What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jul 2, 2021 at 9:44 PM
    #2911
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Truck made it to 100000 miles, no issues, replaced the original brakes at 75,725 miles. I love it, here’s to another 100000 miles.
  2. Jul 3, 2021 at 7:49 AM
    #2912
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Fixed
    These trucks should be held to a higher standard. Even a Kia can make it to 200k. You got this!
    szabo101 and Samoan Thor[QUOTED] like this.
  3. Jul 3, 2021 at 5:15 PM
    #2913
    Wahayes
    Will
    2017 tundra limited *sold*
  4. Jul 3, 2021 at 5:16 PM
    #2914
    Wahayes
    Will
    Also I really need to install my rear lift shackles lol
  5. Jul 5, 2021 at 1:50 PM
    #2915
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Nice Jayco ! , is that the X20E ?
  6. Jul 5, 2021 at 5:45 PM
    #2916
    Wahayes
    Will
    Got her towed back to utah.wooot!!!!! Now to start the disassembly of rats nests and parts to get her running again lol.
    Those wheels got to go!!! Anybody got a 1999 Tahoe needing "dubs" call me lol
  7. Jul 5, 2021 at 6:34 PM
    #2917
    Wahayes
    Will
    Where the mice/rats were hiding stolen dog food lmao
    Bigboitundra and WAtundra4x4 like this.
  8. Jul 5, 2021 at 6:55 PM
    #2918
    Samoan Thor
  9. Jul 6, 2021 at 7:45 AM
    #2919
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    :rofl: My wife had a 1998 Avalon with 249k miles on it. I once went out to check the air filter and there was a pile of dog food under the filter in the bottom of the housing. I always get a good laugh when I go back and look at that picture lol.
    Wahayes[QUOTED] likes this.
  10. Jul 9, 2021 at 7:21 PM
    #2920
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Loaded up and ready for tomorrow morning. A week long trip, sadly the furthest I've ever towed in 23 yrs, 320 miles away. I think the Tundra will open it up further though. Stopping for the night about midway. IMG_20210709_221643.jpg
  11. Jul 9, 2021 at 7:36 PM
    #2921
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Nice! Very little sag even with all of that load. Airbags or Roadmaster active suspension or something else?
    Have a great trip!
    16MagSR5[QUOTED] likes this.
  12. Jul 9, 2021 at 7:43 PM
    #2922
    16MagSR5
    16MagSR5 New Member
    Buffalo
    Air bags the previous owner installed. They have about 12lbs in them. A WDH too. I try to balance camper tongue with payload. Not much in the bed, but in the back of camper. It tends to be tongue heavy, so I compensate. It also has a GVWR of 7k, with a semi wet of 5k. So I have lots of wiggle room. I do my absolute best to stay as safe as I can, trying to use the 80% towing capacity rule.
    And thank you, I hope it is. My wife and I did our best to insure it :)
  13. Jul 9, 2021 at 9:29 PM
    #2923
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
  14. Jul 11, 2021 at 7:09 PM
    #2924
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    Before the bilstien upgrade and trans cooler.AD3D07B6-7A71-430B-B4F1-9BC0A2E006B0.jpg 7k lbs includes 80gal H2O.
    First test run. Need to get some side mirror extensions.
  15. Jul 11, 2021 at 7:15 PM
    #2925
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Looks pretty nice but all I can make out is "Mountain Series". What make and model?
    Dirtytruck[QUOTED] likes this.
  16. Jul 11, 2021 at 7:50 PM
    #2926
    Dirtytruck
    2021 SR5
    2019 Outdoors RV, 21FQS, off-road suspension package to boot
    Cpl_Punishment likes this.
  17. Jul 11, 2021 at 10:31 PM
    #2927
    Dirtytruck
    2021 SR5
    Your avatar is hysterical!
  18. Jul 12, 2021 at 6:03 PM
    #2928
    Retroboy1989
    Northern Utah
    Took a three day weekend and rented another trailer. It towed quite well. The 5.7 got a workout on the mountain passes in the 3-4k rpm range. Temp needles didn't move.
    I was dealing with intermittent "oL" and "SH" codes on the prodigy p2. Hoping it was the trailer and not my truck's wiring. Anyone have a cheap method for load testing the brakes on the road? Multimeter shows up to 12v, but that's not under load and not a road test. The issue while towing was intermittent and impossible to replicate. No real pattern.
  19. Jul 12, 2021 at 6:56 PM
    #2929
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I recently had the same problems with my trailer. 2 out of my four wheels had wires rubbing inside the brakes against the drum. Required removing the wheels, castle nuts, bearing, drums and fixing the wiring then zip tie them up out of the way
    b
    NUDRAT and HulkSmurf14 like this.
  20. Jul 12, 2021 at 7:44 PM
    #2930
    Retroboy1989
    Northern Utah
    From everything I've found online, 9 times out of 10 the problem is the trailer. That trailer was a rental and I made the owner aware of the issue. I'm just trying to find a way to make sure my truck is good to go for another trip.
    shoe07[QUOTED] likes this.
  21. Jul 12, 2021 at 8:15 PM
    #2931
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Exactly, love mine , will be upgrading to a bunk house next year as I have now a third baby , it will be around 21ft , thinking about the Winnebago 210bh
  22. Jul 13, 2021 at 9:03 AM
    #2932
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    21 GeoPro G20BHS. Fantastic trailer!
  23. Jul 17, 2021 at 8:42 AM
    #2933
    Samoan Thor
    I love my diamondback tonneau cover, yes I can store the bikes in the camper but it takes up room in there which we use often when we stop to use the bathroom on breaks or gas stops. Doesn’t take much from my payload, I also don’t have sway bars and tundra tows excellent with about 2/3 freshwater for bathroom breaks. About 1500 miles of towing, no problems.
    NUDRAT, Prostar 190, TunBrun and 5 others like this.
  24. Jul 19, 2021 at 7:30 AM
    #2934
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Our latest trip to Blue Lake, Ontario.
  25. Jul 19, 2021 at 9:29 AM
    #2935
    Mr. Wasteland
    Mr. Wasteland New Member
    2013 Tundra crewmax platinum
    M6040 Kubota on 24ft aluminum deck-over. Pic snapped prior to air bag inflation.20210706_132559.jpg
  26. Jul 21, 2021 at 1:41 PM
    #2936
    TundraMax12
    TundraMax12 New Member
    Dom
    2013 TSS Crewmax
    Reason for the Sequoia on the trailer? New toy?
    NUDRAT likes this.
  27. Jul 21, 2021 at 3:00 PM
    #2937
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    my 2020 tundra limited crew max 4x4 max towing is 8800lbs. sticker on door says i can do 1400 payload. i wouldnt recommend constant driving slightly over payload. if you go for a long weekend 2-3 hours away just drive smart. if your gonna be non stop traveling then get a bigger truck or smaller TT.
  28. Jul 21, 2021 at 3:17 PM
    #2938
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    take a look at the hemisphere hyperlyte 25RBHL... that is an awesome setup... 6000 empty max is 7600lbs tongue weight empty 640 with gear about 750 depending how you are loaded.
  29. Jul 21, 2021 at 3:29 PM
    #2939
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    No bunks?!
  30. Jul 21, 2021 at 4:19 PM
    #2940
    Lifer
    Lifer New Member
    Vince
    That is the wife's 2002 Limited. Basically just car pooling to our 2nd home. Her and the kids stayed up when I had to go back to work. I am considering throwing the 21 with 15 miles on it on the trailer and haul it up there too. That will make a picture!
    NUDRAT likes this.
