Best power running board??
Discussion in 'General Tundra Discussion' started by CamaroSsToTundra, Jul 18, 2021.
  1. Jul 18, 2021 at 3:36 PM
    CamaroSsToTundra
    CamaroSsToTundra [OP] New Member
    Ohio
    2018 Tundra
    Hi I am looking for power running board around or under 1200. Let me know which one you got and how much was it?
  2. Jul 18, 2021 at 3:38 PM
    Loose
    Loose New Member
    2020 Platnium
    1200.00 installed?
  3. Jul 18, 2021 at 3:40 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    I can install by myself.
  4. Jul 18, 2021 at 3:40 PM
    Loose
    Loose New Member
    2020 Platnium
    AMP Research I believe to be the best out there. They will run you 1200.00 or so but you will have to install them. By bill was 1900.00 OTD installed.
  5. Jul 18, 2021 at 3:41 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Did you have any problem with them so far?
    Loose[QUOTED] likes this.
  6. Jul 18, 2021 at 3:41 PM
    Loose
    Loose New Member
    2020 Platnium
  7. Jul 18, 2021 at 3:42 PM
    Loose
    Loose New Member
    2020 Platnium
  8. Jul 18, 2021 at 3:43 PM
    Loose
    Loose New Member
    2020 Platnium
    Not a one...
  9. Jul 18, 2021 at 3:44 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Beast looks good thanks for the suggestion
  10. Jul 18, 2021 at 3:44 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    CamaroSsToTundra[OP] likes this.
  11. Jul 18, 2021 at 6:41 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
  12. Jul 18, 2021 at 6:50 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    i have the AMPs too, on my 2019. they work great, not a single problem since they’ve been on the truck
  13. Jul 18, 2021 at 8:39 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank you..
    I will say this to anyone reading this thread regardless of whom you buy your steps from;
    Amp steps come in one length, or at least they did when I bought them.
    If you have a double cab, you have to cut the steps to size.
    Measure the steps and your truck yourself before cutting them.
    I cut mine according to the Amp instructions without measuring myself.
    I wish I had made them a little longer...
    Also mine are tapped into OEM wiring.
    Use Posi-taps (instead of cheap t-taps) and make sure you get a connection because the stock wiring in the kick panel is very small gauge.
    Really got to work it to get a good solid electrical connection..
    And 1 more thing;
    The cheap little stick on LED lights that came with the steps are worthless.
    Invest in a good LED strip when you install your steps.
    I bought superbright metal strips, painted them to match the body color, and used a good 3M molding tape to attach to the truck...
    If I had it to do over again, I would buy these low profile strips.
    Probably wouldn't even have to paint them.
    Maybe a 4K light in 24", 1 per side...
    Waterproof Linear LED Light Bar Fixture - 390 Lumens | Super Bright LEDs
    Other than than, no issues in 4 years....
  14. Jul 19, 2021 at 10:54 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Anyone know how well they hold up in snow and ice like western NY?
  15. Jul 25, 2021 at 7:31 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Amps are the best. You always pay for what you get. I love mine but will be swapping them out for rock sliders next year.
  16. Jul 25, 2021 at 8:58 AM
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    what sliders ya thinking?
  17. Jul 25, 2021 at 10:19 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    most likely the Cali raised LEDs. I like how it covers the whole side from behind the front wheel weld to the front of the rear wheel weld. More coverage/more protection lol
  18. Jul 25, 2021 at 10:25 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I love my AMP’s. love them.
    My truck is a work truck and they get used and abused all day every day in and out of that truck constantly for 3 years.
    Kgfit85 likes this.
  19. Jul 25, 2021 at 11:00 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Another AMP Research Powerstep user. Love them. They are a bit louder than ones installed on OEMs. Mine are the dual motors, which I paid $1,200 for and installed them myself. Unfortunately, one of the wires for the motors was switched so I had to invert them. Could not understand why, at first, my passenger side looked like it was struggling as I could hear the motors activate.
    Jeez, I didn't realize they would raise the prices on these. That is ridiculous, if they are the single motor ones.
    Quick question, I notice you got the DC version, did you cut your boards or did they come that way?
    EDIT: Nevermind, saw your follow up post. I see that you mentioned you cut them. Sorry!
  20. Jul 25, 2021 at 3:07 PM
    First World Problems
    First World Problems New Member
    2021 Tundra TDR Pro - Lunar Rock
    I love mine. I’ll be putting a set on my next truck. I paid just under $1300 shipped for my Tundra set from TonneauCovered.com which was the best price I could find at the time.
    Install wasn’t particularly difficult but since I’m OCD it took a little while to get it all installed and all wires tucked away. Definitely spring for the extra override switch. It is a must.
    AJGallo41 likes this.
