2020 TRD PRO Skid Plate
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by dkahs05, Jul 15, 2021.
  1. Jul 15, 2021 at 8:37 AM
    dkahs05
    dkahs05 [OP] New Member
    2020 Tundra TRD PRO
    Just found this out the other day while getting my oil changed at the Toyota Dealership. I have been having a popping noise from the front end of my truck for a while now. I have 46,000+ miles on my truck. And was told once before that it was the skid plate because it is removed each time they changed the oil and filter. So the other day after they got done with my truck and the tech. brought it back around and parked it, he heard the popping sound, he walk around the truck checking the lug nuts scratching his head. I walk over to him and said "You hear that popping sound too." he said "Yes" I said, "its been doing that for a while." he said "Let me do some research." And came back and said that the locking nuts need to be replaced every time you take the skid plate off. So he pulled up the part number PT938-34140-HW which is for the service hardware kit that runs from $85 to $118. I said "you got to be fucking kidding me?"The service manager has a TRD PRO and he said I guess I will listen to the popping noise. So I guess its a issue that the service dept. didn't know anything about. Because none of them change the locking nuts out. See the attach images for the service installation.
  2. Jul 15, 2021 at 8:40 AM
    Markh314
    Markh314 New Member
    Mark
    2016 Magnetic Gray TRD Pro
    Current Mileage: 82K as if Nov2021 Undercover RidgeLander Tonneau Cover w/ Rack System ReadyLift 2" SST Lift LT295/70R18/10 Nitto Ridge Grapplers
    Yep, i have it too on my 2016. Gotten used to it :facepalm:
  3. Jul 15, 2021 at 8:43 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    They are taking you for a ride. Why would they take off the TRD skid plate for an oil change? It is designed with an access door specifically so they dont have to take the whole plate off for an oil change. You are getting the popping noise likely because the hardware isnt torqued to spec. What i did for mine was torque everything properly, additionally, i put some weatherseal around the bolt to frame contact points and never heard a peep since.
    Vin63, Bad Cow, Markh314 and 3 others like this.
  4. Jul 28, 2021 at 8:21 PM
    Turtle88
    Turtle88 New Member
    2018 Tundra - Platinum - 3/1 level kit - Fuel Crush 18” / 285/75/18 NRG - Stubby Antenna - TRD Skid plate - NSV light bar - Fuel Crush Wheels - 285/75 R18 Ridge Grapplers - Rear Sway Bar - Tinted Windows - Halo 9 head unit with Focal Speakers, (2) 10" subs and sound deadening throughout the cab - LED interior bulbs - Removed chrome and replaced with color matched mirror caps and black door handles - TRD Shift Knob - Storage unit under rear set - 3/1 Toytec leveling kit - line x bed liner
    Shouldn’t have to remove the skid plate for an oil change, that’s another story.
    I had this same issue, to resolve this I placed a thin/narrow piece of high density rubber between the frame and skid plate, torqued to spec and no more popping noise since and it’s been over a year / 10,000 miles.
    Allrsdup likes this.
  5. Jul 30, 2021 at 11:09 AM
    scout495
    scout495 New Member
    bulldog93, pandapro and dkahs05[OP] like this.
  6. Aug 13, 2021 at 8:34 AM
    pandapro
    pandapro New Member
    This.
