  1. Jul 13, 2021 at 10:12 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I was hoping it was a dual battery monitor.
    Wallygator likes this.
  2. Jul 13, 2021 at 10:17 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Just curious but why not put the bikes on the bed and add hitch mounted storage? Just in case of somebody rear ending the truck. Probably depends which is more valuable I suppose.
  3. Jul 13, 2021 at 10:21 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    There are two roof boxes side-by-side with a 1up in between so I can take 5 bikes. The two boxes will hold more than a hitch-mounted box and we bring much gear with us. This is also modular. Although I'd like more 1ups to put bikes on the bed when I'm not camping. That and I've had the rack longer than the tundra.
  4. Jul 13, 2021 at 10:25 AM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    did that front sway bar stiffen things up a lot?
  5. Jul 13, 2021 at 10:26 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    How does that affect your ability to access the bed through the Diamondback? Seems like the mounting system would prevent you from opening the panels.
  6. Jul 13, 2021 at 10:36 AM
    jpod
    London Canada
    I does. You can't open the cover with either the bike racks or the boxes. That's why I got a bed slide (there will be no crawling into the bed for me.) I also have a swing arm for the bike rack to get it out of the way if the bikes are on it and I need to pull out the bed slide.
    EDIT: you can see the bed slide in action here:
    https://www.tundras.com/threads/camping-overlanding-thread.11105/page-28#post-2320363
    You can't see the hitch swing arm on these pics but the with the bikes off, you can see the gear out.
  7. Jul 13, 2021 at 10:49 AM
    The Californian
    Eric
    Ah, I see the pictures - very nice setup. You probably have more money invested in your coolers than you have in the rest of your setup combined, including the truck. haha
    jpod[QUOTED] likes this.
  8. Jul 13, 2021 at 10:52 AM
    jpod
    London Canada
    lol. Ya, the Yeti's are sweet but aren't cheap. You just have to wait for the REI 20% off any single item sale and it will only cost you an arm OR a leg rather than both.
    NewImprovedRon and 316KS_Runner like this.
  9. Jul 13, 2021 at 10:52 AM
    It does tighten it up a little. I've had mine for a couple of years now.
  10. Jul 13, 2021 at 10:56 AM
    The Californian
    Eric
    I just went with the knock offs, and haven't regretted it. Picked up a couple RTIC's, and then found this company called FrostedFrog, and picked up a 110qt for under $300 and it's worked great for us.
  11. Jul 13, 2021 at 11:04 AM
    jpod
    London Canada
    The RTIC are made as well as the Yeti but wasn't around when I bought my 75 and wasn't available in Canada anywhere when I bought the 45 (they had lost their patent case by then for ripping off the Yeti.) I have a friend who has the RTIC 65 and 45 and we did a couple of tests with the 45's to see how well they did. They perform the same. Literally the same. If the RTIC is available around you, buy them. Use the money saved to fill them full of beer 3 or 4 times.
    I haven't heard of Frosted Frog so I can't comment there.
  12. Jul 13, 2021 at 11:09 AM
    The Californian
    Eric
    Yah, I did a bunch of research when I was in the market - and came to the conclusion that pretty much every rotomolded cooler is comparable in performance at this point. Found Frosted Frog and decided to support their small business.
    Wallygator and jpod[QUOTED] like this.
  13. Jul 13, 2021 at 11:23 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Nice setup! I am making a custom bed rack so I can attach a roof box over the bed just like this. My current box is a Thule, unfortunately it's long and I will need to step down to a shorter box. What Thule is this? The Sidekick?
  14. Jul 13, 2021 at 11:26 AM
    jpod
    London Canada
    Force XT in a Large. Its connection points slide well to the front or back. My old one had to be put on backwards because it goes to a point at the front and that point touched the back window and couldn't be moved back.
    aelarson[QUOTED] likes this.
  15. Jul 13, 2021 at 11:28 AM
    aelarson
    aelarson New Member
    AZ
    Thanks! It's nice to see a similar setup to what I am thinking. Not too many people run cargo boxes over the bed like this!
  16. Jul 13, 2021 at 11:30 AM
    Taco-Spike
    Two Trucks
    Sorry for the delay. Was out at the beach for 4 days with friends.
    That's on my Tacoma.
    2016 -2021 Tacoma Flush Bed Cross Bar (4xinnovations.com)
    I don't see they have one for Tundra.
    My dad welded something up for the Tundra though. Let me find a pic
    Wallygator and NAFlash like this.
  17. Jul 13, 2021 at 11:34 AM
    aelarson
    aelarson New Member
    AZ
    Integrally suppressed barrel .22 bolt action? Slick rig!
    Also, what seat covers are those? Look simple but effective.
  18. Jul 13, 2021 at 3:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I am digging the seat covers. My dad had ones like those in his '82 Ford!
  19. Jul 13, 2021 at 3:31 PM
    birdman86
    birdman86 New Member
    Sadly no suppressors up here in Canada, that's just a heavy barreled CZ 457. Insanely accurate, shoots .6 MOA any day (and I'm a terrible shot).
    Seat covers are saddlecloth, pricey but incredibly durable and comfortable. I found them in the oil patch when every pickup had them installed, now all our farm trucks have them too. Seatcovers.com out of Calgary AB ("Westerner" style).
  20. Jul 13, 2021 at 3:41 PM
    1794TX
    Steven
    N.TX
    '20 1794
    I have that same CZ, but with the walnut stock. Probably close to the same optics as well (6-24x50 Viper HS-T). What ammo do you use (presuming 22LR...)? I've narrowed to a few - Aguila Super Extra gets me to just about 1MOA, but a fidgety disposition typically gets me to 2.
  21. Jul 13, 2021 at 3:42 PM
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    Great looking Tundra!!
    bll05c likes this.
  22. Jul 13, 2021 at 3:53 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    had these in my 03 taco i just sold. love them.
  23. Jul 13, 2021 at 4:37 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Follow-up from this post.
    Had it on for a day and got a CEL this morning. Before my commute home I put the original back on, then went to Autozone to get the code checked and hopefully cleared. Apparently it should clear itself once the problem is corrected. I'm getting the OEM replacement tomorrow, hopefully the code will be gone by then and I can have it click like normal (still not sure why it doesn't anymore).
    Besides the CEL the locking cap seemed goofy, it wouldn't consistently unlock and seemed to require a lot of force to when it did. Reading reviews they seem hit or miss.
  24. Jul 13, 2021 at 5:14 PM
    Love the tail lights.
    bll05c likes this.
  25. Jul 13, 2021 at 5:23 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Good looking truck! I too went from a taco to a tundra. You'll love the extra power and all the extra room.
    bll05c likes this.
  26. Jul 13, 2021 at 5:38 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    Towed this to the beach for some fun.
  27. Jul 13, 2021 at 5:41 PM
    French Avocado
    Utah / Wyo
    Welcome - you are off to a nice quick start. Enjoy the mods. How did you do the blackout of the lights?
  28. Jul 13, 2021 at 5:52 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Geez, neighbors are siphoning your gas?
  29. Jul 13, 2021 at 6:20 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Nope, I figured I'd try it as a precautionary thing since I was replacing anyway as the stock one seemed to not be working right (stealing cats now, maybe next stealing gas?). Turns out it's hit or miss like a lot of stuff off Amazon. I'll just use the OEM and carry on.
  30. Jul 13, 2021 at 6:29 PM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Bought a knockoff that broke so went with the real thing this time. The original seems so awkward after having this one.upload_2021-7-13_21-28-33.jpg
