Magnetic Gray Metallic-MGM (1G3) Picture Thread
Discussion in 'General Tundra Discussion' started by 14tundra, Nov 22, 2016.
  1. Jul 10, 2021 at 7:53 PM
    #2551
    DevenTX
    DevenTX New Member
    Deven
    2020 Tundra SR5 Crew Cab
  2. Jul 12, 2021 at 1:20 PM
    #2552
    Agent680
    Agent680 New Member
    2018 Tundra TRD Off Road Limited
  3. Jul 13, 2021 at 5:21 AM
    #2553
    Robster80
    Robster80 New Member
    How do u like those rb20 running boards? Debating on getting a set
  4. Jul 13, 2021 at 5:33 AM
    #2554
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
  5. Jul 16, 2021 at 12:06 PM
    #2555
    Shammy
    Shammy New Member
    2021 Tundra Grey SR5
    I know this is a stretch but has anyone seen a MGM with everything color matched but the bottom grill surround?
    I’m getting rid of chrome and I have caps and bulge done but thinking of blacking out or painting bottom grill surround to avoid the crazy cost of whole new grill.
  6. Jul 17, 2021 at 9:11 PM
    #2556
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  7. Jul 17, 2021 at 9:25 PM
    #2557
    AZBoatHauler
    So.Arizona
    MGM looking good over Imogene Pass.
    Big J, Prostar 190, GAknight and 10 others like this.
  8. Jul 18, 2021 at 4:26 AM
    #2558
    MightyTundraGA
    MightyTundraGA New Member
    What kind of wheels? Size of tire? Lift? I'm going for a similar look.
  9. Jul 18, 2021 at 6:57 AM
    #2559
    AZBoatHauler
    So.Arizona
  10. Jul 18, 2021 at 8:56 AM
    #2560
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They are Raceline Gauge 950B 18x9 +18mm offset with 295/70R18 Falken Wildpeak AT3w and a 3/1 lift. More details are in my build thread (thanks for linking that, @AZBoatHauler) but let me know if you have any questions on it.
  11. Jul 18, 2021 at 9:11 AM
    #2561
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    Stock wheels and tires...I did add 1 1/2" spacers.
    Big J, 2017xp, Prostar 190 and 6 others like this.
  12. Jul 19, 2021 at 3:03 AM
    #2562
    wdw67
    wdw67 New Member
    2021 trd pro
  13. Jul 19, 2021 at 5:06 AM
    #2563
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Nicely done!
    It will look even better with upgraded tires. But IMO just let that stock rubber wear out first.
  14. Jul 19, 2021 at 5:20 AM
    #2564
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    My 2015 just earning its keep!
    And I mean hauling too.
    6000 miles in 2 weeks half of that towing this trailer.
  15. Jul 19, 2021 at 7:27 AM
    #2565
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    @AZBoatHauler what size and type tire do you have? Looking for something similar to go on my stock TRD wheels. Great pics!
  16. Jul 19, 2021 at 8:15 AM
    #2566
    AZBoatHauler
    So.Arizona
    Thanks. I’m running 275 70 18 Nitto Ridge Grapplers. Ive put 25k miles on them and I’m very impressed with everything about them other than on-road braking in wet conditions. They are getting louder as they wear but I’m happy enough I’ll probably replace them with another set in 10k miles or so. Just trying to decide whether to stick with the same size or bump up to 285 70 18. I won’t go bigger than that unless I re-gear.
    GT87[QUOTED] likes this.
  17. Jul 19, 2021 at 8:25 AM
    #2567
    GT87
    GT87 New Member
    Greg
    Western NY
    Nice! I'm in the same boat as you. Ideally I'd like to go with a 285/70r18 but that is a pretty limited size and RG's are one of the few tires out there available in that size. However, your truck looks really good with the 275/70's which is what I'll probably go with. I'd be looking at a 3 peak rated tire. Looks like you're in AZ, assuming you don't have much experience in snow with the RG's?
  18. Jul 19, 2021 at 8:50 AM
    #2568
    AZBoatHauler
    So.Arizona
    Correct - I have no experience with these in snow or ice.
  19. Jul 20, 2021 at 5:14 PM
    #2569
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    What did you do to the exterior handles? Since it's platinum, did you buy new ones, or give plastidip a go?
    $500 is steep for some new handles, but I'm still contemplating. Then again, I'd rather put on lift and tires...
  20. Jul 20, 2021 at 6:22 PM
    #2570
    MightyTundraGA
    What kind of wheels/offset and tires you have on this thing? I like the aggressive look, but still within the wheel wells. This is what I'm going for as well. I assume you have the standard TRD PRO lift?
  21. Jul 20, 2021 at 9:46 PM
    #2571
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Wireless Charging Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters Undercover Swing Case Wireless LED Bed Light Strip Toyota Chrome Exhaust Tip 18" TRD Wheels
    Does anyone have pics of stock 18’CM with fender flares? I like the stock wheels/rims on mine but was wondering what flares would look like. TIA
  22. Jul 20, 2021 at 10:02 PM
    #2572
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Took them off and painted myself
  23. Jul 21, 2021 at 8:22 AM
    #2573
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    What brand of rims are those please?
  24. Jul 21, 2021 at 9:03 AM
    #2574
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Hey Vicky, they are Raceline Gauge 950B 18x9 +18mm offset. Let me know if you have any other questions on them.
    2021 Semi Pro likes this.
  25. Jul 21, 2021 at 10:11 AM
    #2575
    vl184009
    Vicky
    Southern, Ca.
    Thanks, gonna look them up. Really like them...
    TRDFerguson[QUOTED] likes this.
  26. Jul 21, 2021 at 6:29 PM
    #2576
    Famof5Tundy
    That's great news! How has it held up? I bought some AJT stuff and painted the plastics on the inside to dress it up. It's done well, but wedding rings scratch the regular auto paint...sun rocks and chrome isn't too sticky.....that's why I also how it's held up.
  27. Jul 21, 2021 at 10:40 PM
    #2577
    1904Tundra
    1904Tundra New Member
    Sam Diego
    2015 MGM Limited CM
    New to this thread, heres a pic of my tundra limited
  28. Jul 21, 2021 at 11:18 PM
    #2578
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Few weeks ago visiting some fam. About two weeks after some serious polishing and ceramic wax.
    Big J, Sean492, November Sun and 5 others like this.
  29. Jul 22, 2021 at 5:16 AM
    #2579
    BrakeDust
    Hill Country, TX
    Amazing! :thumbsup:;)
    :benchpress:
    :101010:
    GAknight[QUOTED] likes this.
  30. Jul 22, 2021 at 6:42 AM
    #2580
    Welcome from NY.
