Weird Oil Dipstick Reading
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Jul 21, 2021.
  1. Jul 21, 2021 at 12:41 PM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Hi all. Did an oil change and my dipstick is reading low on one side and on the other side, it's slathered with oil. The truck is parked level, and not on any lifts or anything. What is going on here? I tried wiping and checking the dipstick again, getting the same results.
  2. Jul 21, 2021 at 1:13 PM
    DarkMint
    Ben
    Gotcha, problem is how do I verify if I've filled the oil to the proper level? If one side shows low and on the other side the oil is super high.
  3. Jul 21, 2021 at 1:17 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    wait a little comeback and check it again, oil not settle
    TTund16 likes this.
  4. Jul 21, 2021 at 1:28 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Let it sit overnight and then re-check it.
    Tundra2 likes this.
  5. Jul 21, 2021 at 1:30 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    How long are you waiting to check it after it has been running?
  6. Jul 21, 2021 at 1:32 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine does this too. The tube for the district has an aggressive bend near the bottom. Oil seems to smear on the bottom side of the dip stick (the side thats toward the tire).
    I have always poured 7 qts in mine for hit the mark. I believe 6.5 qts is when using the original filter which is a bit smaller than the one I use
  7. Jul 21, 2021 at 1:36 PM
    a_double
    a_double New Member
    Start and stop the engine. Let it sit for an hour. Pull dipstick, wipe, re-insert, check level.
  8. Jul 21, 2021 at 2:22 PM
    DarkMint
    Ben
    I get the exact same result regardless of how long I leave it after running, or checking it cold, or whatever speed I insert and pull the dipstick. I've let it sit overnight, I've let it sit for an hour, etc. I filled about 6.7 qt in there and I'm using a Mobil 1 M301A filter. But regardless, I should still be able to check oil levels.
  9. Jul 21, 2021 at 2:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It isn't anything to do with letting oil settle. Its from the dip stick tube. I think that oil settles in the bend at the bottom. There might be a ridge where the tube meets the motor or something. As long as I have owned my truck the dip stick can only be read on the side that faces the motor, the other side looks like I am way over full.
    DarkMint[OP] likes this.
  10. Jul 21, 2021 at 2:57 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    The bottom of the dipstick drags the inside of the tube. And when you pull it, hold it flat-flat with the side closest to the engine up. I prefer dipsticks with crosshatching, but the dimples are fine.
    Darkness and DarkMint[OP] like this.
  11. Jul 21, 2021 at 3:18 PM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    Well I think if you wiped the dipstick clean before re-inserting then pulling the dipstick out would not wipe the oil to some lower level, but you can smear oil on the dipstick.
    The lower level would be correct.
    Also the holes in the dipstick are hard to fill with a wipe..
    Darkness likes this.
  12. Jul 21, 2021 at 4:03 PM
    DarkMint
    Ben
    I think Darkness got it. I'll go off the side facing the engine. Makes sense, thank you!
  13. Jul 21, 2021 at 4:10 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Some dipsticks are frustrating to read. I’d just ignore a high reading on one side, as others point out. Take the low reading. After all, any part that’s submerged in oil will cover both sides up to that point.
  14. Jul 21, 2021 at 5:01 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Shoots . . . I thought it was just me . . . EXACT same thing here.
    Last time I did an oil change i was puling and inserting the stick trying to get a good reading . . . my eyes suck, but not THAT bad. I even tried turning/ inserting the stick from 12 oclock to 3:00, to 6:00, to 9:00 LOL . . . .
    Thanks everyone for the replies, much appreciated.
  15. Jul 21, 2021 at 9:22 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I always only use the side of the dip stick with the raised bumps to check oil level. Pull out, wipe, reinsert, pull out again and check level.
  16. Jul 21, 2021 at 9:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    this happens on recently ran engines. general rule of thumb is to go off the lowest side. or let it sit for a half hour and check again
    Desert Dog likes this.
  17. Jul 21, 2021 at 9:32 PM
    I had a problem with mine never reading the oil. I ended up having to buy a longer dip stick so it would read right.
  18. Jul 21, 2021 at 9:33 PM
    empty_lord
    05 rollover special
    uhhhhhhh
    Hi06silver and bmf4069[QUOTED] like this.
  19. Jul 21, 2021 at 9:35 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  20. Jul 21, 2021 at 9:35 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    It is easier to read after a few thousand miles, but not by much.
  21. Jul 21, 2021 at 9:42 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just use royal purple, easiest to read.
    Sirfive likes this.
  22. Jul 21, 2021 at 9:47 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Try not to torture yourself over this. As empty lord stated above, as a general rule of thumb, go with the low side. So long as you're checking it on level ground, the low side will be the accurate and correct reading.
  23. Jul 21, 2021 at 11:45 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'm defeated .. . can't even read my own dipstick . . . . I am the true 'Enos' the "Dipsitick" from Dukes of Hazard.
