2017 sensor issues
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by warhammer8, Jul 26, 2021.
  1. Jul 26, 2021 at 1:47 PM
    warhammer8
    warhammer8 [OP] New Member
    william
    2017 Brown TRD
    Hello All,
    Just need some advice on my 2017 Tundra Limited TRD. First issue is that the right front bumper sensor is going off on its own a lot. I just turned off the sensor control on the dash to shut it up. Does anyone know of this and do I need to adjust this or replace this sensor?
    Second issue: My security alarm has gone off on its own now a few times while just sitting in the driveway. Any advice how to adjust the sensitivity of this alarm are their bigger issues.
    thx all...Love my truck besides this.
  2. Jul 26, 2021 at 1:59 PM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    Does direct sunlight on the front right sensor cause it to go off? It happens to mine and I think it started when I disconnected it to remove the bumper. Maybe I jacked up a connector. Did you disconnect yours?
  3. Jul 26, 2021 at 2:25 PM
    warhammer8
    william
    2017 Brown TRD
    Hi John,
    Never removed or messed with the front bumper. I had the right rear removed and replaced. Hmm....should effect the front. I'm reading that a silicone washer that is around that device might be worn. I'll investigate. Thx for the reply
