Hi!
Discussion in 'New Member Introductions' started by palijim, Jul 15, 2021.
  1. Jul 15, 2021 at 12:34 PM
    palijim
    palijim [OP] New Member
    I have a cherry 2006, Limited long bed which I love . Has 36,000m with alot of time in the garage. IS the timing belt something I really need to replace at this time?
    YardBird likes this.
  2. Jul 15, 2021 at 12:37 PM
    18" TRD Off Road Wheels
    Gravy, chrisb and Darkness like this.
  3. Jul 15, 2021 at 12:38 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Nice score on a low mileage truck!
    Id drive it, but "Im not a roll model"
    With 36k on the clock, id drive it until mileage said so.
  4. Jul 15, 2021 at 12:38 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    A 2006 with 36,000 miles? You need to post pics!
    Even with low miles, an original timing belt introduces risk. It all depends on your comfort level. Personally, I would replace it.
    ToyoMafia, 2mchfun and Darkness like this.
  5. Jul 15, 2021 at 12:49 PM
    Welcome from NY.
    ToyoMafia likes this.
  6. Jul 15, 2021 at 1:08 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  7. Jul 15, 2021 at 1:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Jul 15, 2021 at 1:52 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Jul 15, 2021 at 1:53 PM
    palijim
  10. Jul 15, 2021 at 1:56 PM
    palijim
    On the 2006 the dealer says 10 years or 90,000 miles to replace the timing belt.
    2mchfun likes this.
  11. Jul 15, 2021 at 1:59 PM
  12. Jul 15, 2021 at 2:00 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    It is not the miles, it is the age. Replace it.
    If it breaks on you that beautiful truck will become a large paperweight until you can find a new motor or have yours rebuilt. Replacing it would be $ well spent.
  13. Jul 15, 2021 at 2:05 PM
    Based on age I would replace the timing belt if it's never been done. Best to have them replace the timing belt tensioner and water pump too.
  14. Jul 15, 2021 at 2:20 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I believe that the mileage recommendations are made with consideration that a vehicle would be driven daily. 90k miles would take six years to accumulate for an average driver. Using that as a loose guide you are 9 years overdue.
    I would have the timing belt and water pump job done. Consider it an investment. At $1200-1500 it is a good investment vs replacing a (very low mileage) motor and stepping into the ballpark of $6k and the issues that often come from a replaced motor.
    Thats a beautiful truck. Congratulations, take good care of it as that is practically made of gold.
    chrisb and 2mchfun like this.
  15. Jul 15, 2021 at 2:27 PM
    2mchfun
    Welcome to the forum, as said above, age is a huge factor. I'd not only do timing belt, all belts and important hoses such as heater hoses, radiator hoses, etc. Might want to check out spare tire age too
    Darkness and chrisb like this.
  16. Jul 15, 2021 at 2:37 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    That motor is basically irreplaceable. You won't find a used one with miles that low and a rebuild is significantly more expensive than a t-belt job.
    Do that preventative maintenance and then laugh heartily at the rest of us as your time-capsule truck is still breaking in while ours are getting long in the tooth.
    She's a beaut! Take good care of it and it'll take great care of you.
  17. Jul 15, 2021 at 2:48 PM
    palijim
    Thank you all very much for the advice.
    YardBird, Darkness and 2mchfun like this.
  18. Jul 15, 2021 at 3:45 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Beautiful truck, for that age especially. I would replace the timing belt just because of the age if it were me. If the dealer said "10 years or 90,000 miles" then it would default to the least which would be "ten years".
  19. Jul 15, 2021 at 3:54 PM
    palijim
    Might sell it and buy a 2021 tundra. it will be my last truck.
  20. Jul 15, 2021 at 3:56 PM
    If that thing is as mint as it appears then you'll get top dollar and it'll sell in a day or two. Do lots of research on what they go for before you price it. In today's market, you'll clean up for sure.
  21. Jul 15, 2021 at 4:09 PM
    Gravy
    Gravy Cat herder, ASCM #Ď€
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal
  22. Jul 15, 2021 at 4:36 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  23. Jul 15, 2021 at 4:58 PM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
  24. Jul 15, 2021 at 5:10 PM
    2mchfun
    PM me with your asking price if you decide to sell it.
  25. Jul 15, 2021 at 5:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    First off welcome!
    to answer your question about the t-belt ideally it should be replaced every 6-10 years or 90k (dryer climates will be closer to a 6 year interval) Rubber drys out over time and this can lead to failure of the belt.
    if you were to sell now is indeed the time, but honestly, that things still practically new and financially would be a better move to keep. But obviously it is dated and a new truck would bring you to a modern world of automotive comfort.
    GODZILLA likes this.
