Outside rear dome light
Discussion in '2nd Gen Tundras (2007-2013)' started by Norm1953, Jul 8, 2021.
  1. Jul 8, 2021 at 9:54 AM
    Norm1953
    Norm1953 [OP] New Member
    Norm
    Lakeland, Fl
    2012 Tundra SR5
    How do I control the amount of time my cargo light stay on. Currently after parking my truck it stays on for approx. 10-15 minutes.
    Any help would be greatly appreciated
    Norm
  2. Jul 9, 2021 at 9:12 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Is the Cargo light switch set to "ON" ? The switch should look like this and have 3 settings.
    OFF, the light will never come on.
    Door
    (in the middle) the light comes on when the doors are opened/the truck is unlocked. Works the same as the dome lights in the upper console. Once shutdown the truck and close the door the light will go off a few seconds later. This is the setting almost everyone keeps the switch on.
    ON the light stays on all the time while driving. I assume yours is set to On and the light stays on for 10 minutes until the truck realizes it has been parked and shuts down all accessory power.
    Check the position of the switch. You might just need to move it to the middle "Door" location.
    Wallygator and BravoDeltaRomeo like this.
  3. Jul 10, 2021 at 9:23 AM
    Norm1953
    Norm
    Lakeland, Fl
    2012 Tundra SR5
    Thanks Jeff, Yep, the switch was in the on position. Thanks a bunch, I've owned this truck since 2015 and you would have thought by now I'd know this things.
    Again Thanks Norm
    Jeff_5_7 likes this.
