Red Loctite on Suspension
Discussion in 'Suspension' started by clauderdale001, Jul 10, 2021.
  1. Jul 10, 2021 at 6:15 PM
    clauderdale001
    clauderdale001 [OP] New Member
    Cody
    Hernando, MS
    2017 White Tundra TSS
    Can anyone confirm that the two bolts on the front end lower ball joint that face up have red thread locker on them?
  2. Jul 10, 2021 at 6:41 PM
    15whtrd
    15whtrd Mr. Blonde
    I was told to put Red Loctite on them by another member here who knows what’s up. I promptly removed them one at a time installing red Loctite after I did my lift.
  3. Jul 10, 2021 at 6:46 PM
    Yes they do from the factory. I did not reapply any after I installed my lift and no issues at all.
  4. Jul 10, 2021 at 6:50 PM
    clauderdale001
    Cody
    Hernando, MS
    I’m removing them now and wondering if it’ll help to apply heat. I don’t have the strongest impact at home.
  5. Jul 10, 2021 at 6:52 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m unsure if it’s got Loctite from the factory. But a big ass breaker bar from Harbor freight did the trick for me. I bounced it a little bit. You can also add a cheater bar (piece of pipe) just be careful you don’t break your tool and hurt yourself.
    snivilous likes this.
  6. Jul 10, 2021 at 7:01 PM
    clauderdale001
    Cody
    Hernando, MS
    I have a 1/2” drive breaker bar (what I should be using) but the one 22mm socket I have is 3/8”. Already broke one 3/8” ratchet during this installation.
  7. Jul 10, 2021 at 7:02 PM
    15whtrd
    15whtrd Mr. Blonde
    Upon preparation for my install I loaded up on harbor freight stuff LOL. Impact half inch drive sockets, breaker bar etc.
  8. Jul 10, 2021 at 7:03 PM
    They are pretty tight. I had to use about a 2 foot piece of pipe from a chain link fence rail to break them loose.
    15whtrd likes this.
  9. Jul 10, 2021 at 7:05 PM
    Tunka
    Tunka New Member
    So cal
    2018 sr5 crwmax
    2.5 leveling kit 30555r20 ko2 fuel assault wheels
    They are 220 ft pounds you need man tools
    withoutapaddle, snivilous and 15whtrd like this.
  10. Jul 10, 2021 at 7:05 PM
    2mchfun
    I used a box end wrench and another wrench for a cheater, reapplied red loctite.
  11. Jul 10, 2021 at 7:07 PM
    clauderdale001
    Cody
    Hernando, MS
    I thought the only ones that high were the nuts with the alignment cams. For those I used the 1/2” drive breaker bar. No problem there.
  12. Jul 10, 2021 at 7:08 PM
    clauderdale001
    Cody
    Hernando, MS
    That’s how I broke the 3/8” drive ratchet lol. I really just need a new set of sockets in 1/2” drive.
    15whtrd likes this.
  13. Jul 10, 2021 at 7:15 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    They say to use heat to remove the red locktite and it does make it easier. But, I usually just use a big wrench. Occasionally heat but not very often.
  14. Jul 10, 2021 at 7:16 PM
    2mchfun
    Heat near all the rubber bushings and plastic abs sensor is not a good idea.
    15whtrd likes this.
  15. Jul 10, 2021 at 8:12 PM
    clauderdale001
    Cody
    Hernando, MS
    Well maybe they’re not close enough for all that damage.
  16. Jul 10, 2021 at 9:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    1/2" breaker and a tube extension, and put lock tight on for reinstall and I'd torque them to spec. Those two bolts hold the weight of the entire corner of the truck, so they're working as hard as the cam bolts.
    15whtrd likes this.
  17. Jul 10, 2021 at 9:45 PM
    15whtrd
    15whtrd Mr. Blonde
    This is where your reverse row muscles come in to play LOL
    JLS in WA likes this.
  18. Jul 10, 2021 at 11:17 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I used an impact gun for mine, and applied red Loctite when I put them back together.
  19. Jul 11, 2021 at 9:24 PM
    clauderdale001
    Cody
    Hernando, MS
    Finally finished. The 1/2” drive sockets to go with my breaker bar solved all of my problems. It is now leveled.
    15whtrd likes this.
  20. Jul 12, 2021 at 3:52 AM
    2mchfun
    Did you tighten the LCA cam bolts after you set it down? If not, loosen up and tighten with the weight on the ground. You don't want the bushings in a bind.
