Where to buy a sub box for two 8" subs?
Discussion in 'Audio & Video' started by szabosam, Sep 21, 2019.
  1. Sep 21, 2019 at 3:44 PM
    szabosam
    szabosam [OP] New Member
    sam
    need to know where to buy a sub box for 2 8" subs. ported box for 2019 tundra crewcab
    Rica25 likes this.
  2. Sep 21, 2019 at 3:51 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Check out Tech12volt Solutions. James can hook you up
    Seanc770 likes this.
  3. Sep 21, 2019 at 3:58 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why ported 8s when you can have ported 10s?
    Box built to Sundown specs by James at tech12volt.
  4. Sep 21, 2019 at 4:35 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I would definately go with at least 10s.
    And another vote for James at tech12volt
  5. Sep 21, 2019 at 5:28 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I just had two 10” JL’s put behind my rear seat. My 9 year old daughter loves bouncing to the bass while sitting back there.
    tigerpaw1129 likes this.
  6. Sep 23, 2019 at 2:50 PM
    W27
    W27 New Member
    Those are great options depending on your needs and budget. I found 1 quality 8” was plenty for me. I used a JL audio CP108LG-W3v3. I later added a second one just because I came across a good deal on one. A second didn’t make much difference. They fit perfectly behind the rear seats. Pretty easy to come across.
    20SilverTundra likes this.
  7. Sep 23, 2019 at 2:55 PM
    szabosam
    sam
    where can i get a box for 2 8" and is yours ported?
  8. Sep 23, 2019 at 2:55 PM
    BrownBomberTT
    BrownBomberTT "Smokin' JLo"
    Chill Will
    Metro Atlanta, GA
    2016 Toyota Tundra Limited Crew Max
    Soon 2 Come.. .
    What's that sound deadening material behind the seat? Plus the box is bolted to it? Please explain the setup.
    Primalbryan likes this.
  9. Sep 23, 2019 at 2:59 PM
    W27
    W27 New Member
    If you google JL Audio CP108LG-W3v3 they’ll come up. There’s some deals on used ones on eBay, local audio shops that carry JL, or wherever you find the best deal online. The box is ported and built by JL just for that speaker. It’s a loaded enclosure.
  10. Sep 23, 2019 at 3:04 PM
    W27
    W27 New Member
    I’m not the guy you quoted, but what you’re seeing above the box looks like the factory sound dampening behind a gen 3 crewmax seats.
    Lassie likes this.
  11. Sep 23, 2019 at 4:06 PM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    Doubling the cone area (I.e. adding a second sub) while using the same available power adds about 3dbs. Doubling the power and cone area will gain 6dbs.
    It takes a surprising amount of power and subwoofer cone area to really impact the overall output.
    3db is what most people perceive as a slight increase in volume. Basically it take a lot to get a significant increase in output.
  12. Sep 23, 2019 at 4:15 PM
    Primalbryan
    Primalbryan New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    I just ordered a full audio kit from James at tech12volts. Jbl amp, 2 jbl 10s, all new component speakers, wiring etc for under a grand
    vipgs3 and TxTundracm514 like this.
  13. Sep 23, 2019 at 5:43 PM
    W27
    W27 New Member
    I agree with everything you said. My truck is a 14. When I bought it in 2014 there weren’t many options that would fit behind the crewmax rear seats. Custom installers near me wanted a fortune to build something. At the time I wanted to keep the stock head unit. Now that it’s freezing up an upgrade may be in my future. I thought the initial suggestions would be pricey, but that actually seems very reasonable.
    Twinky[QUOTED] likes this.
  14. Sep 23, 2019 at 7:11 PM
    @james@tech12volts is your man! Best see fist ever (seriously, you can ask anyone on this forum who has worked with him. James has even helped guys who didn’t buy from him troubleshoot the issue because that’s the type of guy he is.)
    Primalbryan and JoshuaA like this.
  15. Sep 23, 2019 at 7:32 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’m not the guy you quoted either, but if the kinda useless white padding is removed from that black factory backing, it leaves room for butyl and MLV deadening. Do the doors, and if adventurous the floor and roof too. I didn’t do the last two and it still made a huge difference in reduced noise and further enjoyment of music.
    BrownBomberTT[QUOTED] likes this.
  16. Sep 23, 2019 at 8:12 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    I fell down the home theater rabbit hole about 5 years ago...you have no idea (or perhaps you do!) how bad the bass chase can get. :thumbsup:
    BrownBomberTT and Twinky[QUOTED] like this.
  17. Sep 24, 2019 at 12:57 PM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    Danimal86 and Primalbryan like this.
  18. Sep 24, 2019 at 6:10 PM
    Danman34
    Danman34 New Member
    Danny
    That’s the mat that is behind the seat stock. I added sound deadening and closed cell foam and put the stock rubber mat back. Box isn’t bolted. It fits perfectly behind the seat. It doesn’t move at all once the seats bolted in place.
  19. Sep 24, 2019 at 6:53 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I got mine from the Toyota dealer.
    Twinky likes this.
  20. Sep 24, 2019 at 6:54 PM
    r1-superstar
    DB
    UTAH
    Agreed about the size! ^^
    BrownBomberTT likes this.
  21. Sep 25, 2019 at 6:37 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    subbed
    PJR202 likes this.
  22. Sep 25, 2019 at 8:10 AM
    PJR202
    PJR202 New Member
    For you all that added subs but kept the remaining speakers...are you only adding an amp for the subwoofer or did you boost the power for the whole shebang? I'd rather not fool with the component speakers if I don't have to. I really just feel like I'm missing a bit of low end to really fill out the music.
    panicman likes this.
  23. Sep 27, 2019 at 4:46 PM
    r1-superstar
    DB
    UTAH
    Post #11 https://www.tundras.com/threads/supes-2018-mgm-sr5-cm-sport-build.38149/
    PJR202[QUOTED] likes this.
  24. Sep 28, 2019 at 4:16 PM
    916tundra
    916tundra New Member
    Ken
    2017 Tundra Crewmax
  25. Sep 28, 2019 at 4:31 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
  26. Jul 20, 2021 at 2:41 PM
    sludgepickle
    sludgepickle New Member
    San Diego
    2018 Silver SR5 DC 4x4
    Looking for guidance to add a single sub under the passenger side of my double cab rear bench seat so I keep the bigger storage area (I have the storage bins). I've heard the JL 8" ACP108LG-W3v3 fits nicely if you pull the storage bin out. Looks easy, already powered, just needs a simple install. Any other recommendations?
  27. Jul 21, 2021 at 7:56 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Last week, I installed Pioneer TX-WX130WD, 8 inch powered sub under the passenger seat. I got non-JBL factory amp under the passenger seat. I just bought harness extensions with necessary breakouts on it. And connected all the wiring from the sub such as left right speaker wires, constant 12V, switched 12V and ground with that breakouts. No modification on truck side wirings. Total I spent is $250+. I can trust Pioneer sound. Works very well to my liking.
    Forgot to add, I got 4 Kicker speakers on all doors before this addition.
    sludgepickle[QUOTED] likes this.
  28. Jul 21, 2021 at 3:08 PM
    sludgepickle
    San Diego
    Looks like your sub is 50 Watts? I'd like 150 if I can...but I do see some more compact ones than the JL W3...maybe I don't need such a beast. This is tempting: https://www.crutchfield.com/p_105DRA8/JVC-CW-DRA8.html
    Lassie[QUOTED] likes this.
  29. Jul 21, 2021 at 3:33 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    I chose a Pioneer Sub based on the ability to reproduce great sound space in my cabin. It is one of the best system in the market. 4 Kickers and this Pioneer can reproduce similar sound space that my headphone, Sennheiser can. That is my goal. If your goal is to have large WATTs rather than better music space then better choose other system like you suggest.
