Spark plugs
Discussion in 'General Tundra Discussion' started by 40cpe, Jul 26, 2021.
  1. Jul 26, 2021 at 4:12 PM
    40cpe
    40cpe [OP] New Member
    gene
    2008 double cab 5.7L
    none
    New to me 2008 5.7, don't know if plugs have been changed. Sample take out is clean but it has a short tip/wide gap. I'm not familiar with iridium plugs. Is there a picture of the tip of a new one, or a gap spec?
  2. Jul 26, 2021 at 4:14 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    1.1 MM OR 0.043 IN.
  3. Jul 26, 2021 at 4:21 PM
    40cpe
    gene
    none
    Thanks for that. I had already reinstalled this one before I lookedtundrasparkplug.jpg at poor shot of tip. Also, notice gummy threads. Plug didn't spin out easily after breaking loose, had a drag on it all the way.
  4. Jul 26, 2021 at 4:28 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just check gap and anti seize
  5. Jul 26, 2021 at 5:46 PM
    40cpe
    gene
    none
    WELL, I pulled the plug again. I could only get .040" of stacked feeler gauges in the gap. Trk has 185,000 on it. Would an iridium plug with that many miles show more wear and gap than this one? I'm used to flathead Fords with .025" gap. Maybe the goop on the threads is anti seize put on at install? Thanks for all the help.
  6. Jul 26, 2021 at 6:12 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    iridium last a long time, it don't show much wear. if you don't know the history you just have to change it.
  7. Jul 27, 2021 at 2:54 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    spark plugs are cheap, just change them to iridium and you will be good to go for 50k miles.
