Bushings or whole control arms?
Discussion in '1st Gen Tundras (2000-2006)' started by mbreed2, Jul 14, 2021.
  1. Jul 14, 2021 at 1:24 PM
    mbreed2
    mbreed2 [OP] Is not right
    Allentown PA
    2001 Tundra 4x4
    I see complete after market lower control arms for half the price of a set of new OE bushings from Toyota parts online.
    What have you all done? Any regrets?
  2. Jul 14, 2021 at 1:26 PM
    When I do mine, I'm buying new control arms. I've done the cut, burn, pry and hammer old bushings out, and it's not fun.
    bmf4069, Hi06silver and des2mtn like this.
  3. Jul 14, 2021 at 1:31 PM
    2mchfun
    I'll be going oem LCAs with oem ball joints. Very much an important component. Pretty much life or death.
  4. Jul 14, 2021 at 1:35 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I bought new OEM control arms when my old bushings were shot, along with new OEM LBJs etc. Everything went back together easy-peazy and my truck performs great. No regrets.
    I've read plenty from others replacing the bushings is trouble. Depending on your rust situation, you may have to cut out the alignment bolts and replace them as well. Can't speak for reliability of aftermarket LCA's.
    Glock 40 likes this.
  5. Jul 14, 2021 at 1:37 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I replaced both LCAs... no regerts. Depending on the condition of your eccentric bolts, you may have to replace those while you're there. If they're frozen on (as is usually the case) a Sawzall with a Diablo carbide blade will make short work of it.
    des2mtn and Jack McCarthy like this.
  6. Jul 14, 2021 at 1:38 PM
    Stay away from Mevotech LCAs. Complete junk with bushings that don’t last.
    OEM and Moog are the ones I’ve seen people use.
  7. Jul 14, 2021 at 1:40 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Moog have been serving me well.
    KNABORES likes this.
  8. Jul 14, 2021 at 1:52 PM
    If the cam bolts aren't seized, is there any need to replace them or can one reuse them? Mine don't have any rust on them like I've seen from others.
  9. Jul 14, 2021 at 2:01 PM
    2mchfun
    You can reuse them for sure.
  10. Jul 14, 2021 at 2:02 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    All I know is I have had my truck aligned twice. And both times the tech have had a problem with the adjusters. Also, I get bad steering wheel wobble at highway speeds.
  11. Jul 15, 2021 at 4:45 AM
    des2mtn
    Shady Grove
    Tonto cover
    I reused mine. There was minimal rust on mine, but I ground it off and rubbed anti-seize all over them.
  12. Jul 15, 2021 at 4:57 AM
    des2mtn
    Shady Grove
    Tonto cover
    Is it the same tech/ place that aligned your truck twice that says they're having problems with the adjusters? If so, I would get a third opinion. Have the tires been rotated regularly?
    I don't think there's anything wrong with your adjusters personally, but these are the adjusters many people end up going with aftermarket. Note, one kit is only for one side. https://www.summitracing.com/parts/SPS-25445
    Sunnier likes this.
  13. Jul 15, 2021 at 7:19 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Two different shops. The tires are shot. I'll be getting new tires, but not before Im sure the suspension and alignment is good. I'm going to jack it up and try to wiggle the lowers with a pry bar before I order anything.
  14. Jul 15, 2021 at 7:28 AM
    koditten
    Kirk
    Midland of the Mitten
    If they are having trouble with the adjusters, that's just another way of saying the cam bolt bushings are sized. The only thing they can adjust is the tie rods. You are not getting what you paid for.
    Cut out the old bolts and replace along with control arms and LBJ's then get it aligned.
  15. Jul 15, 2021 at 8:05 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Again, half the price of OE. These look like junk though. They are really popular?
    onesojourner likes this.
  16. Jul 15, 2021 at 11:12 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  17. Jul 15, 2021 at 11:18 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Make sure that you mark the existing alignment on your old bolts before removal so that you can install the new ones relatively close to where the old ones were. I use White-Out for this. You'll still need an alignment (obviously) but this will make it easier for the shop.
    FirstGenVol likes this.
  18. Jul 15, 2021 at 12:12 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Thanks, I like those Moogs better. Not sure if hollowing out the bolt for the grease weakens it enough to be worried about though.
  19. Jul 15, 2021 at 12:48 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'm pretty abusive with this truck offroad and haven't busted one yet. Lord knows I've tried. I do some stupid shit.
    mbreed2[OP] likes this.
