  1. Jul 25, 2021 at 8:05 AM
    tundrapower
    tundrapower New Member
    Tucson, Arizona
    2007 Tundra Crewmax Limited
    Firestone airbags, Sequoia luggage rack
    Added New front winch bumper and winch and Sequoia Roof rack to my 07
  2. Jul 25, 2021 at 8:40 AM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Is that an oem roof rack? I haven't seen one before, tundra or sequioa, didn't know that was a thing. You got a part number? I love the oem look for roof racks. The prinsu and others are a little too boxy for me, and I don't like how tall they are
    joseph_womack likes this.
  3. Jul 25, 2021 at 8:44 AM
    tundrapower
    Tucson, Arizona
    The roof rack is off a Sequoia that I got for $100. I shortened it and installed with nutserts. It turned out really nice.
  4. Jul 25, 2021 at 11:13 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Please tell us more on how you did the roof rack cut/install. Looks good.
  5. Jul 25, 2021 at 11:28 AM
    Retroboy1989
    Northern Utah
    X2
    joseph_womack and Mountun Goat like this.
  6. Jul 25, 2021 at 11:43 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    That’s dope!
  7. Jul 25, 2021 at 3:05 PM
    tundrapower
    Tucson, Arizona
    Ok. After researching the factory Sequoia Roof rack, I found that the roof line from the sunroof to just past the CrewMax doors was the same as seen in the attached factory sequoia roof rack (though silver) photo. The roof rack is like any from Toyota and has the removable endcaps to exposed the mounting holes. I did not need the middle attachment/mount since I was shortening the side rails. I cut the side rails down to 35" each with a bandsaw. The rack was black so no need to paint it. I reassembled the rack and placed it on the roof to mark the pilot holes. Like the Sequoia, the placement of the mounting holes was just inside the channel with the rubber gasket. I measured about 4 times to get it right. Once in final position, I drilled the pilot holes and the final holes. Then I painted the holes with touchup and used M6 Nutserts with RTV to prevent leaks. Once finished I pulled back the door gaskets, pulled down the headliner to remove the drill shavings. This was a pretty easy install and took about 2 hours. I think it turned out really cool for the money since the rack was $100 and I already had the nutserts and install tool.
    Bikeric, Busa, BigSkyTaco and 14 others like this.
  8. Jul 25, 2021 at 3:31 PM
    Retroboy1989
    Northern Utah
    Nice work. This is cool.
  9. Jul 25, 2021 at 5:56 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    No damage to AIRBAGS from DRILLING ? I remember this issue with other rack installs.
    joseph_womack and GODZILLA like this.
  10. Jul 25, 2021 at 6:23 PM
    Retroboy1989
    Northern Utah
    That sounds like a living nightmare $$$
  11. Jul 26, 2021 at 5:56 AM
    tundrapower
    Tucson, Arizona
    No damage or any issues as the side curtain airbags attach on the outside of the roof channel.
  12. Jul 26, 2021 at 6:17 PM
    Hanzo
    Hanzo New Member
    Ever since I put the stoptech rotors and pads on my truck it’s been shaking like crazy. After chasing my tail a bit on it I finally decided I must have got wrapped rotors from the jump. Pulled the trigger on hawk rotors and pads last week and got them on today. SHAKING IS GONE!!!!
    pic of new stoppers
  13. Jul 26, 2021 at 6:24 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I had the same problem with stoptech. I went back to OEM and broke them in heavy and no shake also. It feels good to ditch the warp!
  14. Jul 26, 2021 at 8:46 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Installed my new antenna, see if this brings in signal any better than the last one
  15. Jul 27, 2021 at 4:31 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    New Diode Dynamics Fogs, New OEM headlight housings & Auxbeam Led headlight bulb and OEM towing mirrors.
    D4x4TRD, WVI, MTRock and 5 others like this.
  16. Jul 27, 2021 at 8:38 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    OOOO!!!
    Lemmy know how it works out!
    I got the following and it is not much better than without an antenna entirely. I am disappointed.
  17. Jul 27, 2021 at 8:41 PM
    COTundie
    Trey
    Pretty things
    Very nice!
    Crispy headlights are always a nice update. Lookin clean for sure!
    Malinois38[QUOTED] likes this.
  18. Jul 27, 2021 at 8:42 PM
    Shanet421
    San Diego,CA
    AntennaMastsRus - The Original 6... https://www.amazon.com/dp/B01NALK2FC?ref=ppx_pop_mob_ap_share
    I have this one and it’s about 75% as good as OEM
  19. Jul 27, 2021 at 8:47 PM
    COTundie
    Trey
    Pretty things
    Thank you Shane.
    I shall check it out.
    ... Its been ordered.
    Dont actually know what OEM sounded like. Was snapped off when I purchased the truck
  20. Jul 27, 2021 at 9:15 PM
    Punisher17
    Punisher17 New Member
    My brake story. Replaced front calipers, rotors and pads appropriately 2 years ago. Bled the brakes and they felt squishy. Took it to les schwab and they bled them but said there was no air in the lines and pedal has felt squishy since. Today I replaced all 6 brake lines with stoptech stainless steel braided brake lines. I bled the brakes with the one man brake bleeder once. Drove and engaged the abs on a gravel road and it didn’t take hardly any effort. Came home bled again. Next trip abs didn’t engage as easily at all. Came home and bled a third time. RP LP RP LD sequence every time. Drove again and I can say that they definitely feel better than before. After I drive it normally I’ll be able to tell more how much of a difference it has made but overall I’m a little bit happier lol.
    Mountun Goat, D4x4TRD and omgboost like this.
  21. Jul 27, 2021 at 9:16 PM
    COTundie
    Trey
    Pretty things
    Oh yeah.
    Received and installed my new bakflip mx4 (in damn near 100* weather)
    Straight forward install including the brackets to drop down and retain the factory tiedown system.
    Loving the low profile look. And the weather/prying-eye resistance will definitely be a welcome comfort. Transporting tools to the job and being able to have them in the bed while shopping will be nice for sure.
    Mountun Goat, D4x4TRD, WVI and 3 others like this.
  22. Jul 27, 2021 at 10:36 PM
    Retroboy1989
    Northern Utah
    I have this too. Works fine for me, but I don't use the radio very often. Most Bluetooth Spotify and audiobooks.
  23. Jul 28, 2021 at 6:17 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    New floor mats to match my new black carpet that I installed last week. These mats are SO much better than the poorly-fitting WeatherTech mats I had before. I installed the floor hooks after I took the pics.
    I can't find the receipt but they seem to have BD as a brand. If anyone cares I can dig the box out of the trash.
    8D57EED4-E118-43E9-9075-31F7916743B4.jpg 557603B3-772D-47AD-8842-26EFFD54866E.jpg
  24. Jul 28, 2021 at 6:29 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I believe they are 3D Maxpider.
  25. Jul 28, 2021 at 6:45 PM
    French Avocado
    Utah / Wyo
    Yes they are 3D MAXpider Kagu floor liners
    Bama and PhotoNerd like this.
  26. Jul 28, 2021 at 7:05 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
  27. Jul 28, 2021 at 7:17 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    finally I found the name I have those they’re great but they are definitely getting old. Where’d you get them if you don’t mind me asking?
    French Avocado likes this.
  28. Jul 28, 2021 at 7:31 PM
    PhotoNerd
    Tony
    Waterford, CT
    3D MAXpider L1TY14701509 All-Weather Floor Mats for Toyota Tundra 2007-2011 Double Cab Custom Fit Car Floor Liners, Kagu Series (1st & 2nd Row, Black) https://www.amazon.com/dp/B00MMKIKXU
    They're available for CrewMax too. Thanks to everyone who figured out what I bought lol. The branding is terrible.
  29. Jul 28, 2021 at 8:06 PM
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    Hung a few trail cams on a hunting property I just got permission on!
  30. Jul 28, 2021 at 8:41 PM
    French Avocado
    Utah / Wyo
    Got mine for the Crew Max from AutoAnything
    raymond_hb[QUOTED] likes this.
