Transmission Drain and Fill Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tallyn91, Jul 20, 2021.
  1. Jul 20, 2021 at 6:20 AM
    Tallyn91
    Tallyn91 [OP] New Member
    2014 Super White Tundra SR
    So I bought my truck at approx 110k miles and it just hit the 120k mark. On the carfax it jumps from about 47k until I bought it. Obviously I don't want to just assume the person before me kept up with everything so should I have a drain and fill done or is it too risky at this point, not knowing if the 60k d/f was done?
    I know a flush is a terrible idea but what about a simple drain and fill?
  2. Jul 20, 2021 at 6:32 AM
    Taco-Spike
    Two Trucks
    I doubt it would hurt anything.
  3. Jul 20, 2021 at 6:32 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Nothing to worry about, drain and fill will be ok.
  4. Jul 20, 2021 at 12:14 PM
    Tallyn91
    Alright cool, I heard both and people saying drain and fill could still kick stuff up and mess up the trans so I just wanted to double check. Thanks guys!
  5. Jul 20, 2021 at 12:48 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Pull the dip stick out and see if the fluid is clean, dark or burn b4 doing anything
  6. Jul 20, 2021 at 12:48 PM
    2mchfun
    I'd drain and fill it three times over about the next 6k. You have no idea what they might have been doing with the truck. Might also want to reset the fluid degradation meter in the computer using techstream software to get the clutch pack pressures matched up with the fresh fluid. After that has been reset I'd do one more drain and fill. Ounce of prevention is worth a pound of cure.
    Hamster14 and Wallygator like this.
  7. Jul 20, 2021 at 1:09 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    What’s all this about?? I’ve never heard of that fluid degradation meter topic before
  8. Jul 20, 2021 at 1:14 PM
    2mchfun
    I read about it in this forum. Apparently the computer compensates as the fluid degradation occurs over time. Basically, my understanding is that it makes pressure adjustments to the clutch packs. Makes sense to me.
  9. Jul 20, 2021 at 1:17 PM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    make sure your fill bolt comes out before draining lesson learned the hard way...
    HulkSmurf14 and 2mchfun like this.
  10. Jul 20, 2021 at 1:24 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I thought the ATF fluid degradation meter was just an info only readout to provide a measure regarding cumulative ATF high temp exposure for follow-up on tranny problems. I don't know that it figures into any trans control strategy. I do not have a Techstream or clone so could not reset it when I changed the ATF. Did not worry about it as I didn't think it controlled anything. Can someone verify?
  11. Jul 20, 2021 at 1:26 PM
    AZBoatHauler
    So.Arizona
    If there is a dipstick for the ATF on his truck there are much bigger issues. In my experience WS turns dark fairly quick so color isn’t a great indicator. If it was me, I’d do drain and fills every 10k for the next 40k miles assuming you plan on keeping the truck as long as possible.
    2mchfun likes this.
  12. Jul 20, 2021 at 1:37 PM
    Tallyn91
    So when you say to do it every 10k for next 40k are you talking about full drain and fills? I've never done one but from my understanding from the forums is you don't actually drain out all of the fluid but rather only end up putting in 3-4 new quarts each time?
    Also not sure about the whole techstream clutch pressure packs thing, hadn't heard that before. Is that something that could be done at a dealer?
  13. Jul 20, 2021 at 1:44 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    WILLINH and Spvrtan like this.
  14. Jul 20, 2021 at 1:55 PM
    AZBoatHauler
    So.Arizona
    Right - you’ll drain about 4 qts each time which is approx 1/3 of the total fluid. Ideally drains 3 and 4 will look about the same. Try to take pics of the old fluid on a paper towel in the same lighting conditions for comparison.
    Tallyn91[QUOTED][OP] and 2mchfun like this.
  15. Jul 20, 2021 at 2:22 PM
    Tallyn91
    Is that all it will allow me to drain or that is all I should drain? Certain parts of cars I've always let a shop handle and trans is one of them so my knowledge is miniscule lol don't wanna jump in there accidentally drain everything
  16. Jul 20, 2021 at 2:25 PM
    2mchfun
    That is all it will allow from the drain plug in the pan
  17. Jul 20, 2021 at 2:27 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    And is there a fill line? How do you know how much to put back? Or is it like diff and just filler up?
  18. Jul 20, 2021 at 2:44 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    There’s a overfill plug next to the drain plug, the filler plug is on the transmission
  19. Jul 20, 2021 at 3:31 PM
    AZBoatHauler
    So.Arizona
    ^ This. If you have an ATF cooler, there is a method that unhooks the return line and allows you to pump out 2 quarts at a time getting much more than the 4 quarts but it is much more involved and carries more risk for a DIY'er in my opinion.
    2 methods people use - 1) measure what you take out and replace the same volume. The old and new fluid should be approx the same temperature if you use this method. 2) the "proper" way is to get the transmission to a specified temp (around 100F) and pull the check bolt - you should get just a trickle of fluid with the motor running. If it doesn't trickle, its low. If its more than a trickle, its high and you keep the check bolt out until it slows to a trickle. Spend some time reading some relevant threads on here and it will make sense.
    2mchfun[QUOTED] and FrenchToasty like this.
  20. Jul 20, 2021 at 3:47 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Gotcha. Thanks. Yeah, need to read up on it. Was done at dealer last so I have no idea if it’s the right level.
  21. Jul 20, 2021 at 8:14 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    great video, guy is on point...
  22. Jul 20, 2021 at 10:56 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Unhooking the return line is a simple process. I’ve done it on two different trucks. Easy peasy.
  23. Jul 21, 2021 at 6:12 AM
    SouthWestGA
    I was looking at the lines going into the transmission cooler yesterday
    Which line is it? I see on the metal lines that run over the radiator shroud and it looks like they have red and blue marks where they attach into the transmission cooler
  24. Jul 21, 2021 at 5:24 PM
    SouthWestGA
    Question answered today
    Here’s pics as proof
    The 1 with fluid in it is the winner!
    JLS in WA likes this.
