crewmax Limited
    My 2014 never did.
    Rica25 likes this.
  2. Jul 26, 2021 at 11:37 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  3. Jul 26, 2021 at 11:39 AM
    Kanobi13
    Kanobi13 New Member
    No idea i remote start mine so never in vehicle when it starts good luck
    Rica25 likes this.
  4. Jul 26, 2021 at 11:49 AM
    Taco-Spike
    Two Trucks
  5. Jul 26, 2021 at 11:50 AM
    crewmaxlmt
    scott
    It's not the message. The video is of the steering wheel twitching. Sometimes it does not move and other times it moves much more than the video.
  6. Jul 26, 2021 at 11:54 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I have it happen before but never really thought anything of it. I just figured it has something to do with the power steering pump when priming or pressurizing itself.
  7. Jul 26, 2021 at 12:33 PM
    crewmaxlmt
    scott
    Do you get much feedback through your steering wheel from rough roads or bumps?
  8. Jul 26, 2021 at 12:54 PM
    crewmaxlmt
    scott
    I bought my 2014 used with a spacer leveling kit on it and I never had feedback like I do now. I talked to the dealership about it but it's tough to make a steering claim to them when you are running 35's.
  9. Jul 26, 2021 at 1:00 PM
    biebs96
    PA
    That might be a steering angle sensor issue
  10. Jul 26, 2021 at 1:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's simply tension to the steering. When you start the engine and the pump runs, that adds assistance to the system and it's just finding it's neutral relaxed position.
    Black Wolf and Tundratoofun like this.
  11. Jul 26, 2021 at 1:06 PM
    crewmaxlmt
    scott
    Possibly. It will do it at times when I backed straight in. I just hope that the road feedback that I am feeling is not tied to a problem with the steering rack.
  12. Jul 26, 2021 at 9:29 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Haven't noticed that on mine.
    I don't know if this would do it or not, but are you buy chance turning the wheel or applying some pressure when you shut it down?
  13. Jul 27, 2021 at 4:44 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    How do you keep it running when you get in it? Or did you aftermarket remote start it?
  14. Jul 27, 2021 at 5:50 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Happens to me sometimes when the steering wheel is turned slightly before starting.
    Probably happens also when using remote start so by the time you start it again after you get in the truck the wheel is already straight.
    Oey12 likes this.
  15. Jul 27, 2021 at 6:17 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    You have a ghost driver that like to driver your truck.
  16. Jul 27, 2021 at 6:20 AM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    Maybe steering fluid is low? Mine has never but it's the first truck I've had with hydro steering. That's my 1st guess. 2nd guess is a broken engine mount, it might shake the front of the truck so bad at startup that wheels wiggle slightly? Again these are just wild guesses from me, I'm no mechanic.
  17. Jul 27, 2021 at 6:56 AM
    crewmaxlmt
    scott
    No. Not at all.
  18. Jul 27, 2021 at 12:26 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I have never seen that at startup…
  19. Jul 27, 2021 at 1:34 PM
    Californate
    Californate New Member
    2019 Cement Limited Crewmax
    You try unplugging it and plugging it back in again? /s haha.
    but nah, I’ve only seen that happen on a friends Jetta.
