  1. Jul 13, 2021 at 7:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Through towns been about the same. Highway 1-2mpg better consistent. Have to calculate the difference in actual mileage traveled due to the speedo reading low. But it’s always higher than before.
    Mind you I have a regular cab and don’t have to push all the double cab weight or even access cab weight. My tundra weights damn near as much as my 01 Tacoma +200 lbs. ratio charts put it into an acceptable rear end ratio for the 33s
    Weight wise my tires are similar to the 32s I had. I went skinnier on the tires
    Darkness, FrenchToasty and TRDGen like this.
  2. Jul 13, 2021 at 8:04 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Lower friction due to less foot print.
    oscardog86 and RUSTYNUTS like this.
  3. Jul 13, 2021 at 8:11 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Definitely something to consider. But I have my doubts, since it does just fine offroad with my stock gears and 295/75r16s. I just can't see 35s with 4.30 gears and a rear locker being problematic on the vvti v8. It already does almost about anything I want it to in 4lo and 1st gear. Plus like I said I spend more time on the highway than I do in the city or offroad. I'd rather try to find a happy medium among all 3 driving types than be best at one of the types of driving I do least.
    oscardog86 and alee891[QUOTED] like this.
  4. Jul 13, 2021 at 8:22 PM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Different strokes for different folks! I went through hassle of dirty fives for improved off road performance, so that’s the angle I’m coming from at the end of the day. The truck still gets up to 90 quick, god forbid I need it to is a different story.
  5. Jul 13, 2021 at 8:32 PM
    I live in a land where I rarely need to get on a freeway; and I absolutely love it! There are literally like 4 times a year I get on the freeway and it’s only for long distance purposes. Everything else is local(35mph posted………..not always obeyed) or 55-65 rural roads to trails or local getaways. I’m not ready to dive down the gear ratio rabbit hole of info, but it is definitely on the back burner as other projects get knocked out and time avails!
    oscardog86 and TRDGen like this.
  6. Jul 13, 2021 at 8:36 PM
    empty_lord
    05 rollover special
    Only 10mm though. Enough to weigh the same
  7. Jul 13, 2021 at 8:37 PM
    empty_lord
    05 rollover special
    The 33s get me anywhere I need to be. This trucks mostly for towing anyway.
    TRDGen and FrenchToasty[QUOTED] like this.
  8. Jul 13, 2021 at 8:41 PM
    I love that your able to utilize your setup for that. Every time I see a long bed, I look, v8, check……….4………w…………d………… CHECK! And wish I could take it for a spin
    Darkness, TRDGen and NWPirate like this.
  9. Jul 13, 2021 at 8:43 PM
    empty_lord
    05 rollover special
    if you find yourself up around here then we can arrange that.
    but 90% of people avoid this area like the plague. and thats part of its charm to me. LOL
    i do plan on making my way down to Arizona at some point to meet with some Tacoma peeps for a little wheeling and picking up goodies.
    but i take it easy.. this thing will still need to do 24 hrs of driving home. LOL
    Darkness, des2mtn, RUSTYNUTS and 3 others like this.
  10. Jul 13, 2021 at 8:51 PM
    Your always welcome down here; I’m going to see what I can do about tundras2sedona, it coincides with other shit that I can work into a sweet trip hopefully.
    like I told @Tundra2 ,I’ll take you on a legit food journey, I love when I see people eating at “Mexican food restaurants”
  11. Jul 13, 2021 at 8:54 PM
    empty_lord
    05 rollover special
    and now is when i get to inform you of my biggest issue.
    i have a seriously small menu due to my mind being a mess from getting deathly ill as a child. But hey, i do totally love exploring the land!
    theres a lot of things that i love the smell of and want to eat. but if i do, i practically get sick within an hour and am done for the day.. it sucks.
  12. Jul 13, 2021 at 8:59 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    so you're running the 2886 and not the 2885 springs up front?
    I'm assuming the stiffer longer spring makes up for lift since people run these with 5100s on lower or bottom notch? Currently I'm on the 3rd circlip (I think) and OEM springs.
    EDIT:
    Also still trying to figure out if I should do the ATS 3/1 or HD 4/1 leafs......
    I'd like to get rid of the 1.25" rear blocks but not sure if the HD 4/1 leafs would do it or not.
  13. Jul 13, 2021 at 8:59 PM
    Well I can definitely take you on some cool geographical journeys, that isn’t a fun thing with your diet I’m sure!
  14. Jul 13, 2021 at 9:02 PM
    empty_lord
    05 rollover special
    shit that was a typo i missed. im running the 885s
    i fat finger the number pad alot... you've probably noticed
  15. Jul 13, 2021 at 9:03 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    good. That's what I was thinking. But that spring on the bottom clip is basically like oem springs on 5100 3rd clip lift height?
  16. Jul 13, 2021 at 9:04 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I figured you'd be towing your taco
  17. Jul 13, 2021 at 9:05 PM
    empty_lord
    05 rollover special
    But I am running 885s, lowest setting.
    I’m guessing 886 would be good for a beefy bumper.
    alee891 likes this.
  18. Jul 13, 2021 at 9:05 PM
    empty_lord
    05 rollover special
    I’d be bringing an empty trailer to pickup a Tacoma frame and some other Tacoma/4runner stuff.
    TRDGen[QUOTED] likes this.
  19. Jul 13, 2021 at 9:06 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I have no intentions of a different than OE bumper so I would guess the 885s should be fine.
    empty_lord[QUOTED] likes this.
  20. Jul 13, 2021 at 9:24 PM
    That would take you straight through amarillo...
  21. Jul 13, 2021 at 9:34 PM
    empty_lord
    05 rollover special
    Yea… but all you could sho me is some shos
  22. Jul 13, 2021 at 10:12 PM
    JODOOR
    JODOOR New Member
    Joshua
    2004 Limited DC 4x4
    Gave the ol' truck a bath and finally got around to getting rid of the chrome.badges via plastidip.
    tacoguybill, NUDRAT, Thrussn and 7 others like this.
  23. Jul 14, 2021 at 6:02 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    First gen party at TTS. Who else is coming? :fistbump:
  24. Jul 14, 2021 at 7:03 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I wanna go.
  25. Jul 14, 2021 at 7:05 AM
    des2mtn
    SW
    Tonto cover
  26. Jul 14, 2021 at 7:24 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Perfect timing, too. Hit sedona and big bend in the same trip, and stop in terlingua on the trip home to be disappointed by the chili.
    des2mtn likes this.
  27. Jul 14, 2021 at 8:41 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Finally got the bumper back on after having it, tailgate and topper painted. Did not do as much to the bumper frame as I wanted to, painting wise....will wait till fall. Seems junior mint barney fife in town felt it necessary to pull me over and even tho he seemed more interested in talking the condition of the tundra, he let me know don't let him catch me in town again without proper bumper.
    It's similar to Ron White story...."The arresting officer, who I had literally known, all my life. You know what I mean? This guy lived four doors down the street me, in a town of less than four hundred people. *We've met.* Now, he takes me to jail, and he asks me if I have any aliases."....we've known each other over 10 years....oh well, F him !
    and all new trim
    Center Plate 52159-0C010
    Center Plate Outer Plate 52163-0C010
    Center Plate Outer Plate 52164-0C010
    Pulling a PHM and meditating for a bit and while on the golf course this evening in preparation for VC work tomorrow and Fri. With a little British Open thrown in for good measure !
    Darkness, Glock 40, bmf4069 and 5 others like this.
  28. Jul 14, 2021 at 8:45 AM
    @BubbaW I didn't realize you were such a big Vols fan. Do you really have a TN plate while living in AL? Truck is looking really good.
    BubbaW and onesojourner like this.
  29. Jul 14, 2021 at 8:48 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What is VC?
    BubbaW[QUOTED] likes this.
  30. Jul 14, 2021 at 8:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks on truck, Born with orange in my blood. First time in Neyland, there were no end zone bleachers….long time ago suffice to say !
    Born, raised, live in TN
    Fck Bama :annoyed::bananadead::frusty:
