  1. Jul 11, 2021 at 4:25 PM
    #7021
    Orracle
    Orracle New Member
    Canton, GA
  2. Jul 11, 2021 at 7:47 PM
    #7022
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    When I add the hitch, I plan on adding the cooler too. But I’m gonna put 37’s on 24’s with an 8” Ready-lift on it first.
  3. Jul 11, 2021 at 7:53 PM
    #7023
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    But wouldnt that hurt your mpg:boink:
    AZTundra, Fotnot and TaquitoBandito like this.
  4. Jul 11, 2021 at 8:05 PM
    #7024
    TaquitoBandito
    Joel (AKA Bif)
    And some Raptor style lights...
  5. Jul 11, 2021 at 8:09 PM
    #7025
    RainMan_PNW
    Casey
    Clark County, WA
    Oh yeah…good thinking!
    I’m gonna need ditch lights and rock lights on it too.
    It does already have a locking diff though! ;) :boink:
  6. Jul 11, 2021 at 8:10 PM
    #7026
    RainMan_PNW
    Casey
    Clark County, WA
    Depends - if I put a Hypertech in it, then I’ll actually know the real MPG.
  7. Jul 13, 2021 at 6:43 AM
    #7027
    I'm once again asking for your advice....
    I have 4 corners like this where my house is lacking any kickout flashing. Naturally, I've found wood rot in at least 2 of those corners where water was going down the siding instead of into the gutters. I've been reading about installing kickout, but I'm not clear how I can do that without removing the hardie plank.
    And no, I didn't add those giant globs of caulk. That was my gutter installer. :rolleyes:
    I think I can slide a piece of flashing under the hardie, but I'm not sure if that will open myself up to more issues. Would love some feedback from the group.
  8. Jul 13, 2021 at 6:59 AM
    #7028
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm almost POSITIVE that is supposed to go under the shingle and hardie board.
    NewImprovedRon likes this.
  9. Jul 13, 2021 at 7:07 AM
    #7029
    @Fotnot From the videos I've seen I think you're correct but they also installed it first, then the siding. I didn't see anyone that was able to just slide it up under existing siding. I think the Hardie plank is laid from the top down so just removing one piece doesn't seem likely. Water is currently trickling back into the fascia so I've got to fix this. May have to get creative with how I do it.
    This is what should have been done.
    NewImprovedRon and Fotnot like this.
  10. Jul 13, 2021 at 8:11 AM
    #7030
    RainMan_PNW
    Casey
    Clark County, WA
    So the flashing along the roofing is supposed to be a step flashing. Each piece is laid under a single row of roofing, so the one in the left of this picture is on top of the first row of shingles but under the second one. Sort of like weaving.
    FortyNorth likes this.
  11. Jul 13, 2021 at 10:21 AM
    #7031
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    This. That little white angle coming out from under the hardie is essentially doing nothing and water is just flowing right under it and into your wall if there isn't any step flashing behind there.
  12. Jul 13, 2021 at 10:59 AM
    #7032
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Slowly but surely I’ve been getting the basement finally finished. Finally got the walls painted in the main room and started the LVP flooring earlier today. Other pics are buried deep in the thread somewhere :rolleyes:
    Lucky for me, as I was placing my last board this morning I caught the tip of my finger with the mallet. Good times, good times… o_O
    A981A07F-5798-4E18-97D5-78A79DB21EC4.jpg B195F482-2A87-43BD-BE81-623137853BF7.jpg
  13. Jul 13, 2021 at 2:24 PM
    #7033
    truckguy84
    truckguy84 New Member
    2011 Black Tundra SR5 TRD
    Finally done with my new deck. Old one had to come out, was really old and house wood was rotten were it meet the old deck.
    was a lot of work but well worth it.
  14. Jul 13, 2021 at 2:42 PM
    #7034
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    :woot:
    truckguy84[QUOTED] likes this.
  15. Jul 13, 2021 at 3:29 PM
    #7035
    Buckeye1977
    Buckeye1977 New Member
    What was the black stuff on top of the floor joists? And was was the purpose? Looks like it was a water proof membrane?
    looks good btw
    truckguy84 likes this.
  16. Jul 13, 2021 at 3:33 PM
    #7036
    Buckeye1977
    Over the weekend my moms houses needed regraded after 50 years of mulch and trees being removed. My BIL did the grading and I surprised mom with new plants on my birthday!?
    aperezsh, saybng, Baja Mike and 10 others like this.
  17. Jul 13, 2021 at 3:37 PM
    #7037
    vl184009
    Vicky
    Southern, Ca.
    You are a good soul!
  18. Jul 13, 2021 at 3:37 PM
    #7038
    truckguy84
    Thanks
    Waterproof Barrier Protection
    When this tape is applied to the top of decking joists, over ledger boards, and around support posts, it creates a waterproof seal that helps stop decay and wood rot. Rot is caused by moisture that stays in contact with treated and untreated lumber deck framing and the above decking material.
    TaquitoBandito, YorkT, Fotnot and 2 others like this.
  19. Jul 13, 2021 at 4:11 PM
    #7039
    Buckeye1977
    Excellent learned something new and it makes sense!!
  20. Jul 13, 2021 at 8:51 PM
    #7040
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What kind of decking is this? And does your township require permits for building decks?
  21. Jul 13, 2021 at 9:18 PM
    #7041
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Continuation from 7249. They got the house wrapped but no HVAC work done, so it seems like a slow week. A photo of DW and my vert, plus the crawl space and6520639B-A8C3-4073-926F-BF89329101BC.jpg 25A20C66-D217-491B-9325-52A97940D10C.jpg 428BEF15-5679-4F8C-A195-1790DC5915C7.jpg 78A6D901-1478-4EFF-8286-BBCA0B7BBA11.jpg 8A51DE09-C577-44EE-BB00-FD7E4D7647B8.jpg 2E699AD4-499E-40AC-8D61-6D3D19A32CF5.jpg plumbing. My current home crawl space is literally that, on your knees and belly.
  22. Jul 14, 2021 at 4:31 PM
    #7042
    truckguy84
    It’s IPE hardwood decking.
    saybng and RainMan_PNW like this.
  23. Jul 14, 2021 at 7:03 PM
    #7043
    Speydragon
    Speydragon New Member
    Oar-E-Gun
    Digging out bamboo. The joy!
    TaquitoBandito and Fotnot like this.
  24. Jul 16, 2021 at 1:57 PM
    #7044
    I agree. I'm just not sure how I install this without completely removing the hardie.
  25. Jul 16, 2021 at 2:10 PM
    #7045
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Work started on the a patio extension
    saybng, Fotnot, T-Rex266 and 5 others like this.
  26. Jul 16, 2021 at 3:37 PM
    #7046
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Trying to map out some sort of peanut shaped looking concrete patio for a table set and firepit. Was gonna the table on the left (about 12ft) circle and fire pit on the right (about 14ft) with a 36” pit in the middle. Then swap the flagstone for pavers. Any thoughts?
  27. Jul 18, 2021 at 12:33 PM
    #7047
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Scored a 5 channel passive soundbar for $100 off marketplace. It’s the Polk Surroundbar 50. Should work out as a good compromise to having the full 5.1 setup I used to have. Not the right space for full tower speakers like I had before. Got all the cable pulled for speaker bar and tv through the smurf tube. Got tv remounted and bar in place, now to just get everything hooked up and working to the home theater receiver again! Sub will go in the corner behind the av rack of gear. Might put my second sub behind the couch for some additional kick but having laminate floor and vaulted ceilings vs carpet and 8ft ceiling at the old house, it may not be needed. Quite a bit of reverberation due to the hard floors vs carpet. Will also be reattaching the speaker grill most likely
    T-Rex266, Fotnot, Yzed608 and 5 others like this.
  28. Jul 18, 2021 at 10:21 PM
    #7048
    WAtundra4x4
    Den
    Wet side WA
    Continuation from 7299. Windows were installed and the HVAC equipment installed. Some additional plumbing of water and gas lines also. Cable TV/ internet routed. Front door was also put on. Progress. E334D3B8-B994-47D9-A4E6-438781AC77BB.jpg 8D81C064-D6B1-4546-8528-06F4503F1548.jpg F7605CE9-6A90-479D-82C2-E242F94976DA.jpg 5E8F8226-425F-419F-806D-6AA4F5998B64.jpg A8223391-3FDA-4A01-83BF-3B1E05A3F84B.jpg 0860CA62-992A-4E0B-89D9-3C1A12FF4406.jpg 79712469-D5EF-4450-B5F3-82DF87174591.jpg 91DDE97F-4484-4570-AAA8-17671C82190D.jpg
    Fin
  29. Jul 19, 2021 at 3:46 AM
    #7049
    Kung
    KG, VA
    Went through this several years back...it just so happened that my Dad, a friend of mine, and my pastor (who was also an electrician) was helping. Was swinging the hammer (one of those big framing suckers) and hit my left thumb *dead* to rights.
    Immediately stood up, trying not to swear with EVERYTHING I had in me...and with tears glanced @ the pastor, who had this huge smile on his face as if to say "I KNOW what you're gonna say...."
    A few seconds later I said ".....darn?" He collapsed on the floor in laughter and said "I KNOW that ain't what you were thinking!" :rofl:
    He said a few minutes later that HE would have cussed a blue streak had he hit his thumb like that.
  30. Jul 19, 2021 at 1:38 PM
    #7050
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Nothing special but hung a TV outdoors :cheers:
    T-Rex266, AZTundra, Fotnot and 2 others like this.
