What is an inexpesive way to connect these cut wires?
Discussion in '1st Gen Tundras (2000-2006)' started by toyota_fan, Jul 14, 2021.
  1. Jul 14, 2021 at 2:27 PM
    toyota_fan
    toyota_fan [OP] New Member
    Missoula, MT
    2006 Tundra SR5 Double Cab 4.7 Liter V8
    What is an inexpesive way to connect these cut wires (black and green wires)?
    I installed a new left hand outside mirror. When I removed the door panel, I noticed some wires that I think had been cut in the past,
    They are the wires to the tweeter by the outside mirror.
    I also noticed some wires below the white connector, that look cut, but can't find what they would go to.
    Would those bottom wire connect to the wires with the connectors, that I circled?
  2. Jul 14, 2021 at 2:41 PM
    Inexpensive? Butt connectors, Strip, solder and tape or heat shrink, maybe Tap splice? Best way? debatable. Most say solder will crack, tap splice is a poor connection (I've never had one fail). Butt connectors with an appropriate crimper and heat shrink is cheap and reliable. All about the crimp on that one.
    Questions:
    1. I'm guessing the speaker isn't working on that side?
    2. Are there aftermarket speakers or stock?
    3. Is there any obvious reason why they would have cut that wire? Factory speaker is still in there and blown, so cut to stop the noise?
  3. Jul 14, 2021 at 2:47 PM
    toyota_fan
    Missoula, MT
    @KNABORES 1. I will have to check if the speaker isn't working. 2. I think they are the stock speakers. 3. I don't know why who ever owned it before me would cut it. Maybe they did cut it because it was blown.
  4. Jul 14, 2021 at 2:57 PM
  5. Jul 14, 2021 at 2:58 PM
  6. Jul 14, 2021 at 3:01 PM
  7. Jul 14, 2021 at 3:02 PM
    Appears to be a couple of front door speaker arrangements. The second one has an additional midrange speaker adjacent to the 6.5 midbass.
  8. Jul 14, 2021 at 3:03 PM
    toyota_fan
    Missoula, MT
    @KNABORES Thanks for the pics, so I can reference them with what I have.
  9. Jul 14, 2021 at 3:20 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
  10. Jul 14, 2021 at 3:22 PM
    toyota_fan
    Missoula, MT
  11. Jul 14, 2021 at 3:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The 2 top ones, as you probably know, simply go back together color for color. The bottom mess would help you if the over spray(paint ??) or whatever that is was removed....rubbing alcohol, paint thinner ?
    Then maybe another pic showing that bottom mess better for others to see. If you proceed before coming back, I would suggest temporarily twisting wires together once figured out to see what reaction from radio you get.
    Keep in mind @KNABORES is showing passenger side, so your driver side colors will be different. Below 2006 EWD shows colors you should see on both passenger and driver side.
    toyota_fan[QUOTED][OP] and Gravy like this.
