  1. Jul 23, 2021 at 6:41 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Hang in there! We feel your pain
    pvn.beluga[QUOTED] likes this.
  2. Jul 23, 2021 at 7:00 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Wow, I guess the pandemic has everything backed up with shortages, etc. Almost every item I order for the truck has a wait time or is put on back order for a while.
  3. Jul 23, 2021 at 7:14 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I wouldn't say it was easy, but it wasn't as hard as when I put seat covers on my Nissan frontier. As far as I'm concerned there is no option but to unbolt the rear seats to put the seat covers on, I don't see how you could without unbolting. If you decide to get them I must give you a fair warning, they are warm seat covers. I find myself a little sweaty after anything longer than a quick errand. I'm sure in the winter it won't be so bad but right now it's definitely noticeable.
  4. Jul 23, 2021 at 7:23 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I know lots of folks had good experiences with them, but just know they come from Europe (I think) and take a while to ship. I ordered mine in December and have yet to receive mine. No big deal, not bashing them at all, shit happens, probably just lost in the mail. I was only out like $15 so I said screw it and just got the real deal caps from McGeorge.
  5. Jul 23, 2021 at 7:28 AM
    snappy924
    Garrett
    Unbolting seats great pointer! Never thought of that! Thanks!
  6. Jul 23, 2021 at 7:30 AM
    snappy924
    Garrett
    I heard most parts are coming overseas. I live in SoCal and when I’m at the beach you can see a ton of cargo ships docked in the ocean waiting to unload. I’m sure our orders are sitting out at sea!
  7. Jul 23, 2021 at 7:33 AM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
    I'm in for milage!
    Tundratoofun and jomikepa like this.
  8. Jul 23, 2021 at 7:33 AM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    What was the process you used to reskin the center console lid? I’ve got the leather sitting in my garage, but haven’t started yet. What foam did use? What parts (if any) were glued down? What kind of glue? Etc.
  9. Jul 23, 2021 at 8:12 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Thanks Jeff!
    That’s pretty killer work yourself there! Love the baseball idea. Looks like that ball is set for a two-seam fastball grip?!
    Now you just need the Katzkins Rawlings leather seats!
  10. Jul 23, 2021 at 9:16 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    The cover itself is vinyl. Got it off of Fleabay actually, here.
    As mentioned, I first removed all the old vinyl and the thin factory foam and glue. It was a sluggy mess. I’m sure after a few years of seasonal temperatures, cleaning products, body oils, etc. the original foam had just about disintegrated.
    I used a old squeegee that I used for vinyl to scrape off as much of the old foam and glue as I could. Any type of small, hard plastic scrapper would be fine.
    From there, I just used Acetone (stole the Ms’s nail polish remover) to get the worst of the sticky off.
    Then used 90% alcohol to help get any of the residue. Finally washed it with dish soap.
    For any leather, vinyl or headliner wrapping, I’ve always used Weldwood contact cement.
    The trick is, to always have clean surfaces, and work in small bits at a time. I’ve always taken my time and enjoyed the process…hence the beer I mentioned in the original post.
    I’ve always used a cheap 1/2” or 1” paint brush to apply the glue. Apply it to each side, and let it tack up (about 5 - 10 mins) before pulling and pressing into place.
    For the foam, I used a dense, closed cell foam. It’s from Creatology. They have some that has self adhesive on it. Don’t use it…it’s shit adhesive. Just get the regular sheets and glue it down.
    I actually found some at Michaels. You might find it at Hobby Lobby as well. I can’t remember the exact type of foam, buts it’s the same stuff a lot of craft foam is made of, and some of the sectional floor pads you can get at Harbor Freight. Here’s a pic of the 1/4” sheet.
    I covered the whole thing with the 1/8” foam, then added a layer of the 1/4” on the top piece. Once everything was set, I used a new x-acto blade and went around the outer edges of the 1/4” piece to cut off the 90 degree angle so the top had a smooth curve to the side. You can gently sand it with 180 or 220 grit to smooth it out as well.
    From there, start gluing down the cover.
    I started on the center of the larger, surface area of the back, then slowly worked forward, one side at a time, about 3” sections at a time. I glued down the top surface first, then the sides. Taking care to line the stitching up with the edges.
    Lastly, I tucked the edges around the under side. You may have to make some small triangular relief cuts as you pull and tuck the edges.
    Check out Chechaflo on YT. This guy’s an old master at leather wrapping. A lot of the techniques in this video are what I used.
    You can get automotive vinyl relatively cheap. Get yourself some and practice wrapping it on a piece of scrap wood. You’ll fine it usually acts much like real leather in that it will stretch one way more than another.
    Good luck with it!
  11. Jul 23, 2021 at 9:20 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks Geno!!
    BlueRibbon4x4[QUOTED] likes this.
  12. Jul 23, 2021 at 9:29 AM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    I punctured the sidewall of my 1,254 mile old tire . Thinking of having the spare mounted and buying a cheaper tire to use as a spare. Any issues w that? Seems logical, but just want to make sure I’m not missing something.
  13. Jul 23, 2021 at 9:42 AM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Finished up a minor detail on my LT headers install.
    Also modified my TRD tailpipes into after axle dumps so the leaf springs would stop hitting them at full droop.
    shes a little dirty.
  14. Jul 23, 2021 at 9:52 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I’d also like to know.
    Where did you get the leather for it?
  15. Jul 23, 2021 at 10:28 AM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    You are correct more than you know, and that's funny, because it is exactly what I do! Spend seven months or so each year on ships delivering cargo all over the world. Then come home and install all the parts that I ordered for my truck while I was away at sea, at least the ones that got delivered on time.
    Tundrastruck91 and AggiePhil like this.
  16. Jul 23, 2021 at 10:29 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    That's what I would do.
    jomikepa[QUOTED] and 2mchfun like this.
  17. Jul 23, 2021 at 11:08 AM
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
    this looks great !! you stole my thunder but am glad you did, now I know for sure the shifter boot will look great.
    yours look great. good job !!
    Clemshady[QUOTED] likes this.
  18. Jul 23, 2021 at 11:17 AM
    dbldutch
    dbldutch Full send
    Dutch
    Highlands Ranch, CO
    2021 Black SX SR5 crew
    Trd pro headlights, baja designs fog lights, total chaos uca's, toytec lift
    Ceramic tinted the front 2 windows today to match the back.
  19. Jul 23, 2021 at 11:20 AM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Yep, pretty easy. All you have to do is pull up the whole center console from the back compartment area with a plastic pry tool. Put the leather boot on and put center console back on. Nothing has to be removed or altered.
  20. Jul 23, 2021 at 11:23 AM
    Clemshady
    Jeff
    Thanks, been an Atlanta Braves fan for years and have gotten used to disappointment, lol.
    TNTundra16 and GAknight like this.
  21. Jul 23, 2021 at 11:25 AM
    swallace
    Steven
    Tri-Cities, WA
    Thank you! This is very helpful.
    GAknight[QUOTED] likes this.
  22. Jul 23, 2021 at 11:30 AM
    Clemshady
    Jeff
    http://www.redlinegoods.com/
    Attached is link. You have lots of color options as far as color of boot and stitching.
    romad86[QUOTED] and GAknight like this.
  23. Jul 23, 2021 at 11:38 AM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    Ceramic tint is cool:cool:
    If you do the windshield too it really cuts down on the dashboard and interior temps. It is considered illegal is some states but...
  24. Jul 23, 2021 at 11:38 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    20210703_170511.jpgadded a trd pro grill and tow mirrors. Like the look of it.
    YotaBro, Winning8, TNTundra16 and 9 others like this.
  25. Jul 23, 2021 at 11:45 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Damn you! (Shakes fist violently)
    Now I need to figure out which color matches my seats...
  26. Jul 23, 2021 at 12:02 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I drive mine to work on Fridays and over the weekend otherwise it sits in my driveway and collects dust which gets washed off every Friday after work. It does get driven though, 7500 miles since I got it in March.
    Tundratoofun likes this.
  27. Jul 23, 2021 at 12:10 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Life changes and the truck has gone through a lot. At one time I was filling up once a week, now it may go 3 months on a tank. If I bought my vehicles based on how much I'd use or what I'll use it for I'd change vehicles 2 to 3 times a year. Best part about a pickup - it'll sit in a driveway, it'll run errands around the city, it'll take a day trip to the mountains, it'll haul quads, and it'll pull a travel trailer. One vehicle that'll do anything I would need one for.
    soobahru and Tundratoofun like this.
  28. Jul 23, 2021 at 12:12 PM
    belanger9
    Edmonton, AB
    A bunch
    Was that with TC off and Tow/Haul engaged?
  29. Jul 23, 2021 at 12:14 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I think the Cummins titan might be a close race.
  30. Jul 23, 2021 at 12:27 PM
    cochese
    cochese New Member
    Oregon
    '21 Lunar Rock TRD Pro Double Cab
    i figure that since it’s now basically legal to run meth as long as you don’t deal too much of it, are they really going to pull you over for front window tint?
    well maybe if you’re drag racing a titan or something *cough*
