What are these?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Jul 19, 2021.
  1. Jul 19, 2021 at 8:26 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Tried searching through the threads with no luck. I had to pull the knee panel below the steering column, and saw two parts I'm not sure what they're for - first one is a small pin connector and second is a slotted thing with nothing behind it:
  2. Jul 19, 2021 at 8:29 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    That's where the driver side Temp sensor would be if you had automatic climate control instead of manual temp control on your A/C.
    GODZILLA likes this.
  3. Jul 19, 2021 at 8:31 AM
    18" TRD Off Road Wheels
    The slotted opening is for the in cab temperature sensor IIRC.
  4. Jul 19, 2021 at 10:05 AM
    RussellVaughan
    Houston
    makes sense! what about the pin connector? It's on the other side of the panel, so makes me think it's not related to the temp sensor.
  5. Jul 19, 2021 at 3:55 PM
    careyrob
    Carey
    Massachusetts
    There's also a tire pressure monitor reset button and a light for the driver foot well that are/can be connected to that panel. Both of them are to the right of the steering column though.
