Conflicting research caused this thread to be created. 3" lift questions.
Discussion in 'Suspension' started by TucsonTundra1794, Jul 9, 2021.
  1. Jul 9, 2021 at 10:55 AM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Ok guys, I started big, I wanted a 6" lift with all the bells and whistles but I finally had a chance to meet up with a friend who has the BDS 6" with fox shocks and I was not as impressed as I thought I would be. 7k in suspension parts and I wanted to be able to drive over speed bumps and not feel them as much. It was very clunky, slushy steering and I was willing to overlook the fact that my bed will be that much harder for me to access for work if the ride was what I wanted. Now I know one truck isn't how they all drive and his could be worn or installed improperly or any number of things and I know many people will post saying they don't have that experience at all.
    All and all I have decided to go with a 3" lift and sacrifice the ride height i want for practicality. Instead of going back and forth with all the research I've read about what is and isn't needed I figured I'd post my situation and see if I can get a definitive answer so I can get my lift installed with everything I need on the first try
    Kit: icon stage 8 with tubular UCS's and rtx leaf set
    Currently the truck is bone stock except for some 1" spacers on the wheels. Running stock 18" Toyota wheels for now.
    I will be using my truck for work mostly (construction), family trips, and occasional off roading.
    What else should I do while the suspension is pulled apart? What other parts do I need other then what comes with the kit? Should I be aware of any issues I may have or stay away from any products what won't work with this kit like TRD sway bars, traction bars, armor?
    Thanks for the help guys. I want to do this right and not regret anything.
  2. Jul 9, 2021 at 11:06 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Not sure what comes in the kit but other than new coil overs and rear springs for 3 inches you will want UCA, front diff drop, rear carrier drop. Kit should come with all bushings and such, just confirm it does.
    sway bar can work, may need to rotate the mounting but that has been covered here. Skids and other armor should work fine as well. Dont know about traction bars, but certainly dont think you will need them.
    TucsonTundra1794[OP] likes this.
  3. Jul 9, 2021 at 11:16 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nothing is gonna ride smoother than stock and fit your needs as a work truck.
    Tundra2 and BroTun13 like this.
  4. Jul 9, 2021 at 11:23 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Comes with the tubular arms, I'll have to source the diff and and carrier drop. I'll verify the bushings come with it.
  5. Jul 9, 2021 at 11:24 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I've heard icon rides super smooth. I don't know from personal experience in a tundra but my friends 4th gen 4runner rides like butter.
  6. Jul 9, 2021 at 11:27 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I personthing think the Diff drop is gimmicky. The carrier bearing does need to be adjusted. Just make sure your drive line angles are all correct before torqueing down your new U bolts.
  7. Jul 9, 2021 at 11:28 AM
    Mwray8909
    Chino Valley
    I've been running a stage 8ish for 3 year on my tundra and love it.
  8. Jul 9, 2021 at 11:30 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    @Bob_Wiley is running the Stage 5 I think. He might have some thoughts. His truck looks awesome.
  9. Jul 9, 2021 at 11:30 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The company installing will do alignment so they should be doing that.
  10. Jul 9, 2021 at 11:31 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Do you have the RTX pack on the back? That's the only reason I bumper up to stage 8 from 5.
  11. Jul 9, 2021 at 11:36 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Love my Icon RXT leaf pack. I would probably piece things together individually though. But at this point, it all depends on what’s available.
    I had Icon 2.5s in the front and moved to Fox reservoir 2.5s and they ride about the same for everyday use, so you will probably be happy with their shocks.
    At the very least I would recommend not going with the Icon tubular UCAs, way too many people have had issues with them, especially trying to fit bigger tires, their geometry just isn’t right.. spend a little more and get Total Chaos or MCM UCAs or some of the other popular brands.
    Also really don’t need the diff drop, general consensus is that it isn’t needed in these trucks. I also didn’t do carrier bearing and have no issues on RXT option 2, so you would likely be fine there too.
    definitely invest in armor if you want to Offroad. Rock sliders are the most important in my opinion.
    Good Luck!
  12. Jul 9, 2021 at 11:41 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Thank you! What about the billet UCAs from Icon with the delta joint? If I go with another brand I'll have to piece my Icon kit without them instead of just ordering the whole stage 8.
    SC_TRD[QUOTED] likes this.
  13. Jul 9, 2021 at 11:48 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Where are you located? Some people say to stay away from the uniball uca if you’re in a harsh winter environment. The salt and brine sprays will eat away at it faster. I went with the SPC in Chicago for that reason.
    Bear likes this.
  14. Jul 9, 2021 at 11:55 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Tucson AZ. I don't know the word winter.
    Bear, Bob_Wiley, SC_TRD and 1 other person like this.
  15. Jul 9, 2021 at 3:21 PM
    SC_TRD
    Colin
    Round Rock, Tx
    The heimmed billet UCAs would solve the issue, those are supposed to be great.
  16. Jul 9, 2021 at 3:22 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Ok, are they worth all the extra $$? the company doing the install suggested a different brand of UCS's because he said not to go with tubular.
  17. Jul 9, 2021 at 3:29 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I've got a quote for $3085 for the kit minus the arms. I think I'll pull the trigger on these and go with different UCAs unless the billet are worth it.
  18. Jul 9, 2021 at 3:33 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Changing gears I see!
    -JS
  19. Jul 9, 2021 at 3:40 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    I have ran many ucas jba bds stock and icon billet delta joint with the heim joints. Awesome build quality but if I didn't clean them they were extremely loud. I drive in dirt and sand every few days and if I didn't constantly clean them my neighbors could hear me backing into my driveway from inside there house.. took them to the shop a few times they said its the heim joint design. So just keep that in mind if it's your daily and you see dusty sandy roads be prepared to clean them daily
  20. Jul 9, 2021 at 3:43 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah... really wanted the 6" actually had a deposit down and friend of mine came by and let me drive his and I did not like the ride quality.
  21. Jul 9, 2021 at 3:49 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'd have to leave the state to find a road with no dirt. What kind of UCAs should I be looking for?
  22. Jul 9, 2021 at 3:52 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    As we've previously discussed a few things to keep in mind:
    1.) Custom springs and valving will change the entire characteristics of a vehicle
    2.) BDS spec isn't necessarily optimized for ride quality, being the higher you go...naturally the Center of Gravity goes up, to keep you from rolling over...they will likely spring and valve where they deem safe for the increased C.O.G.
    -JS
    Ely010606 likes this.
  23. Jul 9, 2021 at 4:02 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah, I knew I'd sacrifice a little but his setup was 4 months old and just wasn't what I expected
  24. Jul 9, 2021 at 4:08 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    If you're ever in the PHX valley, more than happy to let you take a test drive in my mild setup...
    -JS
  25. Jul 9, 2021 at 6:29 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Jba bds spc. Haven't heard any noise complaints from any of these. I've ran all 3. Only issues I've ran into noise wise is heim joints on icons
  26. Jul 9, 2021 at 7:51 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  27. Jul 9, 2021 at 7:55 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Great UCAs! I personally worry about "proprietary components" that can't be easily replicated. Should the company go defunct..SPC is unlikely to...tracking down wear items can be a challenge...
    Less expensive from our the fine folks at @Toytec Lifts.... -JS
  28. Jul 9, 2021 at 8:39 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I might be able to negotiate that price down if I show them that link...
  29. Jul 9, 2021 at 9:53 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    I’m running Icon stage 6 with billet UCAs and really like it. I don’t really have anything to compare it against other than the 3” spacer lift on stock Bilsteins I had before, so that’s obviously a night and day difference. I typically keep it on the softest setting which makes the truck feel planted but not too mushy. I’ve run through speed bumps at full speed to see what it feels like, it absorbs them really well. Haven’t taken it through any desert washes at full speed yet, so I just have the urban testing results to go off of haha. There’s a very noticeable difference in how firm the shocks are as you crank up through the compression settings. For me personally, stage 6 is probably a little overkill (I only off-road occasionally), but I don’t regret getting it. I do wonder how it would compare to Fox or Kings (@BiggHertz I would love to compare with your Fox setup sometime).
    If you’re up in the valley sometime let me know, I’d be happy to let you take mine out on a test drive so you can see what the stage 6 setup is like.
    Thanks!
  30. Jul 9, 2021 at 10:03 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    totally down to meet up just about anytime ! Did you ever throw in those CB drop spacers?
    -JS
