Anyone remove the rear seat upholstery?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redacted, Jul 14, 2021.
  1. Jul 14, 2021 at 9:29 AM
    Redacted
    Redacted [OP] New Member
    MA
    2014 SR5 TRD
    3" level kit
    Anyone manage to pull the rear seat cover off the cushions for a cleanings PO had dogs and on misty says I can’t shake the scent of dog balls.
    Trying an ozone generator now but looking to launder the upholstery as well.
  2. Jul 14, 2021 at 9:33 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    hee hee... dog balls...
  3. Jul 14, 2021 at 9:36 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  4. Jul 14, 2021 at 9:37 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've pulled mine off, but that was to put Katzkins on in their place, so I wasn't afraid to cut up the stock ones a bit. I would say just find a local detailer that can run a deep cleaner over them.
  5. Jul 14, 2021 at 10:28 AM
    Redacted
    MA
    2014 SR5 TRD
    3" level kit
    Thanks guys. The upholstery has zippers but at the back of the seat I hit hog rings and that the spot I can’t get past. Plus with two young kids and no garage I got no time for any of this BS.
    going to take another look and also see how much new covers cost. Maybe it’s cheaper to put new covers on than give it to the detail guy.
  6. Jul 14, 2021 at 10:32 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You can disconnect the hog rings by twisting with some lineman's pliers. You'll obviously need new hog rings and hog ring pliers to put the covers back on, though. I wouldn't think a detailer would charge a ton for seat cleaning, but you could also rent a spot cleaner like @Winning8 posted and do that yourself.
  7. Jul 14, 2021 at 10:34 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Pig Rig, seniao and TRDFerguson like this.
  8. Jul 14, 2021 at 10:43 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    I would imagine the time to take off the upholstery, wash, and put back on would far exceed the time for this “bs” lmao
  9. Jul 14, 2021 at 11:10 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I would try to steam clean it, before ripping it apart.
    PotentPotables likes this.
  10. Jul 14, 2021 at 11:43 AM
    PotentPotables
    Washington
    Agreed!
    That said, I've pulled the covers off without ripping or breaking anything. If you get the hog rings and pliers it's not as terrible as it seems. If not, a good ziptie would also work but it would be tedious. It's a good hand workout for sure. The rear seats, at least on the CM, are exponentially easier than the front seats.
    1lowlife likes this.
  11. Jul 14, 2021 at 4:27 PM
    Rocko9999
    Rocko9999 New Member
    You can have it cleaned or do it yourself and then do a chlorine odor bomb.
    seniao likes this.
  12. Jul 14, 2021 at 4:28 PM
    2mchfun
    Spray with simple green and shopvac behind, kinda at the same time with a spray bottle in one hand and vac nozzle in the other. Will have spearmint scent after.
  13. Feb 2, 2022 at 12:10 PM
    Rocko9999
    How long did it take to remove and put the covers back?
  14. Feb 2, 2022 at 1:49 PM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Guaranteed the smell is deeper than just in the cover. A good steam clean will at least get down in the cushion a bit.
  15. Feb 11, 2022 at 1:17 PM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    Remind. I see that you are trying to nose and generator. Best way to get out smells that I know of.
  16. Feb 11, 2022 at 1:42 PM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    ozone generator
  17. Feb 11, 2022 at 2:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Once you get into a groove and get used to the plastic "tongue in groove" parts and hog ring manipulation it goes quickly. I have a DC and did the small seat first. Took me maybe 30 min to remove the covers and a little longer than that to install. The larger part of the seat went even faster because I had it down.
    I reused the hog rings and used a pair of needle nose and regular pliers.
    I pulled the seats and placed them on cardboard inside the house where the AC was nice and cool.
    Rocko9999[QUOTED] likes this.
