5.7L Fluid Specs?
Discussion in '2nd Gen Tundras (2007-2013)' started by Qiman13, Jul 13, 2021.
  1. Jul 13, 2021 at 8:31 PM
    Qiman13
    Qiman13 [OP] New Member
    Just bought a 2007 5.7L and am new to this forum - my first post.
    What are the fluid capacities, specs, etc. for the engine, transmission, differential.
    Is there anything other than just the engine, transmission and rear differential?
    I'm surprised I couldn't find the fluid specs in the owner's manual.
    Thanks for any help!
  2. Jul 14, 2021 at 4:47 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    They're listed in the manual, start at page 583.
  3. Jul 14, 2021 at 11:38 AM
    Qiman13
  4. Jul 14, 2021 at 1:09 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  5. Jul 14, 2021 at 1:15 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    :bananadead::boink:
  6. Jul 14, 2021 at 1:25 PM
    Qiman13
    For transfer case/transmission and diffs - amsoil.
    For engine, Redline, the data is better than amsoil for engines.
    hagrid likes this.
  7. Jul 14, 2021 at 1:34 PM
    Ericsopa
    Ericsopa Old man and the sea
    Uh-oh.
    hagrid likes this.
  8. Jul 14, 2021 at 1:34 PM
    2mchfun
    Welcome to the forum! Congratulations on your purchase!
  9. Jul 14, 2021 at 5:09 PM
    Qiman13
    Uh-oh what?
  10. Jul 14, 2021 at 5:10 PM
    Qiman13
    Thanks - it's a good looking truck!
    2mchfun[QUOTED] likes this.
  11. Jul 14, 2021 at 9:59 PM
    Ericsopa
    Aw, nothin'. Just that you took the bait. We must have about 3 dozen "oil" threads, everybody pitchin' for their favorite brand. Hagrid likes to stir the pot, and you bit, new guy. Just pullin' your leg. Welcome to the club.
  12. Jul 15, 2021 at 12:25 AM
    Qiman13
    Thanks lol
    I do see there are a lot of dedicated schools of thought on oil. I might break a few of those paradigms over time - especially in regards to thermal efficiency over time.
  13. Jul 15, 2021 at 5:08 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Use whatever oil you want ..... Your "used" 5.7L already has miles on it, and, unless you have a comprehensive maintenance log, who knows what oil was used in it before you got it. These engines are ultra reliable regardless of the engine oil used, as long as serviced routinely.
    omgboost likes this.
  14. Jul 18, 2021 at 1:20 AM
    Qiman13
    Does anyone see any issue with the volume of fluids and types for the following? 2007 5.7 liter
    2. Automatic Transmission fluid - 3.2 quarts ATF WS – going to use
    Red Line D6 AFT Auto Trans Fled Gal (30705)
    3. Transfer case - GL-5 - 75W-90 - 1.2 quarts -
    going to use Red Line 50105 75W85 GL-5 Gear Oil
    4. Front differential - 2.2 quarts, LT 75W-85 GL-5 -
    5. Rear Differential - 3.8 quarts, 75W85 GL-5 -
  15. Jul 18, 2021 at 4:43 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    This thread looks more like a "promo pitch" for Amsoil and Redline lubricants.........:evil:
    IMO, ANY lubricant that meets OE specs will protect the driveline / powertrain.
  16. Jul 18, 2021 at 11:35 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I believe you're going to be far short on ATF.
    Maybe 4x the amount you posted.?
  17. Jul 18, 2021 at 12:14 PM
    Qiman13
    Hmmm, not sure - on page 584 of the 2007 Owner's Manual, it says for ATF WS, 3 liters or 3.2 quarts.
    Do you really mean about 12 quarts?
    @jbrnigan, I work for neither company. My friend who has been an Amsoil dealer for years didn't get back to me in the last several days so I'm going with Redline. Yes, spec oil will protect it, but not all protection is equal. As I mentioned in a post elsewhere, small differences that are insignificant to most people are very significant to me for my purposes.
  18. Jul 18, 2021 at 2:01 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    F3FD744A-8A2B-47F4-8947-092D0ED9C56A.jpg Are you doing a drain and fill on the tranny, or are you disconnecting a cooler hose to fully drain it? It’s about a 12-13 qt job as I recall to pull the hose.
    Edited to include my notes.
  19. Jul 18, 2021 at 2:40 PM
    Qiman13
    Thanks, I'd like to do a full drain (no flush). That's quite a bit 11 quarts - will have to watch some vids I guess :)
    WVI likes this.
  20. Jul 22, 2021 at 12:47 AM
    Qiman13
    Out of curiosity, why do so many here recommend against getting a transmission flush?
  21. Jul 22, 2021 at 1:10 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    toyota claim their transmission don't need service, I think...
  22. Jul 22, 2021 at 1:53 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Flushing the trans fluid can be risky if you don't know if it has been done often. It can cause some build up and particulates to become dislodged in the trans and sometime this build up is better left untouched as it's actually what is keeping the trans working right. This is why many suggest doing multiple drain and fills. When draining from the drain plug you won't get anywhere near all of the fluid out. I believe the capacities you have listed for the trans are for drain and fill.
    Google "why not to flush transmission fluid" and I'd say you'll find some good stuff.
    There are threads all about it on here. Your transmission doesn't have a dipstick (as far as I know) only a fill and drain hole and theres a procedure to deal with that correctly.
    Hopefully someone with more knowledge with transmissions will chime in in the later hours of the day as I definitely am no expert just sharing some of the stuff I have gathered.
  23. Jul 22, 2021 at 2:23 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  24. Jul 23, 2021 at 2:25 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I’ve been bit in the arse after changing trans fluid on a high mileage car. Even with just a drain and fill at 160k or so, the trans crapped out a couple of months later. Granted it was a BMW but still.
    I first heard not to change original trans fluid (at high miles)more than 30 years ago, and decided to tempt fate anyway and lost lol. That being said, I’ve done drain and fills on my high mileage Toyota’s and have lived to tell about it (so far).
    Winning8 likes this.
