  1. Jul 14, 2021 at 7:42 PM
    :thumbsup:
  2. Jul 14, 2021 at 7:45 PM
    French Avocado
    Utah / Wyo
    Start small and all succeeding mods will increase in price!! Congrats
    dbldutch[QUOTED] likes this.
  3. Jul 14, 2021 at 7:51 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Installed two one-hundred watt solar panels under the Front-Runner.
    Swapped out my old headlights for the 2019 OEM LED versions.
    Installed rocker switches.
    Pending install: power distribution tray, Bussman relay box, Baja designs ditch lights, KC Gravity LED Pro6
  4. Jul 14, 2021 at 8:26 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Factory is about +50. +17 will stick out a little over an inch but also depends on tire width
    Brettstation37 likes this.
  5. Jul 14, 2021 at 8:30 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    the rear makes more of a difference but I replaced my stock front with the TRD bar and it helped even more with body roll.
    AggiePhil likes this.
  6. Jul 14, 2021 at 8:35 PM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    :rofl::rofl::rofl:
  7. Jul 14, 2021 at 8:39 PM
    El Two
    Lisa
    Yup, especially with the loctite.
    Dsptundra[QUOTED] likes this.
  8. Jul 14, 2021 at 8:55 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Big ol curb rash on my methods. FML!
    TucsonTundra1794 likes this.
  9. Jul 14, 2021 at 8:58 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :eek2:
  10. Jul 14, 2021 at 9:12 PM
  11. Jul 14, 2021 at 10:02 PM
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    A little more progress on a delayed project.
  12. Jul 14, 2021 at 10:38 PM
    AZTundra
    Paul
    Phoenix, AZ
    Very clean.
    DCB500[QUOTED] likes this.
  13. Jul 15, 2021 at 4:43 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Ouch! Bet you had a few choice words when that happened
  14. Jul 15, 2021 at 7:07 AM
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    Thanks!
  15. Jul 15, 2021 at 8:01 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Finishing what I started last week…
    reneaux, Wallygator, GAknight and 7 others like this.
  16. Jul 15, 2021 at 8:27 AM
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    We heard you like skid plates, so we put a skid plate on your skid plate!
  17. Jul 15, 2021 at 8:55 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Last week, did the maintenance on my front and rear differentials and transfer case. My first time doing it so took my time...had a great time doing it. I, also, got the lube gun out and got all 5 lube points very well. Learned a neat trick...leave the truck in Neutral (emergency brake on and chalk the wheels) and then you can spin the axles to get to the right spot. The worst one was to the left of the transaxle...just NO room to maneuver in there but, finally, got the zerk fitting in and got her done.
    Next job is transmission filter/fluid drain and fill...got everything from my dealership, just need to get a day off work when the Mrs. doesn't have a huge TODO list for me....
    Wallygator, GAknight, Booney and 3 others like this.
  18. Jul 15, 2021 at 8:59 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    in terms of the trans drain/fill....why are you doing it? i'm not knocking, just seen/read mixed things on whether to do it or not. also...how much fluid did you get for it? i've heard those that do a simple drain/fill its only a few quarts (5 i believe) and those doing a drain/flush will need about 12 quarts. thanks for info.
  19. Jul 15, 2021 at 9:08 AM
    ColoradoBoo
    Rick
    I've always kept my Toyota's as long as possible, so do engine oil/filter every 6 months. Transmission (non CVT) gets serviced every 60,000 or 6 years. CVT trannsmissions get serviced every 40,000 or 4 years. Diffs/Transaxles get changed every 30,000 or 3 years. Radiator coolant is (first) at 100,000 or 5 years then every 50,000 or 5 years.
    There's no such thing as "maintenance free" unless you don't intend on keeping your vehicle very long.
    These services are ridiculously expensive, including brakes so I've learned to do them myself over the years and enjoy it! (I'm a computer/systems engineer at my paying job.)
  20. Jul 15, 2021 at 9:47 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i do all my own maintenance and enjoy doing them. transmission has had me second guess. but recently getting information means i'm going to be getting rid of the tundra and getting something like a new sequoia in 2023 or possibly a yukon xl.:notsure:
    Wallygator likes this.
  21. Jul 15, 2021 at 10:10 AM
    GatorBodine
    GatorBodine New Member
    Got line-x sprayed in the Bedliner this morning.
  22. Jul 15, 2021 at 10:21 AM
    Ordered Cupholderhero inserts for the truck and the 4Runner.
  23. Jul 15, 2021 at 12:12 PM
    IceTundra
    IceTundra New Member
    The Dude
    TWO FIVE THREE
    2020 Tundra Pro
    Some...
    +1 for the mountain bikes!
    aelarson[QUOTED] and jpod like this.
  24. Jul 15, 2021 at 12:16 PM
    18" TRD Off Road Wheels
    Is this information of the "bun in the oven" variety? If so, Congratulations!
    If not, I am confused. :confused:
  25. Jul 15, 2021 at 12:30 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    if she didn't have the buns she has, we wouldn't be baking our 4th bun right now:notsure::thumbsup:
  26. Jul 15, 2021 at 12:34 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    D9B451AA-3643-497F-80FB-71639C72EE5A.jpg Color matched bumper end caps. CCEEE339-60E2-425F-A9AC-9B5A31D757C6.jpg
    RRR1C0, kbark, Wallygator and 12 others like this.
  27. Jul 15, 2021 at 12:35 PM
    You say 4th, but what if it's twins... or triplets. :devil:
  28. Jul 15, 2021 at 12:53 PM
    Taco-Spike
    Two Trucks
    Savage
    dpast88, bflooks, woods and 2 others like this.
  29. Jul 15, 2021 at 12:54 PM
    It'll be his penance for abandoning the Tundra.
  30. Jul 15, 2021 at 12:56 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
