  1. Jul 8, 2021 at 3:45 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    I have the same issue with mine. Tried a back to black but didn’t do much. Need to try another brand.
    looks good!
    Silverghost and Orracle[QUOTED] like this.
  2. Jul 8, 2021 at 7:30 AM
    Beachcomber
    Beachcomber New Member
    2011 Silver Sky CrewMax
    BDS 4.5" w/fox CO Lift Sequoia Grill & Headlights Prinsu Roof Rack Bullet Lined Roof Fuel Wheels/NItto Grappler Tires
    Prinsu Rack installed over the weekend. Very happy with the install now I need to start adding the accessories.20210708_103027.jpg 20210708_103235.jpg 20210708_103019.jpg 20210708_103306.jpg
    Prostar 190, D4x4TRD, wv00097 and 9 others like this.
  3. Jul 8, 2021 at 1:31 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    This stuff works very well. Better than anything I've used for making the black plastics look new. Seems to last longer too. I use it on everything but my tires.
    I start at one corner of the truck and work my way around applying, by the time I make it all the way around it's time to go back and start wiping off.
    TheBeast likes this.
  4. Jul 8, 2021 at 1:50 PM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
  5. Jul 8, 2021 at 2:03 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    This got me thinking. When I was applying Cquartz 3.0 ceramic coating on my paint, I got some on the plastic trim on the door and it made it look black instead of dull. So I do think the ceramic coating will help, if any.
  6. Jul 8, 2021 at 2:38 PM
    Orracle
    Orracle New Member
    Canton, GA
  7. Jul 9, 2021 at 11:53 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Installed my Midland MXT275 in the center console, with a remote plug using a factory blank location. Turned out super clean. Able to hit my best friend using our “high gain” antennas 8 miles apart in dense urban. Very impressed. Most likely going to setup one as my base station in the house with a J-Pole antenna in the attic so we can talk house to house, always good to have backup comms. Will probably upgrade the unit in the truck to the new mxt575 when it’s released and move the 275 to the house.
    **EDIT** Ended up moving the rj45 pass through so the cable would hang more naturally when in use.
    A9A54357-FE7E-417B-99ED-DDB5896BBE4D.jpg 7F56DB21-0C12-4A34-8795-030D68FF8257.jpg 7A27D8FB-1C1C-4091-A619-B42C54255092.jpg D6E1B0EA-129C-4B3C-8B75-02E9153FF606.jpg 5C2C75D8-07DA-4AA8-8B7E-38A1FFD4C7F5.jpg
    Prostar 190, WVI, D4x4TRD and 10 others like this.
  8. Jul 9, 2021 at 5:10 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Package 1 of the bumper came today. Apparently it’s the winch mount/main center plate. Also 4 LED pod lights with hardware.
    The other package which I can only assume is the actual front pieces is still in “labeled” status lol and hasn’t moved yet
  9. Jul 9, 2021 at 5:15 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Got my DD SS3 Amber lights and PowerStop z36 brake kit today. Thank you @memario1214 for changing my mind on the lights had a bit of difficulty on the housing due to stubborn screw on the side but after removed housing sit right on there. Brakes will be mounted later even though the tiny rear brakes compared to the front brakes really freaked me out for a second
  10. Jul 9, 2021 at 5:19 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Of course it did. It was a 10mm. You can never find those things.
  11. Jul 10, 2021 at 6:29 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    You and I are on the same wavelength..only in reverse.
    The tundra brakes are underwhelming to say the least. They're not much bigger than the brakes on my sedan weighing an entire ton less.
    It's nice to finally have the factory fresh pads and rotors on there after accumulating the brake shims and hardware. I've never had to purchase the shims for the pads separately before (for almost $60), but hopefully I get several years out of the set... We shall see with these little baby rotors.
    I also rotated the "big foot ATs" as the front tires seem to have a little more wear than rear, and I have no idea when it was done last.
    I also have a fog light project I'll try to get after in the next few. But heres a teaser:
  12. Jul 10, 2021 at 10:55 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Fixed new LED lights on the bullbar I can go purging or zombie hunting tonight ‍♂️‍♀️80419A37-EC94-4000-B9ED-1BE8ECFCD9F7.jpg 55115376-1286-42C1-8622-DF23AECBFF26.jpg
  13. Jul 10, 2021 at 2:55 PM
    iDon’tRead
    iDon’tRead New Member
    72C4EA52-EEBA-457E-976B-3EE4057156B9.jpg Finally got it up , still need to redo my weather sealer since theirs a gap now .. the crew max size doesn’t look too bad in person
    D4x4TRD and Mountun Goat like this.
  14. Jul 10, 2021 at 6:02 PM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Last weekend I made a trip up to Bayfield, WI to do some fishing with my dad and grandfather on Lake Superior. Caught 5 lake trout! Made a quick pit stop through the cabin on the way home to ditch the topper and threw on the bed cover. The topper definitely looked nicer in my opinion but wasn't as functional as a pickup.
    Lake Trout:
    Ditched the Topper:
    The Tundies hanging out:
    This weekend I threw in Morimoto headlights and Morimoto license plate lights that I picked up over the 4th (gotta get the deals!). The headlights are absolutely delightful looking. Cant wait to see how the output looks on the road. The license plate lights are almost too bright, but they serve their purpose well. Overall, took about 45 mins to install both, couldn't have been easier. Can't wait to black out the chrome, it will really set the truck off!
    All lights off:
    Running lights only:
    Running lights only in the dark:
    License plate lights:
    License plate lights illuminating half of the northern hemisphere:
    mrn320, Prostar 190, tnbndr and 11 others like this.
  15. Jul 10, 2021 at 6:15 PM
    SouthWestGA
    Dang those plate lights are bright!
    aelarson likes this.
  16. Jul 10, 2021 at 6:28 PM
    aelarson
    aelarson New Member
    AZ
    Yeah, they are no joke! I'm going to have to find a spot to mount my backup camera that isn't in the light path, otherwise they will completely wash out the camera.
  17. Jul 10, 2021 at 6:39 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    i want this grille :pout:
  18. Jul 10, 2021 at 7:10 PM
    Skywalker
    Skywalker New Member
    CO
    2003 Land Cruiser, 2010 Tundra SR5 TRD Double Cab
    just bought a 2010 sr5 double cab off road, 126k on the clock and a solid maintenance history. I pick it up Tuesday. Pretty excited to have a pickup back in the fleet. It compliments the 2003 Land cruiser nicely.
  19. Jul 10, 2021 at 7:32 PM
    TheBeast
    TheBeast The Beach
    looks great. I have the same lights and yep the morimotos license plates lights are super bright. For $30 it's a no brainer imo
    aelarson[QUOTED] likes this.
  20. Jul 10, 2021 at 7:35 PM
    TheBeast
    TheBeast The Beach
    Gave it a good wash and spray wax from Chemical Guys. Not bad imo.
    Mountun Goat and omgboost like this.
  21. Jul 11, 2021 at 9:49 AM
    Hank
    Hank New Member
    its just a generic from Tractor Supply. I had to cut the harness off my old, damaged plug, and solider it to the new plug. But you can buy a plug-and-play plug for easier fitment.
    YotaMando likes this.
  22. Jul 11, 2021 at 12:09 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Reminisced on the Goats past build progress and feeling bummed I haven’t played with it for ever :(
  23. Jul 11, 2021 at 12:23 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Before and after?
    Mountun Goat likes this.
  24. Jul 11, 2021 at 1:36 PM
    TheBeast
    TheBeast The Beach
    goat will always be the Goat
    Silverghost and Mountun Goat like this.
  25. Jul 11, 2021 at 2:32 PM
    Tui
    Tui New Member
    2013 Tundra RW
    For sale if anyone wants them. OEM crewmax running boards. Took these off about 4 years ago and have just been in storage. 1 bolt is missing. Everything else is there. $100 located in SoCal
    35CC8E7D-6226-4BD3-B3CF-708FB5087D4A.jpg 8F6760EF-5B2B-4DA6-8808-E98BAC0C273D.jpg
  26. Jul 11, 2021 at 3:40 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Crossed a few things off the list today...
    Mounted my powered sub vertically on the back panel. Used a couple brackets and properly fitted hardware and I think its pretty solid. Hated drilling 4 holes into the panel, but used some grommets and I think it looks pretty clean. Better than being loose on the floor behind the seat, and impeding the seat positions.
    Took that time to also install killmat on the rear panel. Will be doing the doors over the next few weeks. Can tell a small difference, keeps the bass in and exhaust out. I have a feeling this will be one of the top 5 best mods I've done when it's all done. I don't think I'll do the floors, but maybe one day. At least the doors. Of course, I forgot to take a pic.
    Coachbuilder abs relocation bracket kit. Only did one of the two brackets it comes with. The BDS kit comes with a small relocation bracket for the hard brake lines, which I kept, but not abs sensor wires. That being said, I've got a relocation bracket for the brake lines if anyone needs it. Willing to ship.
    Replaced PCV valve. $10 and 10min maintenance.
    Then the big ticket item today, spark plugs. I'm at 98.5k miles, 5.7L. Oil on #4 and #6 plugs... great. Going to start looking at valves, seals, and such next oil change. Overall, good idea to change them. Tips looked fine, but they needed a change.
    Mountun Goat, omgboost and 81 TOY like this.
  27. Jul 11, 2021 at 4:33 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    That's not valve seals, that's the spark plug tube seals. It can be a bit of a problem when the oil damages the spark plug boots.
  28. Jul 11, 2021 at 7:29 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Yep. I got the seals. Just going to wait another few weeks before getting back to it. Pain in the ass with off and on rain today
  29. Jul 12, 2021 at 7:22 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yes only the flares are back on again.
    81 TOY[QUOTED] likes this.
  30. Jul 12, 2021 at 7:22 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :fistbump::fistbump::fistbump:
    MTRock likes this.
