Need help quick lol
Discussion in 'Suspension' started by Tam37, Jul 11, 2021.
  1. Jul 11, 2021 at 6:32 PM
    Tam37
    Tam37 [OP] New Member
    Tam
    Victoria, BC
    2016 White Tundra Limited; double cab
    Trying to figure out before I do my own mods
    Does it matter how I remove old Firestone airbags - no order of operations? Can’t find any YouTube vids - but I have install instructions
  2. Jul 11, 2021 at 6:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    They are clearly deflated, so no special order required after that.
    Edit: on a closer look, it appears that the passenger’s side bag may still be inflated. That’s step one, then go to town.
    You’ll need new rear bump stops on top of your leaf packs if you’re removing the firestones and not replacing them with a new set.
  3. Jul 11, 2021 at 7:29 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Tie a rope around one, loop rope around tree, tie to second. Start truck, engage Tow/Haul button and stomp on it! :D (Don't do this!)
    Bob_Wiley likes this.
  4. Jul 11, 2021 at 8:00 PM
    Tam37
    Tam
    Victoria, BC
    I am getting so pissed off - I can’t get the fnk bolt off the top (where the valve was attached) -
    the bolts on the mounts broke with the impact wrench so that’s done. But I can’t hold the heavy ass impact wrench to get at that bolt (valve is off) - I have breaking bar but there’s no clearance; Jesus, do I need to remove the spare tire?!
    I have a new airbag set that I’ll install if I can take these fnk things off.
    The other side looks inflated only because I’ve jacked up the driver side only - they’re def deflated as the truck was sold to me with these airlines (or lack thereof)
    landphil[QUOTED] likes this.
  5. Jul 11, 2021 at 8:01 PM
    Tam37
    Tam
    Victoria, BC
    This is plan B - getting close
    Tundra2 and 2mchfun like this.
  6. Jul 11, 2021 at 8:08 PM
    Gravy
    Yucaipa, California
    You have a torch? Heat cycle it a few times might break the internal rust bond. Also, think Autozone sells nutsplitters. Then there's always the savior of last resort - cutoff wheel.
  7. Jul 11, 2021 at 8:13 PM
    2mchfun
    Sawzall or cold chisel might get it done
  8. Jul 11, 2021 at 8:13 PM
    Tam37
    Tam
    Victoria, BC
    With the can of penetrating oil that’s on there
    - plan C
  9. Jul 11, 2021 at 8:14 PM
    2mchfun
    Pb blaster or other penetrating oil
  10. Jul 11, 2021 at 8:15 PM
    Tam37
    Tam
    Victoria, BC
    I was thinking that - but thought I’d cheap out and not invest in one of those - didn’t think this would be so friggin frustrating.
  11. Jul 11, 2021 at 8:17 PM
    2mchfun
    Put a box end wrench and cheater on the wrench it will either loosen or break off
    Gravy likes this.
  12. Jul 11, 2021 at 8:19 PM
    Gravy
    Yucaipa, California
    Lucky I'm a welder, so plan b for me always involves an angle grinder and a cutoff wheel. When all you have is a hammer, everything looks like a nail...
    Bob_Wiley, landphil and 2mchfun like this.
  13. Jul 11, 2021 at 8:22 PM
    Tam37
    Tam
    Victoria, BC
    Hmmm- believe it or not - the hardware store here had no idea what a cheater bar was when I asked where to find them the other day.
    I’ll have to ask for physical help then
  14. Jul 11, 2021 at 8:22 PM
    2mchfun
    Plasma torch or arc gouger for the serious problem solving.
    Gravy[QUOTED] likes this.
  15. Jul 11, 2021 at 8:24 PM
    2mchfun
    Put box end wrench on the nut, then use another box end wrench as a cheater looped over the open end of the combination box open wrench.
    Blang805 likes this.
  16. Jul 11, 2021 at 8:25 PM
    Tam37
    Tam
    Victoria, BC
    Greasy af in there
    2mchfun[QUOTED] likes this.
  17. Jul 11, 2021 at 8:28 PM
    2mchfun
    Check out YouTube for how to use wrenches to multiply torque
  18. Jul 11, 2021 at 8:29 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    if you have no use for the hardware and the nut inside of the frame, i would get a grinder with a cutoff wheel and low grit flapper disk and go to town. sometimes doing it the "right way" (trying to loosen rusted and corroded bolts) is the hard way.
  19. Jul 11, 2021 at 8:30 PM
    Gravy
    Yucaipa, California
    Penetrants don't work near as well w/o some percussive maintenance, if you've already hosed it down with PB, be sure to give it some good whacks with a wrench or something. But I agree with 2mchfun, box end that sob and either use another wrench or some pipe if youve got it laying around, and manhandle that bastard.
  20. Jul 11, 2021 at 8:34 PM
    Gravy
    Yucaipa, California
    Just noticed you already had a breaker bar, put a pipe on that thing and see which splits first, the nut or the socket!
  21. Jul 11, 2021 at 8:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d totally drop the spare tire for more room too.
  22. Jul 11, 2021 at 8:59 PM
    Gravy
    Yucaipa, California
    He hasn't replied in more than 30 minutes, I think something broke... shall we take a poll: What did Tam break: The nut, his knuckles, a wrench, or his sanity? :D
  23. Jul 11, 2021 at 9:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    *Her.
    Blang805 and ColoradoTJ like this.
  24. Jul 11, 2021 at 9:13 PM
    Gravy
    Yucaipa, California
    DOH, my apologies Tam!!!
    landphil likes this.
  25. Jul 11, 2021 at 9:15 PM
    Do you have the old bump stops by any chance after you do the strap/tree mod?
    Gravy likes this.
  26. Jul 11, 2021 at 9:31 PM
    Tam37
    Tam
    Victoria, BC
    She, by the way! - and I’ve tried all the suggestions; with the exception of using sawzall or grinder - and that’s only because my vehicle is jacked up and hardware stores are closed to buy one. I’m so frustrated; for real! lol - I’ve asked a friend to bring a sawzall- and now it’s dark. This was supposed to be my “hold over” while I load the back with camping gear in the am- waiting for the dobinson ims kit - as I’m driving on flat leafs, blown rear shock, and deflated airbags - fnk long story, but this was my trial at doing it myself. I wont jack shit up ever again without blades and grinders; maybe a welder lol
  27. Jul 11, 2021 at 9:40 PM
    Gravy
    Yucaipa, California
    Hang in there. You're at the stage where it's hard to give you options without knowing what tools you have. You've got that 2' breaker bar and socket in the pic. You already tried putting a length of pipe over the handle? With 2 or 3 feet of pipe as extension, you'll either sheer that nut off or explode the socket, hopefully the former.
  28. Jul 11, 2021 at 10:37 PM
    Blang805
    Blang805 New Member
    Build in Signature
    Just look at it as a learning experience. I’ve been there too with my old long traveled Tacoma. It was a sht show at times but after once not having a certain tool, I decided to go ahead an buy them. Now I’m using those tools on other projects too. It all pays off at the end.
    Keep your head up and get it squared away tomorrow :thumbsup:
    2mchfun and Tam37[QUOTED][OP] like this.
  29. Jul 12, 2021 at 12:49 AM
    Tam37
    Tam
    Victoria, BC
    Yes - I know now; lol - I was getting so mad because I just wanted to get it done and leave town early tomorrow (patience is clearly not my strong suit).
    But….one side is officially done, hah!
  30. Jul 12, 2021 at 12:52 AM
    Tam37
    Tam
    Victoria, BC
    Thanks everyone for your suggestions and support rest assured I’ll be making at least a couple SOS posts when the susp and lift kit arrive - I’ll be making a tool list next week!
    Blang805 and 2mchfun like this.
