Best fuel injector cleaner?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fish River Tundra, Jul 26, 2021.
  1. Jul 26, 2021 at 9:35 PM
    Fish River Tundra
    Fish River Tundra [OP] New Member
    JD
    Nashville
    ‘16 Platinum
    Hi Guys and Gals-
    Was wondering what everyone uses. Am leaning towards Lucas products at the moment? This is my first Toyota, but have had good luck with the clog removing power of drano in the past.
    Metro14536 and Rica25 like this.
  2. Jul 26, 2021 at 9:44 PM
    Rica25
    Ricardo
    Tulare
    I've used BG product 44k since about 2010 on Every Oil change but I always use chevron or shell fuel. My 2008 has 164k miles and no issues since new.
    HulkSmurf14 and Crunch527 like this.
  3. Jul 27, 2021 at 12:35 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    This…
    Rica25[QUOTED] likes this.
  4. Jul 27, 2021 at 1:32 AM
    justcuz
    justcuz 2.5 Gen Member
  5. Jul 27, 2021 at 3:22 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I agree with Rica25. Plus, a Shell engineer recommended BG 44K Platinum as the best. I would assume a Shell engineer who determines the additives that go into Shell gas would know. I follow his advice.
    Rica25 likes this.
  6. Jul 27, 2021 at 3:39 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2, BG 44K is a top of the line ( cleaner) , and rather expensive. Seafoam cleans and lubricates whereas BG 44K specifically cleans. Your Tundra will love you using either one:D
    Dc2015 and Rica25 like this.
  7. Jul 27, 2021 at 3:43 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Checking Project Farm - the definitive source ....
    survey says!....
    they are all about the same.
    fairclothr1, Barrett50 and Rica25 like this.
  8. Jul 27, 2021 at 5:47 AM
    bft305
    bft305 New Member
    2016 tundra limited
    I use B12 Chemtool, it is cheap usually under $4 and works great!
  9. Jul 27, 2021 at 6:05 AM
    trails-end
    trails-end New Member
    NWGA
    2021 Tundra SR5 4x4 crewmax trail white
    TRD antisway bars front and rear.
    Research Techron vs the others. My research has led me to believe it actually does what the others only claim to do. YMWV
    WILLINH and Rica25 like this.
  10. Jul 27, 2021 at 6:15 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Nothing but Chevron fuel goes into my Toyota, WS6 and Acura. Always been and always will.
    Best Damn gas you can get.
    There's a reason every auto manufacturer uses it for testing for the EPA.
    The WS6 has 160K on her and that engine is tight (2000).
    I have a rule I use when I think of using cleaners.
    If you think your engine needs it, pull the injector(s) and get new ones then change the fuel your using.
    A good high speed run on the freeway for an hour or so does wonders for carbon elimination.
    k0diak8o8 and Rica25 like this.
  11. Jul 27, 2021 at 6:31 AM
    Rica25
    Ricardo
    Tulare
    I have also always used the BG additive for my oil on every oil change.
  12. Jul 27, 2021 at 6:39 AM
    trails-end
    NWGA
    Chevron owns Techron and adds it to their fuel.
    Rica25 likes this.
  13. Jul 27, 2021 at 6:46 AM
    Nowhereman
    Al
    Monterey Bay area
    Yes they do and it works so why buy more additives?
  14. Jul 27, 2021 at 7:00 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll keep it a secret that all gas is the same.
    Chevron, when it gets picked up at various truck filling units, adds a unit of techron. very dilute.
    Any tier 1 gas is GTG.
    Costco performs nicely.
    I had Costco 93 octane gas when my Harrop was installed & dyno'd. no knock detected.
    YMMV.
    For the record, I add a bottle of techron every blue moon. to ward off any demons.
    sd172, TheBeast, KatoK and 2 others like this.
  15. Jul 27, 2021 at 7:19 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    You shouldn't need any cleaning additives As long as you are using "top tier" fuel . Most of the time its the marketing for these products that puts the thoughts in peoples heads that their engines are all gummed up which is completely untrue
    Rica25 likes this.
  16. Jul 27, 2021 at 7:20 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    tru dat
    Rica25 likes this.
  17. Jul 27, 2021 at 7:44 AM
    2mchfun
    About every 25k, two cans of Berrymans chemtool in about 15-20 gallons of gas, 1 hour on the highway at about 80, then just run it down under normal conditions. Never had a fuel injector problem here in more than 1.5 million miles of travel. PCV catch can keeps the intake valves nice and clean too. Always run 100% pure top tier gasoline if possible, usually possible.
    Rica25 likes this.
  18. Jul 27, 2021 at 7:51 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I too use Lucas oil, and have for years. I have someone very close to me that has worked at the headquarters in Corona, Ca for many years, and he is fully committed. He says they are so passionate about there product and research, I guess it's just a matter of preference. I am sure there are many great products and beliefs, you just gotta pick yours.
    Rica25 and Metro14536 like this.
  19. Jul 27, 2021 at 8:22 AM
    jordoncloutier
    Jordon
    Alberta , Canada
    Agreed , a good highway run , or towing at highway speeds is a good way to clean out those catalytic converters.
    On the other hand , On port injected engines the fuel injector is constantly cleaning the intake valves , Installing a PCV catch cans are a waste of money on a naturally aspirated engine.
    Rica25 likes this.
  20. Jul 27, 2021 at 8:43 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I have never seen a fuel injector problem on any car 2000+. Older 90's stuff, yes. The best advice for maintaining a clean fuel system is purchasing fuel from high turnover gas stations, like Costco for instance. There is a Costco by me that receives 2-3 double tanker loads of fuel per day so you can be sure that the fuel is fresh and the tanks are clean.
    What brand of fuel you use does not matter. I learned from a tanker driver years ago, Chevron, Shell, Costco, or whoever; they all get their fuel from the same place. That place is whoever has the 87, 89, or 92 that day. But yeah, places like Chevron do dump a bucket of additive into there tanker when they fill their trucks up.
  21. Jul 27, 2021 at 8:43 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Techron every May and October, that's about every 11,000 and top tier gas.
  22. Jul 27, 2021 at 9:08 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Asmoil P.i. Additive but I'm thinking of trying BG products.
    Wallygator, Rica25 and lewi3069 like this.
  23. Jul 27, 2021 at 9:21 AM
    Fishhead
    Fishhead New Member
    I use Chevron techron the tank of gas before I do an oil change. No reason why other than it helps me remember to do it at the same interval.
    Also…I only run top tier gasoline.
    Rica25 and WILLINH like this.
  24. Jul 27, 2021 at 10:30 AM
    Nowhereman
    Al
    Monterey Bay area
    Here's a site where you can buy Techron in large quantities.
    You can calculate if it's financially profitable for you to make your own Chevron gas.
    Just go to Amazon, they sell just about any quantity you want.
    Comes out around $10.66 a bottle though in six packs.
    I wouldn't use a bottle every fill up but you could do half a bottle every fill up.
    Rica25 likes this.
  25. Jul 27, 2021 at 10:41 AM
    Nowhereman
    Al
    Monterey Bay area
    I use Lucas products in my Harleys.
    Rica25 likes this.
  26. Jul 27, 2021 at 10:54 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Use good quality fuel consistently and you don't need it. Top Tier is nice if you can find it. Otherwise I try to use fuel stations that are always busy so I know fuel hasn't been setting in the tanks a long time or haven't been contaminated somehow. I use a Dillon's store (Kroger) nearby On the road, I look for busy stations like truck stops. Don't care if it is a couple cents more. The Dillon's is the busiest station near me and I know if there is problem with their fuel, so many people would be affected it would be shut down pronto until it is fixed.
    Rica25 likes this.
  27. Jul 27, 2021 at 10:57 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I go thru a couple of tanks of E85 at about 500 miles before my oil changes. It's cheaper then a gas fillup and WooHoo to the Horse Power!! The byproduct being a cleaner steam type even helps clean the black soot out of the tailpipe from our rich running Tundra's.
    Rica25 likes this.
  28. Jul 27, 2021 at 10:57 AM
    For people who claim "I use X product and it works well". How could you know it's working? I've used Seafoam in our vehicles for years but it's not like I'm getting any feedback it's working. Honestly, I'm a bit skeptical these products do much of anything and tests I've seen on Youtube seem to back this up.
    Rica25 and 2018TundraLimited like this.
  29. Jul 27, 2021 at 11:28 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I buy my Techron at advanced auto or O’reillys when the have a bogo.
    Rica25 likes this.
  30. Jul 27, 2021 at 12:24 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I use top tier fuel, Costco usually, and several tanks between oil changes I throw a bottle of Gumout/STP concentrated injection cleaner in tank. Never had an issue with clogged injectors in several cars and many miles driven. doing nothing may also yield same results…
    Rica25 and coldcanuk like this.
