New Tundra Owner, Anything To Be Aware Of?
Discussion in '2nd Gen Tundras (2007-2013)' started by socaldiablo, Jul 23, 2021.
  1. Jul 23, 2021 at 9:32 AM
    socaldiablo
    socaldiablo [OP] New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    Hey all,
    Just bought my first Tundra about a month ago and really like it. I had been driving a 17 y/o Infiniti QX56 for 13 years and while it was running well, the sun had taken a toll on its exterior and I had been wanting a pick up truck for some time so I found a nice 13' Tundra Rock Warrior version up near the Bay area. The original owner took really good care of it. It only had 24K miles, he replaced the interior with black leather, added a trailer brake and Leer camping shell, had some carpeted inserts made for the bed, upgraded the wheels, and added running boards. Overall, a great vehicle and it was about exactly what I was looking for.
    It's got a few service issues I need to address like brakes and an imbalance in the wheels causing the steering wheel to shake at higher speeds, and a few others. Other than typical service things, the stereo sucks so that will be coming out soon and will be replaced with all new speakers and head unit. The back passenger side door does not open from the inside so I think the cable end has broke free from the door latch. Will need to pull the door panel and investigate ...I'll do that when I swap out the speaker on that door. This truck is really hard to see out the back so I need to get use to that. The rear view camera screen is up on the rear view mirror in a tiny little screen so I need to find a head unit that has a camera connection and use that to see better. I hope this is something that is not too complicated.
    My question is ...is there anything in particular that I need to be aware of, common problems I should proactively address, or common upgrades that I should consider? I wanted a 2013 because that year was one of the more reliable model years so I'm hoping that pans out. My QX56 I previously drove went through transmissions every 60-70K miles so I don't want that kind of situation again.
    Thanks all!
  2. Jul 23, 2021 at 9:46 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Be sure the child safety lock isn't on and preventing that back door from opening.
    With 24K miles, I wouldn't expect much in the way of issues. The kinds of issues you'll eventually run into will be things like the water pump needing to be replaced, cam tower seals leaking oil down the back of the engine, and worn wheel bearings.
    The cam tower leak is pretty expensive to fix (still probably less than a QX56 transmission), but I think it's rare to have to do it more than once. If your truck is a flex fuel vehicle, there can be some definite shenanigans with that which will require software updates from the dealership.
    socaldiablo[OP] likes this.
  3. Jul 23, 2021 at 9:46 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Welcome neighbor
  4. Jul 23, 2021 at 9:47 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes, you bought the wrong color. :eek:
    Welcome!
    Gravy and socaldiablo[OP] like this.
  5. Jul 23, 2021 at 9:51 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Agreed…:rofl::rofl::rofl:
  6. Jul 23, 2021 at 9:53 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Biggest concern in my opinion is the weight of your wallet after spending too much time on this forum.
  7. Jul 23, 2021 at 9:59 AM
    socaldiablo
    Carlsbad, CA
    Good one! I would have preferred something a bit more sexy but this is the color I need. The truck is too big to park in my garage and so it needs to sit outside. The QX56 was black and the sun absolutely tore it up, literally baked away the clear coat and paint such that the primer was visible on the top panels. I purposely wanted white so the paint would last longer sitting outside. I'm in Southern California and the sun is intense here ...I don't have it quite as bad as others who live further inland, though. I'm about 4-5 miles in from the ocean and so we get the marine layer here often times but nonetheless, I need a light color if parking outside.
    Darkness[QUOTED] likes this.
  8. Jul 23, 2021 at 10:07 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Nice pics ~ thanks for sharing . . .
  9. Jul 23, 2021 at 10:09 AM
    socaldiablo
    Carlsbad, CA
    Yeah, that was the first thing I checked. No go there ...child lock was not engaged. Thanks for the heads up on these service things. I will be sure to watch for this stuff. I do have the flex fuel motor and I see on the CarFax that in 2015 at 9,324 miles, there was an 'Engine/powertrain computer/module reprogrammed' and 'PCM reprogrammed' performed by the local dealership. Maybe this was taken care of already?
    This truck does not sound beefy enough for me with the stock exhaust. I think I need to add a catback system from Borla, Magnaflow, or the likes.
  10. Jul 23, 2021 at 10:11 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    With that low of mileage, it’s obviously sat a while. I’d definitely run a tank with some Royal Purple Max Clean fuel injector cleaner. Also check the date code on the tires to see how old they are. They may look good, but they do dry rot. Also, check the spare tire pressure and make sure it’s not rusted in place.
  11. Jul 23, 2021 at 10:22 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome!
  12. Jul 23, 2021 at 10:23 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm in Moorpark, same problem. That marine layer floats through during the early morning and makes washing my cars pretty futile.
    I'm just gonna pretend your truck is "light black".
  13. Jul 23, 2021 at 10:24 AM
    socaldiablo
    Carlsbad, CA
    Yeah, had thought about the injector cleaner. I typically use Lucas fuel system cleaner every so often in my vehicles and so will be doing this on the Tundra soon. It's got BF Goodrich All Terrain tires that look to be on the newer side ...I looked for the date stamp when I bought the truck but did not see it on these. The original owner had said he replaced the original tires and wheels but he didn't say when. I will check on the date stamp again. I'm sure the spare is OE and probably needs to be replaced as I had a glance at it and it's not a BF Goodrich.
  14. Jul 23, 2021 at 10:28 AM
    socaldiablo
    Carlsbad, CA
    I like your profile pic. My personal e-mail is gosdpadres :thumbsup:
    YardBird[QUOTED] likes this.
  15. Jul 23, 2021 at 10:32 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Around here, we are fans of Keith over @dirtydeeds for exhaust. Explore there 1st
  16. Jul 23, 2021 at 10:46 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  17. Jul 25, 2021 at 1:20 PM
    coastaldesert
    coastaldesert New Member
    Oregon Coast
    Welcome...I just bought a low mileage 07' (53K~) and the inspection checked out clean aside from a leaky water pump which turns out to be very common on these!
    Had a shop put in a new water pump, coolant, thermostat for around $600 and all is well.
    Nice truck, hopefully stays trouble free and lasts you as long as you want it around!
    socaldiablo[OP] and Danny3737 like this.
  18. Jul 25, 2021 at 1:33 PM
    Welcome from NY.
  19. Jul 25, 2021 at 2:58 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal. Nice find! In the fastest color to boot! Just ignore Darkness, he's just mad he's always getting passed by the superior 040s. :poking: :D
