How big is yours? Measure up!
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, May 15, 2019.
  1. May 19, 2021 at 4:37 AM
    #61
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, I replaced the whole assemblies last July with Bilstein 5100's, and Dobinsons C59-302 springs.
    Here's a link to 1stgenoffroad coilovers, and a link to the Dobinsons ¼" shim.
    onesojourner[QUOTED] likes this.
  2. May 19, 2021 at 12:49 PM
    #62
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Not sure if its the 6112 or 5100 but some bilsteins have you set the clips at different heights to account for the lean, so maybe they are flipped around? You could check the perch chart and count the clip height on both sides to check
    Tundra2[QUOTED] likes this.
  3. May 19, 2021 at 3:09 PM
    #63
    While setting the clips at different positions may appear to fix the lean, it will make the preload on the springs different on each side causing potentially unpredictable handling and uneven tire wear. I do not believe it is recommended to do so. I believe the shim is the fix, if it bothers you enough to do so.
    Weagle and Tundra2 like this.
  4. May 19, 2021 at 3:18 PM
    #64
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I paid 1stgenoffroad for assembly of these so I could just install them when the time came. They weren't marked driver/passenger side. I just plopped them in and hoped for the best. The ride is pretty good to me.
    I don't think I want to get into adjusting the clip setting for various reasons, and an inch worth of spacers doesn't seem like the best approach. Hell, I was hesitant to put the 1/4" spacer in. :rofl:
    I have no reason to believe they were assembled incorrectly, but it's possible I suppose. Would how much the shock stud is sticking through the top matter? That's about the only way I can figure to measure for differences with them installed.
  5. May 19, 2021 at 4:04 PM
    #65
    jImmegart
    Jonah
    California
    Ya maybe, but I cant think of why one side studs are shorter. Maybe the top hats are different or something is obstructing it from the underside
  6. May 23, 2021 at 7:25 AM
    #66
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Bone stock with sagging bushings im at 20” front, 22”rear (empty with 1/4 tank of gas.)
  7. May 23, 2021 at 8:44 AM
    #67
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    22.75” Front
    23.50” Rear
    Toytec Boss Coil overs
    JBA Off-road UCA’s
    Rear 2” lift block
    5100’s
    OEM Leaf Springs
    33x10.50R17 Kenda Klevers
    17x8.5” Vision Manx Wheels
    onesojourner likes this.
  8. May 23, 2021 at 10:30 PM
    #68
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    22 1/4" up front
    23" out back
    Bilstein 5100s with ARB 885 springs and camburg arms
    Icon 3 leaf AAL with overload still in place and 5100s out back
    on 255/80r17 cooper ST maxx tires
    the front rubs my mudflaps.. thats about it.
  9. Jul 15, 2021 at 7:16 AM
    #69
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
    Just added the 5100s on all 4 corners and put the front stocks in the middle (third from the bottom) and came up with the following: Front: 21" and Rear: 22.5".
    This is using the OEM springs from the OEM KYB shocks I took off that had 156K miles on them.
    bmf4069 and onesojourner like this.
  10. Jul 15, 2021 at 8:29 AM
    #70
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Front: 23" with 3" spacer lift, stock springs. Have aftermarket bumper and winch.
    Rear: 24" with Roadmaster Active Suspension set with dime width.
    35x10.0R17 Super Swamper TSL/SXII tires on Vision Manx398 17x8.5" -15ET cast bead lock rims.
  11. Jul 15, 2021 at 9:19 AM
    #71
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    But thats not a first gen
  12. Jul 15, 2021 at 9:40 AM
    #72
    empty_lord
    05 rollover special
    I can accept a rcsb
    jImmegart, Bikeric and Darkness[OP] like this.
  13. Jul 15, 2021 at 10:25 AM
    #73
    But it does look pretty good.
  14. Jul 15, 2021 at 10:29 AM
    #74
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I agree, even though it isn't black thats a damn good looking truck. I do like the rcsb ones.
    jImmegart and Bikeric like this.
  15. Jul 15, 2021 at 10:31 AM
    #75
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
  16. Jul 15, 2021 at 10:38 AM
    #76
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  17. Jul 19, 2021 at 9:09 AM
    #77
    Alltimehigh
    Alltimehigh New Member
    This is correct.
    Ive got 5100's all around on the 4th notch with 285/75/16 tires. 2004 2WD Access Cab.
    Im at 21.5 front and back.
  18. Jul 20, 2021 at 12:13 AM
    #78
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Took measurements of my 2wd. Just under 1/2 tank with almost no weight in the rear (backflip tonneau cover, plastic bed liner and a piece of wood across the rear bed liner slots).
    LF: 19 3/8"
    RF: 19 1/2"
    Rear: both 21 1/4"
    des2mtn and onesojourner like this.
  19. Jul 20, 2021 at 10:06 AM
    #79
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My 16’ Tacoma was 1.75” dropped to the drive side rear after I lifted it. I added a 1/2” shim spacer to the drive side leaf pack, and a 1/4” spacer to the top of the drive side coil over and it leveled out the truck pretty well.
    You just have to make sure the front won’t over extend and bind the CV Shaft.
  20. Jul 20, 2021 at 10:36 AM
    #80
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    slight giggle everytime this thread comes back up….leave it to @Darkness
    :burnrubber:
  21. Jul 21, 2021 at 12:06 AM
    #81
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I kind of want to level my truck out now that I know the lean and rake. Went down the research rabbit hole looking for possible OEM combos.
    Tundra AC springs:
    48131-AF170 = 340.0 2wd R
    48131-AF430 = 339.5 2wd R
    48131-AF470 = 333.0 2wd R
    48131-AF180 = 344.0 2wd L
    48131-AF440 = 343.5 2wd L
    48131-AF480 = 336.5 2wd L
    48131-AF410 = 358.5 4wd R
    48131-AF510 = 351.5 4wd R
    48131-AF420 = 363.5 4wd L
    48131-AF520 = 356.5 4wd L
    Tundra DC springs:
    48131-AF250 = 344.5 2wd R
    48131-AF290 = 352 2wd R
    48131-AF260 = 348 2wd L
    48131-AF300 = 355.5 2wd L
    48131-AF270 = 356 4wd R
    48131-AF310 = 363.5 4wd R (off road pkg)
    48131-AF280 = 360.5 4wd L
    48131-AF320 = 369 4wd L (off road pkg)
    Sequoia Limited springs:
    48131-AF370 = 363.0mm 4wd R
    48131-AF390 = 357.5mm 4wd R w/air
    48131-AF380 = 371.5mm 4wd L
    48131-AF400 = 365mm 4wd L w/air
    48131-AF340 = 365mm 2wd L
    48131-AF360 = 357.5mm 2wd L w/air
    48131-AF330 = 356.5mm 2wd R
    48131-AF350 = 349.5mm 2wd R w/air
    Anyone mind measuring the coil diameter (in mm with a caliper) of a 05+ DC and/or Sequoia? Knowing the diameter will give me an idea if the spring rate is significantly more (or not).
    Darkness[OP] and bmf4069 like this.
  22. Jul 21, 2021 at 5:53 AM
    #82
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    An ‘04 sequoia spring wire is 17mm
    ‘02 ac billy is 18mm
    3rd gen taco billy is 19mm
    assassin10000 likes this.
  23. Jul 21, 2021 at 10:05 AM
    #83
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Cool, thanks. Is the Sequoia a limited model and lastly mind counting the approximate # of coils?
    I need to bring my calipers home and check my Tundra.
  24. Jul 21, 2021 at 10:10 AM
    #84
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, its a limited, rwd .
    sequoia has 8, tundra has 8, and taco has 9
    Tundras are progressive, closer coils on top, sequoia and taco spacing is even.
    Darkness[OP] and assassin10000 like this.
  25. Jul 21, 2021 at 10:43 AM
    #85
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    My 05 has 8 coils and 17.8mm O.D., they also don't appear to be progressive.
  26. Jul 21, 2021 at 10:44 AM
    #86
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Anyone figured out the color code for the dots? They may refer to length and/or side.
  27. Jul 22, 2021 at 9:00 AM
    #87
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I remember seeing a list somewhere, a search revealed this link. The info corresponds with .
    2000-06 Tundra Stock 4X2: Drivers: yellow-white, Passengers: blue-white
    2000-06 Tundra Stock 4X4: Drivers: yellow-green, Passengers: blue-green
    2000-06 Tundra TRD 4X4: Drivers: yellow-yellow, Passengers: blue-yellow
    2000-06 Tundra TRD 4X2: Drivers: red-yellow, Passengers: purple-yellow
    My 2002 stock 4x2 springs match the above info. I believe if you go with aftermarket springs, it will result in a slight front lean to one side. This spacer is designed to correct that.
  28. Jul 22, 2021 at 9:15 AM
    #88
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This thread needs way more pics.
    bmf4069 and chrisb like this.
  29. Jul 22, 2021 at 9:33 AM
    #89
    Lil Steve
    Gilbert, AZ
    Fixed'dit.
  30. Jul 22, 2021 at 9:59 AM
    #90
    Lil Steve
    Gilbert, AZ
    First pic is around when I first bought my Tundra, stock everything. Second pic is as it sits today, 5100's all around, fronts on the 3rd clip, ATS HD rear leaf springs 4/1. Before the ATS springs, rear measurements were 21.5" on the drivers side rear and 21 3/4" on the passenger side rear, right after install it sat at 23 1/4" on each side. After several thousand miles it's settled at 23" both rear center hub to fender edge. I never took measurement up front before going with the 5100's, the fronts are currently 21" drivers side and 21 1/4" passenger side.
    whittkl4, DarkMint, bmf4069 and 2 others like this.
