Hannemann Hood w/ scoop Install
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Jul 23, 2021.
  1. Jul 23, 2021 at 11:47 PM
    evilrb
    evilrb [OP] New Member
    Jeremy
    Here is my install and review thread.
    Very Simple install and great quality overall!
    Hood INFO here
    : https://hannemannfiberglass.com/pro...d-with-air-scoop-bolts-to-hinges-uses-2-pins/
    Daystar hood pins:
    https://www.amazon.com/Daystar-Univ...r+hood+pin&qid=1627109152&s=automotive&sr=1-1
    Note the hood pins are sold individually so you will need to order 2.
    Very easy one-man job and the total time was about an hour or so if I did it all at once.
    I was doing a lot in-between so my install was over a few days.
    Straight forward, remove the grill, hood supports, and bolts.
    Drill for washers, I upgraded to Honda odyssey washers to get a better spray.
    https://www.tacomaworld.com/threads/windshield-sprayer-upgrade.542571/page-9
    https://www.amazon.com/dp/B00LIRXIN0?ie=UTF8&pldnSite=1&th=1
    Install hood pins where you like, the radiator support had holes that fit my Daystar hood pins perfectly and looked good to me in the middle.
    I ended up ordering longer studs just to fit better but that was not really needed.
    Other than that this hood is light, well made with 9 out of 10 fitment.
    I'm adding the hood shock back and an underhood light but that's just for me.
    I've had the hood on for a few weeks and parking it in the sun with the heat really helps it relax back into shape.
    The grill also helped the fitment on the front area.
    This is unpainted with only the factory gelcoat.
    Looks great with my white but I'll get to painting and final adjustments on everything in a few months.
    (it needs to move forward a bit)
    This scoop is open and the benefit is more for supercharger guys that cools the manifold.
    Same idea as non-VVTi metal manifold guys swapping to VVTI plastic intakes for heat dissapation.
    Now the PICs!
    154253660_10159387682204236_5644453442956457484_n.jpg 20210707_181331 (1).jpg 20210707_181458.jpg 20210714_154124.jpg 20210714_154127 (1).jpg 20210707_182256 (1).jpg 20210714_154709 (1).jpg 20210714_154719.jpg 20210716_130741.jpg 153837043_10159387682154236_4301186086256548359_n.jpg
  2. Jul 23, 2021 at 11:59 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I would recommend quiklatch hood pins (if you have or can retain the stock hood latch/release).
    Super slick design and work well. Plus no pins to lose.
  3. Jul 24, 2021 at 12:10 AM
    evilrb
    Jeremy
    I like these better, the pictures don't show the rubber grommets that the Daystar have.
  4. Jul 24, 2021 at 5:04 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Very nice.
    ive never had any problems with the novas hood pins, but ive had 2 different friends at different times go driving with the pins out and destroy their hoods and windshields.
    the novas did try to rattle loose, so each has a couple small tack welds because i didnt have loctite.
  5. Jul 24, 2021 at 6:10 AM
    Scoop looks good. Fit and finish is what I normally see from fiberglass hoods, meh at best. Can probably get it adjusted pretty close and it will look good from 10ft. Love the front bumper. Need to weld me one up like that. Good looking truck.
  6. Jul 24, 2021 at 4:54 PM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Looks nice!
    Would you say there was any noticeable weight difference between the 2 hoods?
