Bed Rack Install Help
Discussion in 'General Tundra Discussion' started by angel6mt, Jul 13, 2021.
  1. Jul 13, 2021 at 2:07 PM
    angel6mt
    angel6mt [OP] New Member
    Angel
    Orange County, CA
    ‘18 Cement CM
    Hi All,
    Looking to get some advice…I recently bought a used RCI bed rack (58in) older model for my short bed. I ordered the drill free clamps from RCI but bc I have an older model, the clamps do not fit *sigh* Any advice on how to get this thing secured on the bed? Is my only option to install a deck rail system and get the RCI adapter brackets? Any advice is appreciated.
  2. Jul 13, 2021 at 2:38 PM
    2mchfun
    There are various kinds of ladder rack mount hardware available. Some clamp on the lip and some use stake pockets then go in the side with a bolt. Google is your friend. I used stake pocket expandable rubber anchoring points for my racks and rails, just replaced the eye bolts with stainless steel 3/8" bolts. Nice and solid for a few thousand miles so far. No drilling into the bed, only cut the plastic caps which are replaceable easily.
  3. Jul 16, 2021 at 9:53 AM
    Tamutundra
    Tamutundra New Member
    Frisco Tx.
    19 super white CM TRDoffroad 4x4
    behind the bed liner are several threaded hard points... if you don't want to remove liner... either measure a friends or ask the dealer if you can measure one on the lot... then you will know where to "open/cut" the liner for hard point bracketry
    15whtrd likes this.
  4. Jul 16, 2021 at 10:21 AM
    15whtrd
    15whtrd Mr. Blonde
    Looks like you may need to notch your plastic bedliner.
  5. Jul 16, 2021 at 11:29 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    @SC_TRD didn’t you run into this issue?
    SC_TRD likes this.
  6. Jul 16, 2021 at 11:37 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    sr5shark[QUOTED] likes this.
  7. Jul 26, 2021 at 6:28 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Get rid of the plastic liner and do spray in. Then You can see where the holes are and possibly mount the in bed rail system. I just took mine out for my RCI rack and since you are in OC (I work in OC) I can give you my bed rail system
    Ely010606 likes this.
  8. Jul 27, 2021 at 10:26 AM
    xitoxic
    xitoxic New Member
    Jay
    You need to notch the bedliner, should work
