Need Help: How to run tonneau drainage tubes when bed is line-x'd.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Long Duck Dink, Apr 8, 2020.
  1. Apr 8, 2020 at 2:59 PM
    Long Duck Dink
    Long Duck Dink [OP] Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    As you can see in the picture, the little area where you'd run drainage tubes has been line-x'd. What's the best way for me to run drainage tubes in to those little slots?
    Drill holes, cut out the line-x with a razor, something else?
  2. Apr 8, 2020 at 3:16 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Interested to know what others have done! I installed a bed rug before the tonneau and the drain tubes don’t go anywhere
  3. Apr 8, 2020 at 3:27 PM
    TTund16
    TTund16 New Member
    My Tacoma collects lots of water in the bed-liner if I'm parked downhill and when I start to drive, it floods the street :D
    My Tundra has factory spray or maybe dealer did it. It came with it when I bought new. I didn't know there were holes to drain water. Wonder if the holes were plugged after the spray.
    Are the holes near the back where your tube is? I guess you can unplug them if you know the exact spot.
  4. Apr 8, 2020 at 3:51 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    20200408_175250.jpg On mine, I tried to drill through the oval bed plugs. The liner (applied by Toyota, I assume at port by GST) pulled off of the plastic as soon as the bit took hold. I then just peeled it off the rest of the plastic plug and cleaned up the hole I drilled. Be careful not to go through and hit the back of the cab with the drill bit.
    TXBrit, YardBird, TTund16 and 2 others like this.
  5. Apr 8, 2020 at 3:56 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I just popped the plastic plugs out of the bed, and used a big enough drill bit to fit the drain tube through....the line x did come off the plastic, but being black to begin with it's really not that noticeable.
    Long Duck Dink[OP] likes this.
  6. Apr 8, 2020 at 3:59 PM
    Long Duck Dink
    North Salt Lake, UT
    There are two locations you can drain from (see edited picture). The problem is those are now covered in line-x. If the truck bed hadn't been sprayed, those are just little plastic pieces that can easily be removed for drainage tubes.
    So my options (as I see them) are to drill a hole and run the tubes through the hole or to use a razor blade and try to cut out the inserts. Anyone have any experience doing this?
  7. Apr 8, 2020 at 4:02 PM
    Long Duck Dink
    North Salt Lake, UT
    This is where the drainage holes are.
    YardBird likes this.
  8. Apr 8, 2020 at 4:06 PM
    Jernik
    Jernik New Member
    Jeremy
    I updated my post with a pic, I think your last 2 posts were in before my update. Hope the visual helps.
  9. Apr 8, 2020 at 4:09 PM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    Use a "step Drill" that way you can get the desired size hole and not hit the cab
  10. Apr 8, 2020 at 4:15 PM
    Jernik
    Jernik New Member
    Jeremy
    I used a piece of scrap wood and an assistant to hold it in place to protect mine.
  11. Apr 8, 2020 at 4:18 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s just a rubber coating on a piece of rubber. Not solid whatsoever. Step drill through it.
    YardBird and Long Duck Dink[OP] like this.
  12. Apr 8, 2020 at 5:01 PM
    Bronzeback
    Bronzeback New Member
    This. The linex will peel off. They're just rubber/plastic inserts. Can buy new ones cheap if you need to.
  13. Apr 8, 2020 at 6:37 PM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    There is a hole on the bedside just to the right of your picture up high. I used a piece of red tubing that came with a harbor freight transfer pump and put it through there. Saw idea online somewhere and it works so far. I have an mx4 bakflip.
    NewImprovedRon and TundraMax20 like this.
  14. May 7, 2020 at 11:02 AM
    thexman1
    thexman1 New Member
    James
    Dayton, Ohio
    2016 Tundra (AKA: "The Mothership")
    Would you know by chance what the name of those things are? I am currently looking for the part from Toyota.
  15. Jul 13, 2021 at 1:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Why not just run the tube through the already existing hole above your bed cleat, right below the clamp nearest the top of the hose? This is what I did, keeps the hose short and dont have to worry about snagging it on something if you put something in the corner there.
  16. Jul 13, 2021 at 2:20 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    This is what I did. Very clean and worked great. I forget what these fittings are called, I *think* it was a 1/2 inch to 3/4 inch fitting. There are threads on the 3/4 inch side, so when I drilled a 3/4 in hole through the rhino liner and plastic cap, the fitting screwed in perfectly and is nice and snug. Looks clean and works great, I just need to paint them black now lol
  17. Jul 13, 2021 at 2:30 PM
    GWill
    Willis
    2020 MGM TRD Pro
    Found it, I think this was the exact one I got, just take in your tube and make sure to find one that fits the barbed end, and use the right sized drill bit for the threaded end, it will screw in nicely
    TTund16, YardBird and Cons like this.
  18. Jul 13, 2021 at 2:49 PM
    MadMaxCanon
    No pic of my truck because I rode my bike to work, but I circled the hole I'm talking about and the blue x is where you can cut the excess tubing.
  19. Jul 13, 2021 at 3:01 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I bought two new plugs so I would have fresh ones if I pulled the TC off for some reason.
    Drilled holes in the originals. I used risers from sprinkler heads and grey PVC nuts from the electrical department. There is one inside and one outside of the plug. Had to dremel the the hole on the inside one to get it around the bend.
    I spray painted everything with rattle can bed liner spray over primer. Like mentioned above, it fell off the plug when I reinstalled.
    Edit: You can see little bits of the paint left on the plug (I hadn't noticed until now). Also, I would expect you can cut around the edge of the plug and pop it out with a screwdriver... mine came from the port with no bedliner on the plugs.
    NewImprovedRon and Cons like this.
  20. Jul 13, 2021 at 3:33 PM
    BrunoTheRescuePup
    SW Portland Metro
    I chose the route I did instead of those holes as I would have to drill them out to fit the tube. Also I am not sure how the finish is 'inside' the bed and didn't want to dump water in there all winter long. Someone that has gone that route could probably educate both of us on this.
  21. Jul 13, 2021 at 4:19 PM
    MadMaxCanon
    I used them without drilling. Just pinch the end of the hose a bit to get the diameter down,and stick it in there, if its the ribbed hose like mine, it should go in no problem. I have 0 issues, water goes right outside. I tested it with a bottle of water. Save yourself the trouble and having a way longer hose that might get pinched if you put stuff down there.
    TTund16 and BrunoTheRescuePup like this.
  22. Mar 20, 2022 at 4:22 AM
    CSB
    CSB New Member
    CSB
    Do not use the existing hole in the upper side wall of the bed as MadMax suggests - as it is not clear where the water could possibly collect in the frame/body. See figures 11a/11b provided in the link below. The aforementioned figures provide a depiction of the proper way to install drainage tubes in the Tundra beds, without or with the Toyota plastic Bed-liner (respectively), as instructed by Toyota (of Canada) in their installation instructions. Good luck.
    https://www.toyotapartsdeal.com/resources/installation/tpd/pu100-3415 toyota tundra-print.pdf
    gkelm likes this.
  23. Mar 20, 2022 at 4:58 AM
    18" TRD Off Road Wheels
    The fact that you think this could possibly drain into the frame makes me doubt your advice..... A lot.
  24. Mar 20, 2022 at 5:45 AM
    CSB
    CSB New Member
    CSB
    @GODZILLA Well alrighty then.
    I used the words, “could possibly collect in the frame/body.”
    I assume that you are a mechanical engineer that not only understands corrosion and its affects on materials, but as how to protect them or avoid water and other particle intrusion altogether.
    So then it can be assumed you know exactly where the moisture could go and thus not result in damage (I don’t)? It can therefore also be assumed that you also have seen the Toyota drawings for the bed and know how it was designed to drain (I haven’t), and furthermore you know the materials and coatings that were used to protect the area (I don’t)? You must also know that the hole in the bed side wall was put there to serve as the drain, and not for manufacturing purposes (I don't)? Since you are so smart (Lol) in these areas, you doubt the integrity of the actual Toyota installation procedure link that I provided too, right? Actually, I doubt your ability to think critically….…”a lot”. Arrogant twit.
  25. Mar 20, 2022 at 5:53 AM
    Well, a chemical engineer would probably know more about corrosion than a structural. Perhaps you should consult one?
    You didn't quote Toyota... you quoted Toyot-eh of Canad-eh.
    Jokes aside, it's an exposed hole on the exterior of the truck. Common sense would point toward the fact that if water intrusion could be detrimental here, then it's a design flaw from day one and we are all boned.
    I don't need technical drawings to know that a hole in the sheet metal on the side of the bed doesn't drain into the frame. I stand by my previous assessment that you entertaining that possibility draws into question your sense; common or otherwise.
  26. Mar 20, 2022 at 5:56 AM
    An engineer who knows everything... while also stating they don't know... color me surprised.
  27. Mar 20, 2022 at 6:00 AM
    CSB
    CSB New Member
    CSB
    You obviously know nothing about engineering. Chemical engineers are concerned mainly with chemical processes for maximizing product output, and perhaps chemical plant design. Mechanical engineers, like myself are responsible mechanical design, including corrosion concerns. You know nothing. And if you don’t trust Toyotas proven instruction, I doubt your ability to think critically……..a lot. Cretin.
  28. Mar 20, 2022 at 6:01 AM
    Screenshot_20220320-065914_Samsung Internet.jpg 5 whole posts before you had to tell everyone you're an engineer. That's gotta be a record.:rofl:
  29. Mar 20, 2022 at 6:02 AM
    CSB
    CSB New Member
    CSB
    You don’t get it, engineers are problem solvers. We do not guess we are on the side of caution. If Toyota, the people that designed this product, tell you how to do something correctly, why would you do it another way that you are unsure of?
    Cpl_Punishment likes this.
  30. Mar 20, 2022 at 6:03 AM
    CSB
    CSB New Member
    CSB
    Well, you sound like you’re a teenager. What makes you so smart? I think someone here is a teenager and that doesn’t like to be shown that they’re wrong. I would guess you don’t own a tundra nor even have a drivers license either. I doubt your ability to critically think……A lot. Lol
