  1. Jul 12, 2021 at 6:18 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Whatever man. You have no idea what you're talking about. You probably think while having an 8" lift and 37s that getting good gas mileage is impossible on these trucks. I'm smarter than my parents say I am
  2. Jul 12, 2021 at 6:31 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This is a common misconception. You can run it in the engine bay but you need to tap into the transmission cooler line, so it’s only available for 2018 and older models.
    You won’t be able to hit 88 miles per hour with that setup unless you regear…
  3. Jul 12, 2021 at 6:34 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    You may have to Super Charge :spending:
  4. Jul 12, 2021 at 7:06 PM
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Gave it a bath then loaded it with some tree trimmings. Thought it looked good in the sunset20210712_205840~2.jpg
    Jcmf52, Okie3006, RowdyT 54 and 12 others like this.
  5. Jul 12, 2021 at 7:14 PM
    French Avocado
    Utah / Wyo
    Falcon shocks
    Powder Coated coils
    Sumo springs
    CoachBuilder CB+1 shackles
    TRD front sway bar
    Pictures in Falcon group buy thread
    GAknight, Booney, Asimov2025 and 3 others like this.
  6. Jul 12, 2021 at 7:18 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    To add to this - anyone who has ever bought a cover from them for a Tundra (at least 2014+) can ask them for them and they will ship them to you for FREE. When I bought my cover they did not have shims yet but DB sent me a box when I asked them about them.
  7. Jul 12, 2021 at 7:28 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    9039AD4D-12F7-48C1-95B6-CDF9C2C1D7E5.jpg Hi rev BRB tails
  8. Jul 12, 2021 at 7:34 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Thank you!!
  9. Jul 12, 2021 at 7:49 PM
    BeachBaum107
    BeachBaum107 New Member
    Thomas
    2021 Magnetic Gray Metallic
    Tool Box Floor Mats Pistol Mount Running Boards 20” Fuel Wheels Tinted Front Windows
    Awesome
    mikesTundra77 and Fotnot[QUOTED] like this.
  10. Jul 12, 2021 at 8:23 PM
    BeachBaum107
    Thomas
    upload_2021-7-12_22-22-4.jpg Like these.
    TucsonTundra1794 likes this.
  11. Jul 12, 2021 at 9:04 PM
    AKLA98
    AKLA98 New Member
    Liam
    Anchorage, AK / Boulder, CO
    2019 MGM TRDOR Double Cab
    TRD PRO Grille, Colormatched Mirror Caps, Rear Bumper Caps, Husky X-Act Floor Mats, 20% VLT Front Tint, BAJA Designs Squadron Sport Fog Lights, LockerDown Console Vault
    Would love to see some pictures of your Snugtop Rebel.
  12. Jul 12, 2021 at 10:18 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Phase one of Saftey Inferno is complete!
    I saved looking at the rear suspension for last. The previous owner of the truck didn't know about it but there are a set of air lift 5180 on this truck. I asked about them at the test drive so I was aware of them but I assumed they were shot. They were pancacked and rubbing the mounts but appeared to be in good shape. We put air in and - wow. The truck rear raised up three inches. A nice little surprise at the end of the day. We will see if they hold air overnight and how it rides in the morning. The change is crazy. It used to be I could lean against the tailgate and look in. Now, it's more like peeking over a fence.
  13. Jul 12, 2021 at 10:41 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Installed Dirty Deeds stainless 10" exhaust with resonator. Without the resonator, it was too loud for my liking. Wife was not pleased either. Resonator toned it down about 50%, and it is just about right. The drone in the city is a bit louder than I would want, but almost gone completely on the highway.
    I wasn't a fan of the rusty tail pipe, or the look of the tail pipe at all for that matter. I cut the tail pipe about 6 inches after the hanger. I'm a big fan of the clean look. I used a wire brush drill attachment to remove the rust, primed it with two coats Rust-Oleum high heat primer, then three coats Rust-Oleum high heat flat black spray paint. Finished it off with the "baking" process in the paint directions.
    Before
    In Process
    After
  14. Jul 13, 2021 at 4:33 AM
    Rippyro
    Rippyro New Member
    I like the look of those a lot. Less traditional than your typical aftermarket look.
    NorthShore and Rica25 like this.
  15. Jul 13, 2021 at 4:49 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Those Rhinos are sweet! Stock offset is +60. The generally accepted 'sweet spot' seems between in the +20 to +30 range. Lots of guys go out to 0 tho. The numbers on your lift and intended tire size just need to jive with your offset.
    Here
    https://www.tundras.com/threads/anyone-running-17-rims-on-your-3rd-gen.23617/
    And here is everything you need to know. :):thumbsup:
    GODZILLA likes this.
  16. Jul 13, 2021 at 4:55 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    stock offset is +60 on most....+50 on a few others.
    Rica25 and GODZILLA like this.
  17. Jul 13, 2021 at 5:17 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Yah, it’s a completely separate instruction page.
  18. Jul 13, 2021 at 5:17 AM
    The Californian
    Eric
    Good to know.
    Rica25 likes this.
  19. Jul 13, 2021 at 5:26 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I like em. Kinda military looking. I have +18 on my Tundra. Here is a pic for reference...
    Army_of_One, Rica25, MatD13 and 5 others like this.
  20. Jul 13, 2021 at 5:53 AM
    Buckwalleye
    Buckwalleye New Member
    2018 TRD double cab
    the wheels I just got are a +20 and I love the stance. Stick out just enough IMO
    TNTundra16 likes this.
  21. Jul 13, 2021 at 6:11 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Can I get more info on that screen and what it does? Thanks
  22. Jul 13, 2021 at 6:37 AM
    justcuz
    justcuz 2.5 Gen Member
    bought a touch up pen. most expensive mod so far.
  23. Jul 13, 2021 at 6:50 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Second roof box
    83D19584-5346-4FB9-A24C-8CE26D1345EB.jpg D6703F6F-E77E-4EE0-BA38-2B15C62364D2.jpg
    WILLINH, Steve18, aelarson and 7 others like this.
  24. Jul 13, 2021 at 6:57 AM
    French Avocado
    Utah / Wyo
    A couple pictures
    AB1E8B0A-7475-4906-9317-29613285A064.jpg 9B1ED1B8-57FA-4DD7-9732-BB43429C337E.jpg
    RRR1C0, TunBrun, HulkSmurf14 and 16 others like this.
  25. Jul 13, 2021 at 7:45 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'll pay someone a dollar to do this to their tundra.
  26. Jul 13, 2021 at 9:46 AM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    Lol!!! I'm sure those will be fine for off roading
  27. Jul 13, 2021 at 9:53 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    For sure, that tred pattern is super aggressive
    mikesTundra77[QUOTED] likes this.
  28. Jul 13, 2021 at 9:59 AM
    birdman86
    birdman86 New Member
    I'm not a gun nut who has to have his rifle with him everywhere he goes, but this truck does daily pest control around the farm and I got sick of the rifle bouncing around the cab all summer. Built out of scraps and bedlined, it hooks into the console and is surprisingly stable without having to bolt anything down. Granted the rifle is super heavy which helps.
    SpooledReel, reneaux, Jcmf52 and 29 others like this.
  29. Jul 13, 2021 at 10:02 AM
    birdman86
    Looks like a solar controller maybe? Just guessing
  30. Jul 13, 2021 at 10:04 AM
    The Californian
    Eric
    Here is a link to the installation instructions. https://cdn.shopify.com/s/files/1/1...-installation-guide.pdf?v=6381642095274368811
    For some reason they put it under a separate section called "Other Components" in their installation guides, instead of including it in the main installation instructions.
