Normal Front-to-Rear Suspension Rake?
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Jul 24, 2021.
  1. Jul 24, 2021 at 1:08 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Hey folks, is my truck sitting normally or is the front to rear height difference too much?
    I know that my front end is supposed to be slightly lower than my rear but I'd love more opinions on if my truck's front rake is normal or if it's a more pronounced height difference. This truck is new to me with 180k miles, and if the height difference is bad I'll just replace the suspension with stock. Or something budget-friendly and issue free. Any suggestions? I probably can't afford bilsteins or some of the other popular suspension upgrades.
  2. Jul 24, 2021 at 1:09 AM
    DarkMint
    Ben
    Yes I know about the rusty scratch, yes I know the paint is shit. It's all money dependent.
  3. Jul 24, 2021 at 2:12 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Your front lower shock bushings could be shot if your shocks are old. Mine definitely are. My truck sits almost like yours. Although after my recent recall frame swap it's sitting up higher front and rear for whatever reason. Bilstien 5100s or similar are on my list. Just want mine to sit level really.
    Spacer lifts are cheap but theres a reason for that. A lot of people say they ride like garbage with spacer lifts but I can't say first hand.
    DarkMint[QUOTED][OP] likes this.
  4. Jul 24, 2021 at 5:59 AM
    Black Wolf, Darkness and DarkMint[OP] like this.
  5. Jul 24, 2021 at 6:02 AM
    Picks of the suspension to see what we are working with would help. The rake appears factory, or maybe a little high in the back? Also, I have a set of daystar front strut spacers that lift about 2". Free to a good home.
    DarkMint[OP] likes this.
  6. Jul 24, 2021 at 6:48 AM
    DarkMint
    Ben
    How hard is it to change out shock bushings? My knowledge of suspensions is zero...
  7. Jul 24, 2021 at 6:48 AM
    DarkMint
    Ben
    I'll get on this. Nice to have something to compare to.
  8. Jul 24, 2021 at 6:50 AM
    DarkMint
    Ben
    Pics inbound of the suspension.
    I'm definitely interested in the spacers! However people have said they don't "ride" well. What does that mean, like a stiffer ride? Any reason you're not using them yourself? Just curious!
  9. Jul 24, 2021 at 10:11 AM
    NickB_01TRD
    KY
    I believe it's possible and some people on here have found them for sale online for the factory bilstiens (if you have them) as well. Usually though if the bushings are worn out the shocks usually are too. New shocks have new bushings.
  10. Jul 24, 2021 at 10:22 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    My front bushing are shot, but i dont rake like the 1st pic. 2nd pic looks fine?
  11. Jul 24, 2021 at 7:41 PM
    DarkMint
    Ben
    Here is my suspension. Let me know if I'm taking pictures of the wrong thing.
    Passenger side:
  12. Jul 24, 2021 at 7:43 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    see how that bushing isnt centered?
  13. Jul 24, 2021 at 7:43 PM
    DarkMint
    Ben
    Driver side:
  14. Jul 24, 2021 at 7:44 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Oughtta reattach the sway bar, too.
    Black Wolf and DarkMint[OP] like this.
  15. Jul 24, 2021 at 7:45 PM
    DarkMint
    Ben
    Hmm yeah... That bushing is not holding the bolt in the direct center of the circle. I gotcha. Guess I'll replace that.
    Where does one reattach the sway bar?
    I'm officially spooked about this suspension haha.
    Rodtheviking likes this.
  16. Jul 24, 2021 at 7:45 PM
    Your lower shock bushing is wore out. Your sway bar bushing is broken in two.
    I took the spacers off after I bought the 5100 Billy's, it rode just fine with them on my factory shocks.
  17. Jul 24, 2021 at 7:50 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    make the top one look like the bottom one. You’ll need a new link, but might as well do all the sway bar bushings while you’re in there.
    and why is your driver side cv boot so juicy?
  18. Jul 24, 2021 at 8:09 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone recognize those shocks? And are those spacers under the springs? They dont look like my sequoias shocks.
  19. Jul 24, 2021 at 8:13 PM
    DarkMint
    Ben
    Thank you Sirfive. I'll look into buying a new link and sway bar bushings.
    I think I juiced the CV boot, lightly covered with oil from when I was doing something else. The rubber doesn't feel dry or stiff or anything bad, I think...
  20. Jul 24, 2021 at 8:14 PM
    DarkMint
    Ben
    Now that you mention it it kinda looks like spacers huh? I don't know what I'm looking at. Hope someone can provide insight.
  21. Jul 24, 2021 at 8:16 PM
    DarkMint
    Ben
    1) Does anything else look off about my suspension other than the shock and sway bar bushings and sway bar links?
    2) How difficult is it to replace these parts? Should I have a shop do it?
    3) What kind of shocks are these? I didn't know they are unusual.
    4) Is this vehicle safe to drive for now?
  22. Jul 24, 2021 at 8:24 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    1)Hows the tire wear look? Any pulling to one side? Since the bottom of the knuckles look fresh, are the lower ball joints fresh? Have you done a wheel bearing wiggle test?
    2) how much experience do you have with a wrench? Might have to get creative to replace shock bushings, i dont know how hard they are to press in or out.
    4) worn shock bushings arent too dangerous. As long as the broken sway bar link doesnt grab anything, i wouldnt call it safe, but i wouldnt consider it too dangerous.
  23. Jul 24, 2021 at 9:34 PM
    RustyShackles
    RustyShackles New Member
    2002 Tundra 4.7L AC SR5 4x4
    +1 on Sirfive.
    The shocks are stock height and a normal setup for that style. Probably a Monroe, Gabriel or similar brand. Some brands use a rubber seat like that to accommodate for the shape of the spring while others have a "bent" metal seat for the spring to rest upon.
    tacoguybill and DarkMint[OP] like this.
  24. Jul 25, 2021 at 4:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    May or may not help but the attached is from FSM for Front Suspension and Axle parts layout !
  25. Jul 26, 2021 at 1:42 AM
    DarkMint
    Ben
    Thanks everyone. You all rock.
  26. Jul 26, 2021 at 3:43 AM
    DarkMint
    Ben
    1) Tire wear looks fine for now, no pulling to one side. LBJ's are freshly done at dealer on recall. I have not done a wheel bearing wiggle test, don't know what that is...
    2) I have moderate experience with a wrench. I can't do stuff that requires press tools or torches though. I can probably change out the sway bar links myself but beyond that, if the bushings are difficult to press in/out then my hands are tied.
    4) Thanks. I'm going to keep driving this vehicle until the new links show up in the mail and replace them.
    I haven't noticed any excessive body roll but that's probably because I just don't know better with these trucks.
  27. Jul 26, 2021 at 5:07 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    with the front jacked up, grab the top and bottom of the tire, and wiggle. Shouldnt have any noticable play. The tie rod wiggle is the same, just grab the front and back of the tire, sometimes it helps to check that with one side jacked up at a time, or with blocks under the side you’re not checking.
    tacoguybill likes this.
