Problem with fog lights blowing fuse
Discussion in 'Lighting' started by DVCNick, Jul 26, 2021.
  1. Jul 26, 2021 at 7:00 AM
    DVCNick
    DVCNick [OP] New Member
    2011 5.7 4x4 Double Cab
    Hey all,
    I don't think of myself as a total dunce with electricity, so this has me a little confused and embarrassed, but I can't seem to figure this out...
    2011 truck with fog lights. The stock ones worked fine.
    I removed them and replaced with S2 Pro's. Now any time I flip the factory switch to turn them on, the fuse instantly blows. I didn't change anything about the wiring except just replaced the stock bulb housing with the S2. S2s should draw less current so the stock fuse should be more than enough. It is almost like I created a short somewhere, but I really don't think it is in my splicing... any thoughts would be appreciated. TIA.
  2. Jul 26, 2021 at 7:02 AM
    DVCNick
    Also of note, using the Baha Designs supplied wiring harness and connecting straight to a battery, the lights turn on and off with no issues so they seem fine to me based on that.
  3. Jul 26, 2021 at 7:03 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you wire them up backwards? This is a common issue with splicing in aftermarket fogs. Try reversing the polarity, or better idea, put a multimeter on the leads so you know for sure which wire is which.
    KK6PD and AZBoatHauler like this.
  4. Jul 26, 2021 at 7:10 AM
    DVCNick
    I believe I confirmed that before (It has actually been a little while since I did this and I got distracted with a different car, but coming back to this now). I will double check that, thanks.
  5. Jul 26, 2021 at 7:29 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'd also disconnect one and/or the other and see if the problem persists with both lights individually.
    DVCNick[OP] likes this.
  6. Jul 27, 2021 at 8:06 AM
    DVCNick
    Sure enough... I just "assumed" that "A" was positive, but connected the supplied wiring harness back up and sure enough "B" is positive... I had both wired backwards. Swapped the connectors around and now they light up like a champ.
    Dunce status confirmed... thanks guys.
    KK6PD and TRDFerguson[QUOTED] like this.
  7. Jul 27, 2021 at 8:17 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s an easy mistake to make. Glad you were able to get it sorted out!
