Anyone have Black Rhino Stadiums?
Discussion in 'Wheels & Tires' started by ProtoJ, Oct 11, 2019.
  1. Jan 27, 2021 at 6:02 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It'll look like more with bigger tires.
  2. Jan 27, 2021 at 6:05 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Did you need spacers?
  3. Jan 27, 2021 at 6:07 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    What size tires did you put on sir? Thanks btw, I’m new to all this.
  4. Jan 27, 2021 at 6:10 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    No spacers. Spacers would stick it out even more.
    Falken Wildpeak 275/70/18 on the BR Stadium Rims which are +10 offset compared to stock +60. If you put on 295, your tires will have more bulge than mine.
    17inferno likes this.
  5. Jan 27, 2021 at 6:15 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Thanks man. I’m pumped. Should probably look a bit more like 60driver then, huh? What lift did you use if any? Great looking setup!
  6. Jan 27, 2021 at 6:33 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    No lift. I'm hoping for a small 2/1 lift in the spring/summer (Bilstein 5100 middle setting and a 1" rear lift) to give a bit more clearance and allow me to put mud flaps back on.
    I wanted some poke and in a perfect world, these would have been +25. I could have also played it safer with 275/65 tires.
    We had minor rubbing but fixed it in an hour by removing flaps and pulled the front plastic liner forward 1/2".
    Thanks. We are quite happy with how the look turned out and we love the rims. Tires are awesome in the snow too
  7. Jan 27, 2021 at 6:39 PM
    DevenTX
    DevenTX New Member
    Deven
    2020 Tundra SR5 Crew Cab
    I have them in black, 285/70/17. Bilstein 5100, top setting.20201018_173554.jpg
    Ohannon7 likes this.
  8. Jan 27, 2021 at 6:41 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Thanks a heap! I’ll post some before and afters. My wife surprised me by asking for a lift and bigger tires so I’ve been down quite a rabbit hole for a clean looking setup for her. I’m a jeep fella. I really like the setups you and 60driver put together. We’ll see how 3/1 level w/ 295/70r18 Cooper ST Maxx on BR 18x8.5 looks. I imagine I’ll be massaging some plastic.
  9. Jan 27, 2021 at 6:44 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Sweet rig. That looks just like ours. What’s the tire peek like on the sides?
  10. Jan 27, 2021 at 6:46 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Damn. Should I go Bilstein 5100 instead of the Rough Country 3/1 level kit?
  11. Jan 27, 2021 at 7:23 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Nice.
    But I don't think your rims are Stadium unless they have changed them over the years. Yours have a design around the edge and your spokes are more shaped and glossy.
  12. Jan 27, 2021 at 7:45 PM
    DevenTX
    DevenTX New Member
    Deven
    You are correct I totally lied, the are The Chase. I will graciously remove my self from this thread. To eager for attention I guess.
    17inferno and BravoDeltaRomeo like this.
  13. Jan 27, 2021 at 7:50 PM
    Wiferig
    Wiferig New Member
    2017 Crewmax
    None
    Sick rig fella.
    BravoDeltaRomeo likes this.
  14. Jan 27, 2021 at 7:53 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    No no....I just noticed they are a bit different. :thumbsup:
    What offset are they? We don't see too many BR rims here. I've always liked them and not sure why more people don't run them.
  15. Feb 8, 2021 at 9:46 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Has anyone else joined @60driver and fit the 17” version of these to a 3rd gen? I love the look and prefer the offset over the Method 701 but only if they don’t cause caliper rubbing issues.
    Rippyro likes this.
  16. Jul 14, 2021 at 10:45 AM
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Bump for this question. I'm not a fan of the method hubcap/fake beadlock. I'm considering 17's, but of caliper spacing is a big deal I may just have to go 18s
  17. Jul 14, 2021 at 11:02 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I have a single 17" that I bought to test fit. I'm willing to pass it on if you want to try it. Where are you located?
    Or @60driver if you want a spare let me know.
  18. Jul 14, 2021 at 11:10 AM
    Rippyro
    Rippyro New Member
    I appreciate the offer, but I'm in Texas. @60driver do you have any pictures of your wheel weights or caliper spacing in the wheel? It would be much appreciated. Looks great BTW
  19. Jul 25, 2021 at 2:03 PM
    COTundra23
    COTundra23 New Member
    Beauty of a rig!
