Throttle body
Discussion in 'Performance and Tuning' started by Xcali89, Jul 11, 2021.
  1. Jul 11, 2021 at 7:28 AM
    Xcali89
    Xcali89 [OP] New Member
    Anthony
    2015 SR5 tundra
    K and N cold air intake
    Are there no good throttle bodies for the tundra, only saw one and looked factory? Wish BBK made one for them
  2. Jul 11, 2021 at 8:06 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
  3. Jul 11, 2021 at 8:19 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I would be interested in seeing what this would do for an N/A truck. I think it would be a big enough tb to not need a reducer on my intake. I can't imagine it would be enough to be worth making a bracket and the $$$ for the tb.
  4. Jul 12, 2021 at 5:30 AM
    Xcali89
    Anthony
    2015 SR5 tundra
    Dirtydeeds, how much for the headers and the bully tuner? Also how long do you think the install takes on the headers?
    dirtydeeds likes this.
  5. Jul 12, 2021 at 6:41 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    There won't be any benefit to doing this on the stock intake manifold. The supercharger has a larger inlet diameter and can be opened more to flow smoother, it can also make use of the additional airflow.
    ProSpeed sells an adapter that allows you to mount the RCF TB on a supercharger and transitions the diameter down to the supercharger inlet diameter for better flow. The bolt patterns are different, so it won't mount directly to the stock TB holes. The adapter can still be mounted to the stock intake manifold, but the diameter of the stock intake manifold is smaller than the supercharger-side the adapter.
  6. Jul 12, 2021 at 7:47 AM
    dirtydeeds
    Keith
    USA
    Headers are a 8-12 hour install.
    call for pricing on everything. 760-877-4234
    Keith
